Question about Ovens
Does a moffat oven need a 30amp cooker socket or is it ok on a 13amp plug
  • mickndebs Oct 07, 2009
    the oven is from wicks the number is 193014 it says on the plate that 1850watts 12.5 amps hope this helps
  • Obertelli
    Obertelli May 11, 2010
    What's the exact make and model? Alternatively what is the power rating on the device's data plate?
  • 379 Answers
Unless your talking about one of those tiny, table top ovens, dont use a 13 amp socket / connection.
An electric oven must be connected via a 30 amp SUPPLY - the socket is just the connector at the end of the cable that runs from the fuse / breaker board. A 30 amp supply will use a much thicker cable capable of handing the higher currents.
Whilst a very basic oven may draw less than 13 amps current when operating in some modes, most will draw well in excess of this depending on what facilities they have, e.g. bake and grill at the same time, or maybe a combi-oven - one that can bake and microwave at the same time.
Posted on Oct 03, 2009
Testimonial: "cheers you have helped alot"
In a rental property we have a 13amp socket above a free standing gas cooker, on ordering a new cooker the installer refused to fit until the socket was removed.is this correct?
There is no 13 amp receptacle. It was 15 amp and need to be changed to correct size and the wiring must be adequate. call electrician, do not do yourself.
May 10, 2018 | Ovens
Moffat oven doesn't heat .The elements don't turn red
Check the oven fuse. If that's OK, unplug it from the power supply. Remove the screws holding the element to the oven and pull it carefully back away from the oven wall. Connect your VOM test leads to the 2 terminals (meter set to at least 250Vac). Make sure the leads are not touching any metal parts of the oven and they are not touching the element. Plug oven in and turn the oven on. Do not touch the oven during testing. Reading 220 - 250 Vac power is OK. Element is bad. Reading lower then 220 or none at all no power getting to element, need more testing to find the problem. Be careful, and use common sense when working with and around electricity.
Feb 05, 2015 | Moffat Ovens
Wiring up
  • If it is a single oven attaching a 13amp plug and connecting it to a socket is fine. If it is a double oven it needs to be connected to a dedicated cooker circuit from your fuse board via a cooker control switch with 6mm twin and earth cable.
Apr 02, 2014 | Ovens
Diplomat integrated oven- 13amp?
You need to get an electrician to wire it in to a 30amp cooker outlet. It is 30amp rather than 13amp (like most sockets). It should go to its own fuse in the fuebox
Feb 22, 2009 | Belling XOU592 / XOU593 Electric Double...
Installing a B1641 oven
Providing it is just a single fan oven on it's own. then it will work fine from a normal 13 amp socket.
If it is a double oven, then it will have to be hard wired into a cooker control switch box, protected with a 30amp circuit trip or fuse.
Please rate my solution to your query.
Thanks.
Feb 19, 2009 | Neff B1641 Single circotherm super...
Belling fan assisted ovens
no you can't connect a double oven to a 13a socket!!
needs a proper cooker outlet wired back to the consumer unit
Sep 29, 2008 | Belling XOU592 / XOU593 Electric Double...
Problem with oven on Moffat Program Gas Cooker
Sounds to me like the oven thermostat has gone.
Dec 30, 2007 | Moffat Ovens
Ovens Logo
136 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
