Question about Motorola Mobility RAZR V3
Unable to charge
When I connect my razor v3c to the computer, it displays Unable to CHarge. on it. I've tried using different USB cords but it still does the same. can someone help me?
    Brigadier General:
  • 7,752 Answers
Try a travel charger and see if that is charging it...if that does not help the problem you may need to change the charger port. or when u install it on the pc....check your device maanger and see if it has a yellow triangle which means that you may need to update the drivers for the computer to recognise it...hopefully you are using windows XP...if you are using vista that O/S is giving loads of problems.
P.S. trying loading on your MPT 4.0....if you do not have it you can download it for free online
Posted on Dec 21, 2007
My Sony Walkman NWZ-E344 not show anything to display. Display show only logo & i have connect pc then show "connected USB.the timer and Alarm will become invalid" pls solve this...
pls solve this problem?
Dec 21, 2010 | Sony Walkman NWZ-E344 Digital Media Player
My old Razr V3c, doesn't have service. Will not power on. I connect the phone to my computer via USB and a screen appears saying "Unable to Charge". There are priceless pictures on this phone which I would...
probably your units charging system is faulty. you could charge the battery from somewhere else then put it back and see. direct battery charging can also help boos a battery especially if it has stopped charging due to a very low battery.
Oct 25, 2010 | Motorola Mobility RAZR V3c Cellular Phone
It wont charge
Your battery has gone out most likely. Take it to the retailer and ask them about a new battery
May 01, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Get pictures off razor phone
use either the bluetooth connection or use a USB data cable and Mototools.
Feb 14, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Razr will not charge with wall charger
Your charger is faulty. If your phone is able to charge off of other sources (computer, car charger, another wall charger) Then, the charger needs to be replaced. Some mobile companies have a 90 warranty on accessories like the charger and battery. Then the mobile manufacture (Motorola) has a 1 year warranty on the charge and battery. I would check on that, and get those replaced.
Feb 04, 2009 | Motorola Mobility RAZR V3c Cellular Phone
Recharging batt. on emerson mp3 digital media player
if your mp3 player comes with a usb charge cord and has no bulge in the cord, such as would contain some kind of voltage modification electronics, then it's ok.
   the reason is: both the motorola charger and the usb port are  5 volts, all usb is 5 volts standard, and the motorola charger is labeled 5 volts right on the unit itself.
    The the only possible problem would be if the motorola charger was wired differently. However I have been using my razor charger to charge my Emerson 2GB mp3 player w/no problem.
    Plug in the charger with the mp3 player powered up, you should see the battery icon filling up just as if you were using the usb charger.
    if you are still to worried to try it , then get a voltage meter and test the polarity (weather positive and negative are the same on the motorola charger as the usb cord when plugged into the computer.
Sep 04, 2008 | Audio Players & Recorders
My Razr V3c will only turn on when plugged in to Charger or computer
Sounds like the connections to the Batteries are worn down or dirty try cleaning with alcohol...
Mar 20, 2008 | Motorola Mobility RAZR V3c Cellular Phone
Mobile Phone - Flip
"unable to charge", "insert sim". is your phone been dropped or got wet? if unable to charge, when using a wall charger, try different outlets. if using onl one charger, tr different chargers. if it won't work, try other compatible batteries if you would get a charging message. if does not work, have your phone checked with a service center
Sep 01, 2007 | Motorola Mobility RAZR V3c Cellular Phone
Motorola Mobility RAZR V3 Logo
85 people viewed this question
Top Motorola Mobility Cell Phones Experts
vince
D. E. Hev
Steve Berry
Level 1 Expert
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
