Question about Hotpoint Ultima WF860 Front Load Washer
Error F01 Hotpoint unlitima WT940 are you able to fix this problem yourself? If so please tell me How!! MANY THANKS!!
I have the same problem the machine gets part way through a cycle and then stops and Displays F1.
Posted on Jul 30, 2010
How can i fix my hotpoint wt940 with F-01
Hi Hayley,
Please help us help you. Expand on what is working and what is not. SO please add to your comments and repost.
First things first. Water is always a hazard with electricity. Please turn of the power source to your machine and do a fine cleanup, Take canister vacuum and get the hard reach places. A large box fan will help dry the machine and the floor. Pull the machine away from the wall. If possible lift the top off the machine to allow air flow and a panel cover for examination. a hair dryer can be used to dry electronic components in the event of an overload. Give it a chance.
If the machine restarts and is faulting. Here is a link to diagnose the coding Error Codes Hotpoint Service
F01 - Short circuit motor triac*
Here is a place for an online repair manual Free Online HOTPOINT Washing Machine Repair Manual
Here is the Hotpoint manual conversion site Download Manual Hotpoint Service
It appears you may need a new module if the cleanup does not clear out the code
http://www.ukwhitegoods.co.uk/help/fault-codes/laundry-fault-codes/3336-hotpoint-first-edition-hvl-series-washing-machine-and-washer-dryer-error-codes.html
Fare. Well.
Jan 05, 2015 | Hotpoint Washing Machines
Hi I have a Hotpoint WM D940G washing machine and after selecting the wash cycle needed nothing is happening. Then after a short time it is saying on the display No water check the supply if you then...
For most Indesit (Hotpoint and Ariston) models 'F01' often refers to the 'motor triac- check connections' but for a number of faults apparently poor PCB connections are often the cause so try this/these first. If you are not electrically confident and competent yourself, which you appear to be, you need to employ the skills of a partner, friend or service engineer ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
May 19, 2011 | Hotpoint Ultima WF840 Front Load Washer /...
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
What does a fault F01 signify on a Hotpoint Ultima 7kg washing machine?
Error code F01 indicates a short circuit motor triac.
Thoroughly check all connections on the motor, the motor plug, and the electronic module board..
Look for a broken wire, or a bad connection.
Please rate my solution.
Thankyou.
Jan 22, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error message F-01 & flashing lights etc I have a Hotpoint aquarius, WMF740. Suddenly returning to the kitchen I noticed an error message - the machine was switched off - which says F-01 and flashes...
You need to check connections on the motor, the motor plug and the module.
Having said that, you really should ring the manufacture, as the washer is still obviously under guarantee, and should be fixed at no cost to you.
The point to bear in mind is that if you do anything to it yourself, then in theory, you could invalidate the guarantee.
So, unless it is anything obvious, then I would advise you ring the manufacturer.
Hope this is of assistance to you.
Thankyou.
Dec 21, 2009 | Hotpoint Washing Machines
F-01 error hotpoint WMD960P
Error code F01 is indicating ashort circuit motor triac.
Check connections on motor the motor plug and then control module.
Thanks.
Nov 17, 2009 | Hotpoint Washing Machines
WHAT IS FAULT F01 ON MY WASHING MACHINE WF860
F01 indicates a short circuit motor triac, this is part of the motor speed control, either in the motor, or the control unit, and as such is something you cannot repair yourself.
It means that you will have to call hotpoint unfortunately.
If it is under 5 years old, then you should be able to get it done under the 5 year guarantee.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Washing Machines
Error code f08 on Wt940 ultima.
not sure if this will help but try:
First empty the machine by lowering the hose at the rear to ground level into a container. Take off the white plastic cover on rear at bottom. You will see black rubber hose connected to barrel of machine in right hand corner. Undo the silver screw on the band securing the hose. (Biggest band). You can now pull the hose down to reveal a "table tennis like" ball. Lift it out carefully and you will probably find an obstruction like a coin or similar. I found a hairgrip but it was enough to stop the ball functioning. DO NOT TAKE OFF THE WHITE HOSE CLIPS
Comment by pulmicort, posted on Feb 02, 2008 Further to my comments re clearing scrap from table tennis ball after code F4. Machine started ok but then F5 came up. Had to take the pump off and apart to reveal broken hairclip actually seized in pump. If you are handy at all this is simplicity itself.
Slide pump to left and lift and it comes clear. Take off 2 black hoses only where connected to main machine. Pull off electrical connection. Pump and hoses lift out easily. 3 screws open the pump. Clean any obstruction and reassemble. A 30 minute operation.
Apr 02, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Ultima WF860 Front Load Washer Logo
614 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
