posted by happybuck on Dec 21, 2007
Hello.
I'm, unfortunately, pretty clueless as you'll see...
The humidifier is 3.5 years old. I noticed it wasn't running. Opened it up (after unpluggin) and see a filter/frame piece which is caked with dried white build-up.
Is this a replaceable filter which I should purchase, install and then turn back on the system or should I call a technician for service?
2 Other Users Have The Same Problem
Comment by imcj, posted on Jan 20, 2008
My Hunter Carefree Plus 34357 will not go to the percentage of humidity that I set. I moves 1 or 2 % then will go no further.
Comment by Guest, posted on Jan 01, 2008
I need to get a new filter, or absorption sleeve, can you direct me in the right way?
Solution #1
posted on Dec 29, 2007
First of all the white build up is hard water residue. If you haven't replaced the filter in 3 and a half years you NEED to replace it. They have a safety switch may not be satisfied because of your filter.
Was this solution helpful? Show your Appreciation by rating it:
This Problem Also Relates To:
Honeywell HCM530 Humidifier
Honeywell HCM-640 4 Gallon Humidifier
Honeywell Cool Mist HCM890 Humidifier
Honeywell DH-805 Humidifier
Honeywell DH830 Humidifier
Honeywell EWM-350 3.5 Gallon Humidifier
Honeywell Cool Mist HCM6011 11 Gallon Humidifier
Can you Help with these Humidifiers problems?
Kenmore 14410 Humidifier
quiet comfort humidifier not...
I can't get my humidifier to... Answer This...
Bionaire BCM6010 Humidifier
BIONAIRE BCM630 TOWER...
All of a sudden, the fan will... Answer This...
Air-O-Swiss 7133 Humidifier
air o swiss 7133 doesn't send...
I cleaned it and then noticed... Answer This...
Crane Penguin 1 Gallon Humidifier
Crane Penguin 1 Gallon...
I lost my manual to my new... Answer This...
Repair Service
Find Humidifier Repairman Near You:
