Question about JBL Duet Computer Speakers
How can i open my speaker JBL duet?
I've a problem with my speakers, so i wont to open the left speaker but after removing the two screws under the speaker i can't open it! there are other screws? or can i force it?
Sorry for my English!
  • corsairdared Oct 03, 2009
    I've solved my problem, visit my blog
    You can use google translator to translate on your language!
  • pumpz Jul 02, 2013
    thank you veeeeeeery much!
4 Suggested Answers
rylee_smith
  • 8619 Answers
SOURCE: Where can I find JBL platinum series speaker drivers?
Hi!
The kind of speakers usually don't effect what drivers you have to use. If you have your motherboard cd then you can install the sound drivers from that cd. And, if you still are unable to find them in the cd then please tell me the model no. of your PC(and/or model no. of the motherboard).
Please rate this solution as FixYa if found useful.
Thanks Rylee
Posted on Feb 20, 2009
  • 3 Answers
SOURCE: driver jbl pro speakers
I use these speakers since 2000. It will be 9 years this October!!! They work very good. I never used any drivers for them. I changed three computers with different mother boards / sound cards and they worked fine with any Sound Manager I tried.
Posted on Jun 28, 2009
SOURCE: JBL spot series speaker not working.
I know this is old but just incase anyone has the same problem. Its proabably the connection from back panel to the internal amp (Inside the sub enclosure). The ribbon cable has the + for the left speaker right at the edge with quite a bit of tension. Over time and with the vibrations from the sub this will bend/pull out slightly and needs to be pushed back on and some hot glue put around the connection to hold it in place.
Thats how I fixed mine anyway.
Posted on Feb 22, 2010
How Dismantle jbl on tour
First you need to remove the sliding door. You can do this by opening it and lifitng one side with a screwdriver like on one of the pictures.
After that you can remove the battery cap and batteries.
Than you will need to remove the JBL logo. This is quite tricky. because it is glued.
After that you can remove all the torx screws and open the device.
http://imgur.com/a/Czyat
I damaged mine because I didn't have proper tools. Fixed the speaker though.
Aug 12, 2012 | JBL On Tour Computer Speakers
How do I open DUET - 2.0 COMPUTER SPEAKERS BLACK
You need to gently prise off the front speaker grill. You could use a blunt pen knife to do this. After you remove the grill You will see 4 additional screws at roughly each corner of the front panel. Unscrew them and then you can use the pen knife once more to prise apart the speaker housing. Prise the housing apart from the top because two base pads hold both halves together at the bottom. I hope this helps! :)
Feb 06, 2012 | JBL Duet Computer Speakers
Hi I want to open the case of my JBL on Tour, but I dont know how to. I need to troubleshoot inside to fix this sound problem. Kindly help me.. Nikka
Its pretty late for your post....but today i repaired my jbl on tour...
there are 7 screws to be removed. 2 on thre front upper side, remove the battery cover an you find the first two. then remove the jbl sign, theres another under it. its very hard to remove, i had to destroy my jbl sign. now you have to clip out the cover when you have slided it back, under the back side who was covered, are the last 4 screws. now the nasty part is coming: you cant open it, cause its glued all around. put at first a knife into the slot betwen the upper cover & the under cover, move it around the jbl on tour, but watch out that you damage no electronic parts, or cut off the battery cabel (as i did ;) ) and now you can open the device. my jbl looks really bad after, but it works fine (had issues with the current cable)
Feb 28, 2011 | JBL On Tour Computer Speakers
I have a pair of JBL Duet speakers and 1 doesn't work unless the volume is maxed out on the other.
mcdevito75 here, Try to increase the volume from your keyboard, Then adjust the volume at the speakers, there should be only 1 volume control on 1 speaker to control them both, also check your connections at both speakers.
Jul 17, 2010 | JBL Duet Speakers, White Computer Speakers
When I plug in JBL duet 11 speakers to my computer I have no sound
Make sure the power supply is plugged in and getting current. The speaker plug on most computers is usually green.
Feb 26, 2010 | JBL Duet Computer Speakers
Disassembling the speakers - Compaq Jbl Pro (401508-001)
pry the speaker cover slowly using small screw driver on the side,,it has four locks giong thru..its position two at the top and two at the bottom..it is line w/ the volume control and headset..be careful not to break the speaker cover.then remove the four screws inside the hole where the speaker cover is position.remove also the rubber protector beneath the speaker or under the speaker..it has a lock beneath the rubber covering it..push the lock slowly, be careful not to break it.but even if you break it,it will do nothing..now insert finger in the hole and pull the face or pry w/ small screw driver and lift...
Apr 15, 2009 | HP Compaq JBL Pro (401508-001) Computer...
Replacing the diaphragms on the eon power 15
Yes - Simply face the speaker down - unscrew all of the screws (don't forget to remove the handle and the 2 under it) - once they are all lose, carefully stand the speaker upright and gently pop apart - as it is opening you will need to disconnect some wire harnesses and will need to undo the ground wires. DONE
Apr 07, 2009 | JBL EON 15-G2 Powered DJ Speaker With EQ...
How to open the jbl radial micro speaker set?
Bit late! Just remove the four rubber feet underneath (self adhesive). Take out the four philips screws. It's a bit of a mess inside - you'll have to remove the connectors and some screws to get to the i-pod connector. You dont need to remove the button pcbs just the main board. The i-pod connector pcb is on the end of the grey ribbon cable connected to the main board (the button end of the unit).
Nov 22, 2008 | JBL (JBLRADIALWHT) Speaker System, Docking...
Jul 12, 2008 | JBL Spyro Computer Speakers
Speakers not working
If you have another computer or a friend, test them on his/her computer. Try this, as its fixed such a problem for me in the past. Start>All Programs>Accessories>Entertainment>Volume Control Then check the ticked/unticked boxes
Aug 02, 2007 | JBL Duet Speakers, White Computer Speakers
JBL Duet Computer Speakers Logo
863 people viewed this question
Top JBL Audio Players & Recorders Experts
Michael Edwards
Michael Edwards
Level 1 Expert
 Grubhead
Grubhead
Vito Vacirca Jr.
Are you a JBL Audio Player and Recorder Expert? Answer questions, earn points and help others
