Maytag flashes LD.I only use he detergent.I checked the holes and all is properly installed.
    President:
  • 1,304 Answers
Sounds like a door lock issue
Posted on Oct 03, 2009
What is hd code????
Hi Peter, If I understand your question correctly, you are asking what the code "HD" means for your machine. I am unable to find the code "HD", however, here is a list of the codes for these Maytag models, perhaps one looks similar to "HD". Hopefully this answers your question!
Washer displaying code messages
- "LF" (Washer is taking too long to fill)
Check the following:
Are the water inlet hoses kinked or clogged?
Are the water inlet valve screens clear?
Press PAUSE/CANCEL to clear display.
- "Ld" (Washer is taking too long to drain water from the wash tub)
Is the drain hose kinked or clogged?
Is the drain hose installed properly? See "Connect the Drain Hose." Press PAUSE/CANCEL
to clear display.
- "uL" (Unbalanced Load)
If the load is unbalanced, the washer will display this code while running an imbalanced
load correction routine at the end of the wash cycle and before the final spin. If the code
remains and the wash cycle dial is flashing after the recovery routine has stopped, open
lid and redistribute the load. Close lid and press START.
- "oL" (Over Load)
Is the washer overloaded? The washer has attempted to fill and begin the wash cycle. If
the washer is overloaded, it will drain any water and detergent that was added during the
fill. To correct the overload, remove several items and add detergent. Close lid and press
START.
- "Sd" (Suds Detected)
Did you use regular detergent?
Regular or hand-washing detergents are not recommended for this washer. Use only High
Efficiency ("HE") detergent.
Did you add too much detergent?
Always measure detergent. Follow detergent manufacturer's directions.
If excessive suds are detected, the washer will display this code while running a suds
reduction correction routine at the end of the wash cycle. The suds reduction routine
removes extra suds and assures proper rinsing of your garments. If the code remains and
the wash cycle dial is flashing after the recovery routine has stopped, re-select your
desired cycle using cold water. Press START. Do not add detergent.
- "lid" (Lid Opened)
Is the lid open? Close the lid to clear the display. If the lid remains open for more than 10
minutes, water in the wash tub will drain.
- "HC" (Cold and Hot hoses switched)
This code will appear at the end of the wash cycle to indicate that the cold and hot water
inlet hoses are switched. See "Connect the Inlet Hoses."
- "dL" (Door/Lid cannot lock)
Indicates lid is not locked. Check for items caught in the lid keeping it from closing. Press
PAUSE/CANCEL once to clear the code.
- "dU" (Door/Lid cannot unlock)
Is there excessive weight on the lid, such as a basket of laundry? Excessive weight will
keep the lid from unlocking. Press PAUSE/CANCEL once to clear the code.
- "F##" code
Press PAUSE/CANCEL once to clear code. Press START. If code appears again, call for
service.
May 01, 2014 | Maytag Bravos MTW6600T Top Load Washer
Dishes not coming out clean
Hello
There are some things you can try, however, if your Maytag dishwasher is not getting your dishes as clean as you would like. Maytag recommends several processes for fixing this issue with your dishwasher.
Do not run your Maytag dishwasher while hot water is being used in other parts of your home, such as washing clothes or showering. Hot water is needed for your Maytag dishwasher to properly clean dishes.
Run water in the sink in your kitchen until it gets very hot. Then, turn on your Maytag dishwasher. This will ensure that the water cleaning your dishes is the hottest possible temperature.
Clean your Maytag dishwasher to improve the cleaning results for dishes. Run your dishwasher on a short wash cycle and wait for it to fill up with water. Stop the cycle and add about 1/3 of a cup of rust remover to the dishwasher and finish the cycle. Run your Maytag dishwasher through one normal cycle with regular detergent to finish the cleaning process.
Check your detergent. Old detergent or those that have been exposed to moisture can be clumpy. This detergent will not clean your dishes as well when loaded into your Maytag dishwasher. Purchase fresh detergent.
