Question about Dell 1720dn Laser Printer
Drum has been replaced but lights and warnings still advise that drum needs to be changed.
  • Mike S
    Mike S May 11, 2010
    Check the manuals instructions, sometimes you have to reset the drum replacement , be sure you replaced the drum not the toner. I am not sure if these come all in one.
Open the front door then press the X button until all the light flash.
Close door
Posted on Oct 14, 2009
Why is the drum error message on after new drum installed and won't print
Hello, you need to reset the Drum Unit life:
After changing a DR2000 drum unit in a Brother HL-2040, the printer's page count needs to be reset. This will turn off the drum warning light on the printer.
Simply open the front cover, and hold the "GO" button until all four LED's are lit. Release the "GO" button and close the front cover.
Jul 28, 2014 | Brother HL-2040 Laser Printer
Why it prints grey background
Either the toner cartridge is very close to empty or the drum unit needs to be replaced. Check your warning lights. Yellow = toner, red = drum. If no warning lights, pull out the toner/drum unit and remove the toner cartridge. Have a look at the cylinder in the drum (DR2125) - if it is very black and matt looking you will need to have it cleaned or just replace it.
May 20, 2014 | Brother HL-2170W Laser Printer
How to replace a R1 drum cartridge on a xerox 7545?
The entire 57 series from Xerox is one of the friendliest units for operators there are on today's market. To replace the drum module you simply need to unlock and drop the tray which is attached to it below the drum unit, then swing the locking arm to the unlock position and remove the old drum. All the drum replacement kits come with an instructional showing you how to remove the shipping material from the new drum and then simply replace drum into the copier and return locking arm and relock the lower tray to bottom of drum frame and shut the door. It's that easy.
ONE THING TO KEEP IN MIND: NEVER, and I mean NEVER touch your fingers or hands to the drum surface. The natural oils in your skin can cause damage to the drum surface. Be very careful when installing the drum to ensure that nothing touches the actual drum surface.
SECOND WARNING: Drums are LIGHT SENSITIVE! NEVER leave a drum exposed to office light or any other light source for more than 5 minutes. If you need to stop your replacement procedure, make sure you cover the drum with a dark black garbage bag or some other source that can completely stop the light from reaching the drum.
Mar 30, 2013 | Xerox WorkCentre 7525 7530 7535 7545 7556...
Even after changing the toner, its shoing the drum unit warning
this warning is for replacment of drum, not for toner.
so please replace drum unit and resset drum counter with the help of installation docs available with new drum unit.
Apr 18, 2011 | Toshiba DP80F Printer
Drum light is on
This usually means that you need to replace the drum on the printer. Most likely it's under 10%, because that's when the warning light comes on. Depending on the printer, you may have 50-150 pages before it completely fails. I would advise to get it replaced soon.
Reminder: A drum is NOT the toner. It's normally a device that may house the toner. Or a separate part.
Apr 02, 2011 | Brother Office Equipment & Supplies
The attention light is staying on. Drum Life warning came on. All drums replaced. Attention light and drum life warning still on.
When replacing drums you have to have the printer off first, so the drums will reset. The best way to do this is to contact Rich @ www.summitechnologies.com; ricardop@uninetimaging.com you can get the fuses cheap, and you will have to take apart the drums and replace the fuse, expect an hour or two to do this.
Dec 14, 2010 | OKI C5500n Printer
E-Studio170F drum warning changed drum and still get warning
You need to reset the drum count on the machine. To do this press [MENU], [5], [2], [04] then when it says reset drum count use the up or down keys until it says yes then press enter.
Jul 27, 2010 | Toshiba E-Studio 161 Copier
Alarm says replace drum soon. Can the message be
The "replace drum soon" indicater is a warning for you to have a new replacement drum "on-hand". Soon the display will change to "REPLACE DRUM" AT WHICH TIME THE UNIT WILL STOP PRINTING.
When the new drum cartridge is then installed...the REPLACE DRUM indicator will be reset. DO NOT replace the drum before the machine says to.
Jun 04, 2010 | Muratec F320 Plain Paper LED Fax
Xerox FAXCENTRE 2218 Drum Warning displays on
Often times with that machine, if you replace the drum before it says replace, it will not reset.
Jan 04, 2010 | Xerox FAXCENTRE 2218 18PPM FAX
Brother HL-5240 drum light flashing
Normally clearing the drum count the machine has to be on open front cover as if to change the drum press and hold the button in for about 10 second then release and shut the door. This should reset the count if not please get back to me and I'll check the service manual to see if anything in that.
Thanks J
Jan 29, 2008 | Brother HL-5240 Laser Printer
Dell 1720dn Laser Printer Logo
214 people viewed this question
Top Dell Office Equipment & Supplies Experts
Electro Med Services...
color wheel light...
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
