Question about Black & Decker Leaf Hog Blower Vac With Leaf Collection System
Machine emitting sparks - Black & Decker Leaf Hog Blower Vac With Leaf Collection System
  • 437 Answers
It sounds like the motor is going bad. If it is electric, it may be time for a new one. If it is gas powered; It may be time for a engine rebuild.
Posted on Oct 03, 2009
"Print Mechanism"
Cinda:
When the paper is picked up by the pickup roller the paper crosses a sensor that tells the machine that the paper has fed from the tray. The sensor is an infra-red light emitting diode and an infra-red receiver placed in a small plastic "U" shaped body so that the light emitting diode and the receiver are looking at each other. It is located in the throat of the paper path (where the paper first enters the machine from the tray. A plastic "tab" (sensor flag) sticks up in the "U" to tell the machine that there is no paper in the path. When the paper was pulled out from the front of the machine, the "tab" (sensor flag) was either displaced from the sensor body (U) or it was broken off by the paper, so now the light emitting diode can be "seen" by the receiver and the machine thinks that there is paper in the paper path. If you know someone who is mechanically inclined,k they can remove the cover from the machine and either reposition the sensor flag into the sensor body, or if it is broken off, glue the sensor flag back together.
Good Luck
Sep 09, 2012 | HP Officejet Pro 8500 Wireless All-in-one...
How to check faulty 6 volt coil
pull the coil wire from the dist cap attach a spark plug to the coil wire make sure the plug is grounded. attach a jumper wire from the - side of the coil turn key on. touch the jumper to any good ground. then remove the jumper from ground every time you do this the coil should emit a spark from the plug if no spark the coil is bad if the plug sparks the coil is good
Mar 26, 2012 | Cars & Trucks
My built-in microwave, 2001 build UMC5100ADW emits sparks from behind cardboard panel. Suspect magnatron, or maybe metal deposits in cardboard. Looking for a replacement to fit the frame...
That "Cardboard" item is a wave guide cover and is critical part of the machine.
It is made of mica and needs replacing. The magnetron is OK as long as it does not spark too much or get any foreign items in there.
Replace the wave guide cover.
Feb 27, 2011 | Maytag Microwave Ovens
The bottom half on the RCA D52W19 has been removed and the Flyback on the Back right corner emits a noticable spark when attempting to turn the television on. Is this a flyback problem? Or is this a sign...
this is the flyback. it is not uncommon for this part to be bad and spark. Now it is common if this part is bad then the horizontal output transistor is shorted. this part is located directly in front of the flyback on a large heatsink.
Oct 12, 2010 | RCA D52W19 52" Rear Projection Television
I have a Sharper Image GP Hybrid model 1724. I cleaned the pull out blades and the inside of the unit. When I turn it on, the needs attention light comes on almost immediately. How can I get the machine...
i found a solution to the sparking problem in the ionic breeze. purchased scotch brite cleaning pads from home depot. using a long strip of pad scrub the plates back and forth especially in the areas that seem to be emitting sparks. i did this and the unit runs quiet as a whisper.
Jul 05, 2010 | Sharper Image Hybrid GP (SI724) Air...
10-12 year old dacor 4 burner epicure cooktop --left front burner
Here is a tip that I wrote to help people troubleshoot problems with their cooktops not igniting.
Cooktop Range Stove spark ignition does not work
http://www.fixya.com/support/r5649407-cooktop_range_stove_spark_ignition_not
heatman101
May 29, 2010 | Dacor Epicure ESG366 Gas Cooktop
I have a VBB vespa scooter 1961 it wont start after a full engine rebuild
check:
- is gasoline in the tank?
- is there a spark emitted at the spark plug if held to the cylinder while cranking the engine.
- is the headlight lighting up while cranking?
use a starter-spray in the air intake
Vespa 150GS VS5 spark check
Apr 10, 2010 | Peg Perego Vespa Scooter
My Simpson Sirocco 3500 clothes dryer emits burning smell!
1)check for something stuck between drum and dryer housing 2)check for stuck vent flapper at exhaust opening outside 3) check dryer lint screen
Nov 05, 2009 | Dryers
Smoke emitting from engine and runs sluggish.
how fresh is gas? maybe carb issues, look in gas tank is there stuff floating in bottom? if yes carb is clogged with dirt
Jul 06, 2009 | Garden
Black & Decker Leaf Hog Blower Vac With Leaf Collection System  Logo
107 people viewed this question
Top Black & Decker Garden Experts
Nick Olsen
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
