Cant install new 1gb pc3200 memory into my chaintech apogee 9pjl motherboard. as soon as power is turned on, i either get a constant beep or a neverending intermitant one. please help.
  • 329 Answers
Try another RAM or try this RAM in other system also chcek for compatibility
Posted on Oct 03, 2009
    Problem Solver:
  • 17 Answers
Either the ram is bad or not compatible with that motherboard.
Main Memory Four 184-pin DDR DIMMs up to 4GB
Supports Dual-Channel DDR266/333/400 memory
This is what I found with a quick search. If you have other ram installed, it may not be compatible with the new stick. Try taking out the other ram. Try the new stick. It worked? The ram is good, just won't jive with the others. Doesn't work? May be bad or wrong for that board.
  • 15 Answers
Some memory brands are not compatible with some motherboards. Go to the motherboard web page and check it for the kind and brand of memory you can use.
Does D915GLVG support DDR2 ram
Hello, I am the technician that will be assisting you today. My name is Norman-Wynne Damstra.
Welcome to Fixya, Anish Nitin.
Unfortunately your Intel D915GLVG only supports DDR memory up to a maximum frequency of 400MHz. It also supports 333MHz frequency as well.
Therefore the maximum/fastest is DDR400 also called PC3200. In those days when the memory was manufactured they made 1GB modules.
If you would like to upgrade this computer install 2X DDR400/PC3200 1GB memory modules.
Take care!
Dec 16, 2011 | Intel D915GLVG Motherboard
I have an emachine T5026. Emachine tech swears this machine only supports pc2700 ram but the stickers on the factory installed ram says pc3200 256mb x 2 so i bought 2 memory masters pc3200 1gb x 2 sticks....
PC3200 is backwards compatible with PC2700. Meaning you can install PC3200 into your motherboard but it won't run any faster than would PC2700, however it will not cause any harm and should work fine.
Emachine's would say you need PC2700 most likely because they're trying to sell you some.
One of your new memory modules or the memory slots on your computer may be defective. I recommend installing a single stick of memory and booting your system. If it is successful then shut it down, disconnect the power and install another stick. Boot again and keep doing so and by process of elimination identify the bad memory stick or the bad memory slot.
This is the "likely" cause and isn't too uncommon.
Good luck.
Sep 07, 2010 | E-Machines eMachines Desktop PC
How to link case wires on the mother board? I've lost the manual and i don't find any stuff on chaintech website...
hi
  • Locate the case connector pins on your motherboard. This will be a bank of two rows with 10-12 pins in each row. Each pin will be about 1 cm in length.
  • Step 2 Locate the power lead behind the power button on your computer case. The lead will consist of two thin wires, usually white and black, held together by a small plastic cap.
  • Step 3 Examine the underside of the power lead for an arrow or dot. If one is present, the marking signifies the first pin. This must correspond with the first pin on the motherboard, which will also be indicated by an arrow, dot, or number. If no markings are present, the lead can be installed in either orientation.
  • Step 4 Place the lead over the power pins within the pin bank. The correct pins will be indicated by a diagram on the motherboard, or by a picture in your motherboard's instruction manual.
  • Step 5 Connect the power cable to the back of your computer, and turn the computer on.
  • Jun 30, 2010 | Chaintech 9PJL APOGEE Motherboard
    Hi I also have a P4m800-M7 rev 3.1 motherboard and a 512mb of ram.. my question is, is it okay to put another ram but in 1gb size its pc3200, will it work? thanks!!
    The motherboard supports 2GB maximum memory. 1x1GB in each slot.
    Maximum clock speed is 400MHz (PC3200), so the memory module you have should work fine.
    Please remember to remove the power cord before installing the new ram.
    Regards.
    Nov 25, 2009 | EliteGroup P4M800-M7 Motherboard
    Try to install 2gb ddr memory on MS-6741 motherboard
    pls check you motherboard manual if it accept that kind of memory because some board cannot accept.
    Jan 08, 2009 | MSI K8MM-ILSR Motherboard
    New ram
    Memory type is the major problem with the 741GX chipset. Very touchy. I used Crucial PC3200 High Density memory to start with (2 x 1 gig Memory), system was lagging even though adjusted settings in bios. whenever a USB device was pluged in, the system would stop responding. Switched to low density memory and no problems since (Ultra PC3200 (2 x 1 gig Memory), and the USB device problem is also solved. I am running WinXP with SP2.
    Jun 02, 2008 | EliteGroup 741GX-M Motherboard
    Upgrading ram
    Hi reisrui, yes it is odd. (It's not the first time I have seen this.)
    According to you're manual on page 6, under Specifications. The manual say's you can run up to a Max speed of PC3200 400MHz, 1GB in slot one. In slot 2 you can run a Max of 1GB of PC2700 333MHz in slot 2. Every motherboard I have come across that can run two different speeds of memory. The system will reduce the Max speed to the lower MHz memory speed. If you currently are using 512MB PC3200 400MHz in slot 1 & add 1GB of PC3200 400MHz into slot 2 for a total of 1.5GB of memory. The motherboard will ruduce the total memory over all speed to PC2700 333MHz. Motherboards alway run at the lower memory speed if two different speeds are presant.
    I can’t be 100% sure of the 1GB of PC3200 400MHz into slot 2, will run at all! Or if it will be reduce down to 333MHz. I am sure you can run 2GB of PC2700 333MHz, 1GB of memory per slot in you're board for a total of 2GB.
    If I can help you further, feel free to post.
    Suggestions & comments welcomed.
    Mike
    May 27, 2008 | Asrock 775VM800 Motherboard
    Wiring Diagram
    Browse this site Chaintech.com and Shopzilla.com,all types of motherboards from chaintech is there..
    Goodluck!! =)
    Jan 15, 2008 | Chaintech 9EJL1 APOGEE Motherboard
    RAM upgrate
    you can upgrade to a max of 2gb on that board. These are your 1gb options: 1GB PC2700 333MHz DDR Memory, 1GB PC2100 266MHz DDR Memory, and 1GB PC3200 400MHz Non-ECC Unbuffered 184-pin DDR DIMM Memory. Install a set of any of these and your off and running.
    Dec 22, 2007 | FIC P4M-800T Motherboard
    Computers & Internet Logo
    158 people viewed this question
    David Payne
    David Payne
