Question about Electrolux Washing Machines
How to change door seal on electrolux ewf1087 frontloader
My electrolux EWF1087 is leaking water from the front door, I cannot see any damage on the door seal although I never noticed its folded over and full of dirt. Do I need a new seal ?
Posted on Mar 05, 2011
Hi I have a Electrolux Ewf1087 which will not fill up, I have replaced the solenoid valve, but it still will not let water in the machine , can anyone please help??
I would check ur water pressure switch next but Im thinking ur control board is mis communicating with the inlet valve , check with a meter
Jun 16, 2015 | Electrolux Washing Machines
Why Electrolux front load making knocking sounds during spin cycle. Model ewf1087
Good Morning Friend,
I understand your Electrolux washer, model# EWF1087, is making knocking sounds during the spin cycle. In researching your model number, I show that your appliance was manufactured in Australia. If this were manufactured in the U.S., I would suggest making sure that the load was balanced. Balance your wash load and if you are still having trouble, I suggest contacting the manufacturer in Australia. Hope this is helpful.
-Best Regards-
WP
Jun 22, 2014 | Electrolux EW1200i Front Load Washer /...
Electrolux has power does not work with no LED display
Sounds like you need a new electronics main panel or interface if seperate - plus an investigation into why it failed. Don't just buy a new part and fit it - it might blow up again and the supplier wont accept it back if it does.
Consider age of machine before booking an expensive repair call
Sep 20, 2017 | Electrolux Washing Machines
Electrolux Eco Valve EWF1087 washing machine,will not programme?Won't accept Quick wash cycle, then stops halfway through
8 November, Today I picked this model off the footpath, yet to set it up I hope it works LeonZ -Reservoir, Vic.
Nov 05, 2011 | Electrolux EW1000i Front Load Washer
My ewf1087 has the tub locked, as if an emergency brake has been applied or something and now it dosnt rotate freely by hand and when it tries to go into a spin cycle or move the tub at all it sounds like...
You have something jammed in the tub cavity - like a sock, or pants etc. Caused by overloading the machine. You will find it very difficult to remove, as the gap is very narrow. If you are lucky, you may see it jammed up the side of the door seal, but may need to dismantle the machine to get it out. If its a nail or screw stuck, its probably wrecked the machines tub or heater. Try removing the water heater and looking inside carefully with a torch - sometimes you can remove obstructions with a long piece of wire with a hook on - maybe! lol Or try removing the door seal - but good luck getting it back on again!!! very difficult unless you have tried this before.
Dec 15, 2017 | Electrolux AWF 1435 Front Load Washer
ELectrolux frontloader EWF1090 door wont open
Make sure you drain the machine first by setting a spin cycle manually and see if it releases the door after a few minutes. If that fails then switch off the machine and leave for 5 mins, door should release but you could end up with water on the floor. After this clean your filter and check you water pump, then try a short cycle without clothes.
Apr 11, 2009 | Electrolux Washing Machines
Washing Machines Logo
1,044 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
