Question about RCA DRC8030N
2200mf 6.3Volt caps for the RCA DRC8030n DVD recorder where do I find them and what is the cost per cap , looked in my unite and two of the caps are swelled up.Heres my email address seadevil_179@yahoo.com
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 106 Answers
I have plenty of spare power boards so you can replace the whole board vs. components. I can have one shipped at $10 plus shipping.
Posted on Oct 16, 2009
  • 6 more comments
  • mavrickmjs Sep 06, 2010
    Guru RCA, I could use one of those power boards also mavrickmjs@juno.com
  • fatcatken Sep 18, 2010
    GSAN, I could use 3 of these boards. 3 units = 3 bad power supplies
    kepeck@gmail.com
  • bunnthebody
    bunnthebody Sep 26, 2010
    Do you have a power supply left? My electricity flickered and now all i get is hello.
    roge1@crockettnet.com
  • Gerson War
    Gerson War Sep 26, 2010
    sorry for the delay. You can paypal $17 to goguerra@miners.utep.edu and please specify what board and shipping address and I will have it sent to you ASAP
  • Gerson War
  • Gerson War
    sorry for the delay. You can paypal $37 to goguerra@miners.utep.edu and please specify what board and shipping address and I will have it sent to you ASAP
  • Gerson War
  • Gerson War
    Also, try swapping the DVD drive with another known good one (any PC IDE drive will do) to make sure it isn't the DVD drive that is causing the Hello. They tend to burn out first.
When I set the record mode the unit record one minute time and reset again one minute more and again and again.
Posted on Jul 28, 2010
  • 458 Answers
The DVD is not recording at all.
if it has a harddrive, that can become full and you need to delete using remote control.
Mar 04, 2016 | RCA drc8030n dvd recorder w/80gb hard...
I NEED POWER SUPPLY BOARD FOR DRC8030N
I am sure that the fault was relative of the bad capacitor and swapping the working board has proved. Hope that solves the issue as all what is needed is to check and replace all the suspected capacitor is the Primary /Secondary side as the SMPS is working BUT with a limited voltage. So the threshold is low and so can be a tank capacitor, change the mains capacitor and also the secondary +B side.
Dec 02, 2011 | RCA DRC8030N
2200mf 6.3Volt caps for the RCA DRC8060n DVD recorder where do I find them and what is the cost per cap , looked in my unite and two of the caps are swelled up.Heres my email address seadevil...
All the capacitors with that value and at least that voltage will due, all you need to check is that it will fit in that space.
For better resilience in the future get ones rated at 10 volts - less than $1 per piece at any hobby shop.
Oct 03, 2009 | RCA DRC8030N
Noise coming from DVD player and it will not work
This is due to the mechanics inside the DVD-RW being out of place.  If you open the DVD-RW (take both the top and bottom cover off and take the CD tray out) you will see the white plastic guide that guides 2 arms as the laser mechanism lowers and raises.  One of these 2 arms is out of place and need to be pushed back in.  Also, check for a crack in the black plastic on the arms....this usually causes the arms to slip out of place.  If a crack is found, simply super glue it tigether.
Jan 27, 2009 | RCA DRC8030N
I want to find a replacement for DRC8030N
you can replace the DVD-RW yourself with any computer DVD/DVD-rw drive.  You will need to modify the way it sits in the unit as the screw holes will be different and some drilling will most likely be needed to make new screw holes.  Finding an original replacement DVD-RW for this unit will be hard because the first problem that this unit has is a constant HELLO message due to a faulty DVD-RW, so they are in high demand.
Jan 13, 2009 | RCA DRC8030N
Programing my drc8030n remote to the tv
Try looking! Here, for example:
http://remotefinder.rca.com/default.aspx?site=rca
or http://www.thompsontv.com/rcarc.html
Sep 30, 2008 | RCA DRC8030N
RCA DRC8030N Problem
This is due to the DVD-RW drive that is in the unit. This is the first to fail and RCA seems to have gone with the lowest bidder on this model. The DVD-RW drive will need to be replaced. If you used the DVR to watch and burn DVDs then you will need to replace it with any computer DVD-RW but you may need to re-drill some holes to have the replacement drive fit exactly aligned with the DVD door. If you only want to use this DVR for the internal hard drive recording and TV viewing, then any CD or DVD computer drive will do, just simply connect the replacement drive and leave it in the case (you wont have access to the DVD or CD drive under this option). If you do replace the drive, make sure you match up the jumper on the back so that it will be in the same position as in the original DVD drive ( the Master setting). I hope I did not scare you with all this information, but unfortunately, the dreaded HELLO issue with the DRC8030N has no easy fix.
Jul 09, 2008 | RCA DRC8030N
RCA DRC8030N
These units have flaky TV tuners. Try connecting the coax cable (the one with the cable television signal or antena) to the back of your TV first and from there take the output to the input of the DVR. By doing this, you will beusing your TVs TV tuner vs the DVR's flaky one.
Mar 13, 2008 | RCA DRC8030N
Rca drc8060n
BTW - I did open the unit up, and my hunch is that it is a power supply issue. Also, the DVD drive appears to be a standard 5.25" IDE drive made by Philips. It might be worth salvaging for use in a PC if drivers and/or firmware exist for it.
Oct 19, 2007 | RCA DRC8060N DVD Recorder
RCA DRC8030N Logo
471 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
