Question about HP Color LaserJet 4650DTN Printer
To install a 500 sheet paper tray for hp laserjet 5 printer
How to install a 500 sheet paper tray for HP laserjet 5 printer
  • jerry42 Dec 21, 2007
    I just received this 500 sheet paper tray for my HP laserjet 5 printer but don't know how to install it (I think it is to sit under the 250 sheet tray) thanks
  • Anonymous Mar 18, 2014
    Remove back tray on HP LaserJet 3035
  • HP Expert
  • 141 Answers
Make sure you reboot the printer after doing so or the printer will not recognize the new tray 3 assembly.
Posted on Oct 11, 2008
  • 26 Answers
Just put your printer on top of your 500 sheet paper tray ( printer sit just on top of it )
then you have to go in your propertie menu ( on computer)
look for the accessory tab , and check for 500 sheet paper tray ( tray3 )
et voila !!
Posted on Jan 11, 2008
How to fix error printer 2055 laser jet has massege output bin is full
there is a small flag sensor in the output tray over the roller that deliver the printed paper , its not return down after paper get out. so the the printer scene the tray is full , check it may lost if not try to lubricate the support pour it hasn't spring it move to its weight. or it may
Nov 12, 2014 | HP laserjet 2055 series 500 sheet paper...
HP Laserjet 2430n printer won't see the paper in Tray 2. Continues to give in display paper size *letter and *plain but I set it and it just comes back asking again. When you print it won't pickup from...
Yes I checked the tray throughly. I also changed to paper to legal plain and changed the configuration...still came back on the display panel change paper size...just won't stop asking.
If I put the add-on paper tray 500 sheet that tray works fine.
I was thinking though I might order another paper tray and try it since I replaced the pickup assy and still have problems...what do you think
I also cold reset the printer just in the event something was set wrong...still has problems
Oct 15, 2010 | HP LaserJet 2430tn Printer
My hp laserjet 9050 show paper jam when the tray is empty
(1) dose it work ok when you install paper.
(2) when it runs out of paper it dose not a sheet going through it so it gives that code .If its still works dont worry about it should be fine.
Aug 13, 2010 | HP LaserJet 9050 Printer
What is the maximum paper weight allowable for the HP LaserJet 2840 printer? I am printing recipe cards but 4x6 or 3x5 cards are too heavy and the printer won't take them.
Handle a variety of business needs. Spend less time loading
paper with an input capacity of up to 375 sheets. A 125-sheet
multipurpose tray and a 250-sheet paper tray offer easy
access to a variety of paper finishes, sizes, and types,
including labels and envelopes, at weights of up to 47 lb
(177 g/m2) and HP laser glossy and photo papers up to 70 lb
(220 g/m2).1
Jun 08, 2010 | HP LaserJet 2840 All-In-One Printer
My printer will not pull paper from the manual tray. I am trying to print envelopes and postcards from the manual tray. Even when I select manual tray in the "paper source" field it will not pull. I think...
Check the Paper Handling Menu. The Tray 1 size and Tray 1 Type should be set to Any Size. This means that the printer should pull the paper from Tray 1 first when paper is loaded in tray 1
Oct 15, 2009 | HP P4515TN LaserJet Printer with 500 Sheet...
My laserjet 1020 develops a paper jam after printing the first page of a multipage print instruction .I have deleted the printer and re-installed it including all drivers but problem still...
Reinstalling the printer is related the Software.
If the paper gets physically jammed than its the driver setting issue or hardware issue.
Check if two sheets get jammed or only one sheet.
If it is two sheets than printer is picking up multiple sheets and paper gets jammed.
If the printer is jamming a single sheet than remove the Tray and look there is rubber roller inside if there are marks or lines on that rubber roller or if the roller roller is worn out than that rubber roller called as paper pickup roller need to be replaced.
If that looks fine than try to priny using manual feed and if the problem persists from manual feed too than try another toner cartridge
If the problem is not from Manual feed Tray that Replace the main Tray with known good Tray and check if the issue resolved.
Jul 01, 2009 | HP LaserJet 1010 Printer
Hp color LaserJet 3700 jams 70# uncoated letterhead stock
Hi manitou344:
Here is some info that might help you.
Table 1-8. Tray 1 paper sizes1
Media Dimensions Weight or thickness Capacity
Minimum size paper 76 by 127 mm
(3 by 5 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
(75 g/m2; 20 lb bond)
Maximum size paper 216 by 356 mm
(8.5 by 14 in)
60 to 163 g/m2
(16 to 43 lb bond)
100 sheets
Minimum size glossy
paper
76 by 127 mm
(3 by 5 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
height: 12 mm (0.47 in)
Maximum size glossy
paper
216 by 356 mm
(8.5 by 14 in)
75 to 120 g/m2
(20 to 32 lb bond)
Maximum stack
Minimum size
transparencies2
76 by 127 mm
(3 by 5 in)
0.12 to 0.13 mm thick
(4.7 to 5 mils thick)
50 sheets
Maximum size
transparencies2
216 by 356 mm
(8.5 by 14 in)
50 sheets
Minimum size
envelopes
76 by 127 mm
(3 by 5 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Maximum size
envelopes
216 by 356 mm
(8.5 by 14 in)
60 to 90 g/m2
(16 to 24 lb bond)
10 sheets
Minimum size label 76 by 127 mm
(3 by 5 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Maximum size label 216 by 356 mm
(8.5 by 14 in)
75 to 163 g/m2
(20 to 43 lb bond)
50 sheets
Minimum size
cardstock
76 by 127 mm
(3 by 5 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
Maximum size
cardstock
216 by 356 mm
(8.5 by 14 in)
135 to 216 g/m2
(43 to 43 lb bond)
50 sheets
This printer can
detect transparencies that were not designed for use with HP Color LaserJet printers.
Jun 30, 2009 | HP Office Equipment & Supplies
Hp 2200 laser printer tray 1 paper delivery from top
Are these printers designed to handle Legal sheets?
Did you tell the Printers Software that you will be sending Legal size sheets to this printer?
Apr 10, 2008 | HP LaserJet 2200dn Printer
Paper Tray
The paper tray is a non-repairable item. HP replaces them outright.
Jun 12, 2007 | HP LaserJet 5000n Printer
HP Color LaserJet 4650DTN Printer Logo
253 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
