Question about Brother MFC 420CN All-In-One InkJet Printer
Empty Ink message
My printer said it was out of yellow ink. Bought a new one (not generic) and replaced it. Printer still says ink empty to reinstall ink cartridge. Have done so many time but still says empty.
  • 832 Answers
Try this 1# :
If you still have trouble:
unplug machine from power. Open cover and take all carts out of position. Plug machine to power again by connecting it to the wall socket. Wait until machine has done start up. When finished power on machine (if it has shut down first). Machine demands carts. Place each demanded cart into position and make sure it is secured. Answer lcd display questions. Close cover. Machine will run a cleaning cycle and come up stand-by.
If you still have trouble after that procedure, use another ORIGINAL cart. (Most brother printer  trouble is because of diffrent construction of generic ink carts and due to wrong ink).
And if there still is trouble have a look at the led control circuit board built in the cart holder it should look this:
Posted on Dec 21, 2007
  • Mix-it-up
    Mix-it-up Dec 21, 2007
    The circuit board should be in palce like shown in the pic. Otherwise it has to be corrected by opening the printer and fixing it. If it is OK there might be a short circuit due to splashed ink!
False ink empty
Are you sure its exclamation mark?..
This warning message related to print head. (warn out). When you are replacing ink tube assembly use dummy print heads to do the priming (new ink tubes are empty & they have to fill with ink)..
Action: Remove all cartridges and print heads, switch on the printer follow the screen message.(Insert cartridges first next dummy print heads).once its recognizes cartridges then it switch over to print heads,insert dummy print heads. Once printer recognized the dummy print heads, printer will perform priming, during priming dummy print heads will filled with respective inks.(follow the display message)Remove dummy print heads & insert normal print heads. Wait till printer recognizes print heads, load the paper & wait till performs the calibration, once calibration is successfully done issue closed.
If calibration not successfully done, check align print out for which print head is not printed properly, replace it..
Pl ensure that minimum 50% ink levels required in cartridges before performing the priming. Best of luck..
Dec 03, 2012 | HP DesignJet 500 InkJet Printer
I replaced an ink cartridge because the printer stopped working and showed a message that the old cartridge is empty. However after putting the new one in but the printer still refuses to work and shows...
maybe the cartridge is wrong, release it and clean the electrical contacts, put them again one by one, if notting happen, try this
Solution As the printer operates, it moves ink from the ink cartridges into a printhead reservoir. The printer does not deliver a message when an ink cartridge goes empty, because it still has ink in the reservoir. The printer continues printing until the ink level in the reservoir falls to a first trigger point - then a message appears advising the printer owner to Replace Cartridges Soon . At this point, other cartridges that are empty but have not reached the trigger point are also mentioned in the message, to save trips to the retailer. After the first trigger point, the printer can continue printing until ink levels in the reservoir reach a second trigger point. At the second trigger point there is only enough ink left to perform vital servicing tasks, and a new message appears, saying Ink Cartridges Empty . The options offered depend on the usable inks remaining. If no options are offered, the cartridges indicated must be replaced before printing can continue. The Ink Cartridges Empty options are described in the table below: Ink colors out Option Print mode possible All Cancel None Black
Cyan, Magenta, or Yellow (any or all) Black only Continue with other colors Cyan/Magenta/Yellow mode (composite black)
Text and photo quality will differ from those printed when all colors are available Light Cyan or Light Magenta (either or both) Cyan, Magenta, or Yellow (any or all)
(Black still available) Print with black ink only Grayscale
Apr 07, 2010 | HP Photosmart 3210 Printer
Ive replaced black ink cart but it doesnt work,still the message check ink u163 on th LCD.thank you
Either the new ink is a generic cartridge and not reset properly, or one of the other inks is empty. Your display should tell you which ink is empty. U163 just says that one of the inks is empty.
Feb 05, 2010 | Canon PIXMA MX300 All-in-One Printer
Epson CX3900 says all cartridges empty but not true
Did you use Epson Genuine Cartridges?
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
Also go thru the utility to change cartridges. This will make the chip know that you have all new cartridges and will move the ink station in place.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Feb 04, 2010 | Epson STYLUS CX3900 All-In-One InkJet...
Printer thinks cartridges empty
Unplug your printer from the computer and then the power supply. Remove the inks from the printer. Plug the printer back into the computer first then connect the power supply. Install the inks "very slowly" one by one and then check the levels, they should now read full. Thank you, Dana
Nov 06, 2009 | Brother DCP 115C All-In-One InkJet Printer
Windows Ink Cartridge Empty false error message.
slowly off and on the printer for five times without cartridge, printer saves data of cart of last 5 only so next time it reads full ink..
Oct 28, 2009 | HP C6280 All-in-One Printer
Changed yellow ink to new cartridge. Printer won't recognize.
I contacted the Brother site, the support function there. Pursuant to what I found there, I unplugged the printer for ten seconds and replugged. The message display then told me that cyan was empty, and that magenta was near empty.
I installed a new cartridge in place of the empty cyan, and that fixed it.
Jun 04, 2009 | Brother MFC 420CN All-In-One InkJet...
Printer cannot detect new yellow ink, the near empty message on
The Ink sensor sounds like it needs to be replaced. This happens from time to time.
Feb 12, 2009 | Brother DCP 115C All-In-One InkJet Printer
Message: "Ink empty black" --won't reset
this could be because of generic ink carts which do not have the size of the original ones. If so put some paperstrip beneath the cart to lift it up a bit.
Anyway, did you tell the printer that you have changed the cart by pressing 1? Look at the display when you insert the cart!
Feb 24, 2008 | Brother Multi-Function Center MFC-240C...
Ink empty yellow error message even after ink has been replaced
the mechanism on the cariage is faulty. It cannot be repaired by you the user.
Jul 08, 2007 | Brother MFC 420CN All-In-One InkJet...
Brother MFC 420CN All-In-One InkJet Printer Logo
James Cagle
James Cagle
Jim Keysor
