Question about Pioneer SD-P50A5-K 50" Rear Projection Television
Pioneer projection tv model sd p404 channel programming
I can't program the channels on the tv. it's missing a few cable channels and i can't figure out how to reset or put the television through a channel scan for cable. there no catv switch either.
  • 1 more comment
  • chillefreeze Dec 22, 2007
    no it goes up to channel 65 then skips everything until 94 it doesn't go past 100
  • Anonymous Jan 07, 2008
    i am haveing the same problem with my tv sd-p5071 i want to set all my channels up to 99,it goes from 65 to channel 94 i need helppppppppppppp
  • barnwell69 Jan 18, 2009
    I am having the same issue, Is there a way to get the tv to reset and do an initial channel scan again
    Problem Solver:
  • 16 Answers
Are the channels are above 125 ?
Posted on Dec 21, 2007
Toshiba rear projection will not play one antenna channel
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
Jan 24, 2016 | Toshiba 62HM196 62" SD Television
Have a mod # kp-53v45 tv and it wont let me program it to get my cable to run through it, and dont have a manual to it, what to do?
Please open the manual of the KP-53V45 TV by clicking here. To program the channels in the TV, make sure that the cable is connected to the TV using the Coaxial VHF-UHF cable. Select the Auto Program option to program the channels in the TV. Press the MENU button select SETUP MENU and then select AUTO PROGRAM option to scan all the channels in the TV.
Thanks for contacting FixYa.
Jul 16, 2011 | Sony KP-53V45 53" Rear Projection...
I was given a pioneer tv sd-p5575 and i dont have
MY PROBLEM IS ANTIVIRUS IX DIRTY AND NEW ANTIVIRUS
Dec 06, 2009 | Pioneer Televison & Video
Tv missing remote. bwant to watch cable tv
many of these require an original remote to program the catv and other functions---check ebay with your model number and see if you can get one.
Aug 06, 2009 | Televison & Video
Hitachi 53FDX20B -- HD tuner?
hi, hd ready means the tv is capable of re-producing the hd picture from a cable or satellite co. call your local cable/sat people they can advise you which channels are which in your area, video-tek
Jun 06, 2009 | Hitachi 53FDX01B 53" Rear Projection...
Programming Channels
Your TV is likely set for "AIR" tuning rather than "CABLE" mode. In this case channels above 13 don't tune correctly. The tuning mode is adjusted through the setup menu (it's been too long since I've seen one of these to remember exactly how the menu looks). Once you set the tuning mode for cable, all the available channels should come in properly.
But you've said you have satellite, so you should have a satellite receiver connected to your TV, and you'd be changing channels there rather than on the TV. Your TV would be staying on channel 3 or 4 (if using the satellite antenna output connection), or on the A/V input you have the satellite connected to (if using the direct A/V outputs). Am I missing something about your system?
Feb 18, 2009 | Mitsubishi WS-73905 73" Rear Projection...
Hooking up my cable
You will need to go into the menu and do a channel scan. Until the tv scans through all of the channels and finds them you will not get them. This is also where you would switch between air and cable. If you go through the menu untill you see this you will fix your tv.
Feb 06, 2008 | Pioneer SD-533HD5 53" Rear Projection HDTV
No audio or video
If you can see the channel number as well as the volume setting when you press on the appropriate buttons on the remote, then it would seem that what happened is that your TV went into muting (video and audio). This can only be brought about if the TV is not receiving any signal from your cable or aerial. This is a built-in feature. Another possibility is that the tuner section of the TV has some issues. To determine whether cable or tuner, pls try installing a known operational VCR and play a good tape. Connect the RF OUT of the VCR to the CABLE/ANT IN of the TV. Select channel 3 or 4 and should you be able to watch the tap video, then you have just confirmed that it is your cable (or aerial). If on the other hand there is likewise no display on either 3 or 4, then you have just confirmed that somethings needs to be done internally in the tuner section.
Hope this be of some help/idea. Pls post back how things turned out or should you need additional information.
Good luck and kind regards.
Feb 05, 2008 | Pioneer SD-P50A5-K 50" Rear Projection...
Pioneer projection tv model sd-p404
In menu go to cable/then press auto programming see if this fixes your set.
Dec 06, 2007 | Pioneer SD-P50A5-K 50" Rear Projection...
Programming digital channels
The problem is not with your TV. You need a digital box to unscramble the channels.
Oct 28, 2007 | RCA HD52W56 52" Rear Projection HDTV
Pioneer SD-P50A5-K 50" Rear Projection Television Logo
151 people viewed this question
Top Pioneer Televison & Video Experts
Jaime Hernandez
Are you a Pioneer Televison and Video Expert? Answer questions, earn points and help others