Use extra detergent when washing dishes that have a lot of built-up grease or food particles. The extra amount of detergent is needed to get your dishes clean. Choose a long cleaning cycle to clean these dishes.
Fill your Maytag dishwasher properly. Dishes should not be stacked on top of each other or excessively crammed into your dishwasher. This will keep the dishwasher from adequately cleaning all areas of your dishes and from rinsing them thoroughly.
Sep 13, 2011 | Maytag Dishwashers
Ld signal won't drain
For the LD error please check for the following:
  • Check for kinked or clogged Drain Hose: Remove any obstructions in the drain hose / stand pipe / utility sink. Straighten the hose to remove any kinks. If the washer is unable to drain due to a kinked or restricted drain hose, the washer may not spin.
  • Check for Standpipe higher than 8 feet above the floor:The pump is not powerful enough to pump water to heights greater than 8ft. The water will remain in the basket.
  • Check for excessive suds in the washer: Drain pumps cannot drain suds out of the washer.
To clear the suds condition: Check the drain hose and make sure the hose is not plugged or kinked Press pause/cancel twice to clear the display Run the machine through a Rinse/Spin cycle using cold water, then a Normal cycle using cold water.
Note: Do NOT add any additional detergent. This will remove much of the remaining detergent held in the fabric. This step may have to be repeated to remove all the detergent.
Jan 16, 2011 | Maytag Bravos MTW6600T Top Load Washer
I have a kenmore elite top load washing machine. It keeps giving a code of ld. Ceral number is SM 9711024
Hello, LD stands for long drain.
If all the water isn't out of the unit within a certain time, the ld will flash.
Could be 2 things.
1) There's lint stuck in the pump preventing the water to drain properly or
2) You're using too much soap causing lots of suds also preventing the pump from draining properly. If this is the case, what you need to do is run the washer on full load with no detergent and clothes. Let it go thru the cycle and get rid of eccess suds. This is most likely your problem.
Best of luck :)
Aug 19, 2009 | Washing Machines
My Maytoag Bravos Top load washer drains really
Is the drain hose kinked or clogged? Is the drain hose installed properly? look in the installation Instructions, Press POWER/CANCEL to clear display........ hope this helps.....
Jul 09, 2009 | Maytag Bravos MTW6600T Top Load Washer
Cabrio washer wont drain
Could be 2 things.
Best of luck :)
Apr 06, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
Dishwasher does not clean well
If Rylee's above solutions do not fix your problem the filters may indeed be the problem. Start by removing the lower spray arm. There is no need to remove the arm from what I'll call the "arm base/cover assembly"; keep it clipped on.At the center of the arm is a knurled screw. It looks like a thin disk with several bumps on it, about 2 inches in diameter. It will unscrew (lefty-loosy) and allow removal of the arm assembly. At quick glance it appears to be a molded part of the arm but that's a clever disguise. Making this part a different color would be too helpful. What else would the Maytag repairman do it they made it easy for the do-it yourselfer?
Anyway, after removing the spray arm take note (or photos) of the visible parts, i.e, spray nozzle, 2 split plastic spacers. Be sure you'll be able to return these to their proper position later.
Remove the six torx (star-shaped) screws and lift the impeller cover off. Again note/photograph the position of remaining parts, i.e. filter, impeller. You will likely find the filter clogged with debris. It can be pulled out. On my model it is retained in a groove and take a bit of force to remove. I used water pressure (sink sprayer) and a toothbrush to clean my filter.
Remove any debris from the sump/ drain area. Reassembly is reverse of installation. Be sure to flush out the arm assembly to unblock all holes before re-installing it.
I hope this helps.
Feb 16, 2009 | Maytag MDB9600A Jetclean II Built-in...
Washer fills with water and stops
Could be 2 things.
Best of luck :)
Jan 14, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
Displays ld
Hi, how are ya?
Could be 2 things.
Thanks for using Fixya
Oct 16, 2007 | Kenmore 27032
Washing Machines Logo
15 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
