Question about Olevia LT42HVi 42 in. LCD Television
Olevia LT42HVi - Need to toggle power switch on back of TV off/on all the time
We have an Olevia LT42HVi TV connected via Verizon FIOS. Almost reotuinely, the TV will not power on or off via the remote OR the Power button on the front of the TV. If you simply, toggle the on.off switch on the back of the TV udner the power cord, the TV power and remote then work. Is this a fuse problem that requires a technician call? I tried swapping out the Power strip and also just plugged the TV directly into the wall. No differrence. The TV is 14 months old.
  • 1 more comment
  • Anonymous Dec 26, 2007
    I just had a similar issue, it seems my TV during use will just turns itself off for no reason.  I can get it turn back on but it seems the color is starting to go as well.
  • drgamble Nov 09, 2008
    Siliconchip, can you tell me do you have to just remove the outside back cover only to get to the connector terminal that you speak of that may be loose?
    Thanks.
  • jeffjohnson1 Nov 10, 2008
    I had the same problem, then progressed to shutting off, and when repowered via toggling back power button, all settings were messed up.....way off scale: color would be funny, brightness, etc.....some set to 268 on a scale of 0-100 (don't know how this is possible but it was), color screwed up and parental control set to all on meaning only G shows would play.  after about two months of this, the screen has gone completely dead.....only switches between black and blue screen, about once every 10 seconds or longer.  Sears can fix nor get parts, Olevia has been no help other than to say they "might" be able to rebuild the tuner box (if that is what it is) to the tune of $300-$400.  The TV was just out of warranty.  I would steer clear of anything from these folks in the future.  I paid $2100 for this when new in Jan 2007.
I have not had the entire back off of my tv, but will do so tomorrow. my "board" box simply slides into a slot with the connector at the back of it. There seems to be no problem with the "fit" and the connection seems secure. I have plugged and unplugged this box several times thinking the same thing...wondering if it was a bad connection. However, I have not messed with the other plugs in the back. I think that the plug in the upper left is for the LCD screen itself. I did see that one and it looked fine on my set. Because of similar problems I have read about on other sites and from what the "factory" service center told me, I suspect my problem is not a loose connector, but I can't go wrong by checking since I don't have anything now. Thanks for the advice. I will let you know how it turns out.
Jeff
Posted on Nov 11, 2008
Well, yesterday I took the back cover off and looked around, had no idea what i was doing but happened to notice a wire harness near the upper left hand corner of the set that looked like it was partly unplugged, so i of course plugged it in snugly, put the cover back on, and, I also toggled the on/off switch just below the power cord and it came on and has worked fine ever since. Don't know for sure if any thing i did solved the problem, only time will tell but so far so good.
Posted on Nov 10, 2008
  • 52 Answers
You swapped the power strip. How about swapping the cord with another. Most LCD and Plasma TV used a cord similar to the cord use for the power supply of PC (IEC line plug). If still it doesn't work. Time to open the back to access the connector terminal which came loose (Due to heat) if not soldered directly to the power supply PCB. Just pinch the spade crimp, better still solder it. Make sure to lay the TV flat, face down on a smooth surface table if you're repairing it yourself.
Good Luck.
Posted on Dec 29, 2007
I have an Olevia 226-s11 that shows the Olevia screen when powered on but no picture thereafter. Sound works, but no picture.
Back-light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 12, 2015 | Olevia Televison & Video
My husband bought me your DVD Recorder Model No. DMR-EH75V for Christmas in 2006. It worked with my analog TV and a COMCAST cable box. In April 2007, I bought an Olevia HD TV and changed to a Verizon...
Due to certain limitations of the Panasonic DMR-EH75V, it can only accommodate composite Video INput and give composite Video OUTput as well as the standard Audio L/R. Additionally, if your Verizon FIOS HD cable box has an RF OUT, that can also be connected to the RF/CABLE IN of the Panasonic.
Please refer to the simplified diagram below.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Mar 19, 2008 | Televison & Video
Olevia television won't turn on unless you unplug the power cord from the back and plug is back in
One of the buttons has flattened out try the remote first and see if it will pop up, if so replace remote. Then try the one on the TV itself which is more likely...that one will require a new PC board with the buttons on it.
Jul 23, 2014 | Olevia LT42HVi 42 in. LCD Television
TV not turn on
Clear all Power,disconnect wait 15mins.re connect to power source.Hold the power button till picture is on..IT WORKED FOR ME''
Jun 07, 2010 | Olevia LT42HVi 42 in. LCD Television
Where is the fuse on LT42HVI please ? The power
It should be located where the end of the power cord come in. Look at the power supply for component with label such as F1.
Nov 11, 2009 | Olevia LT42HVi 42 in. LCD Television
Now have verizon Fios and cannot get DVD player to play
Check the connection cable. If the Verizon box and the DVD player are connecting to the same TV input, ensure that the Verizon fios box is connecting to DVD input, and DVD output is connecting to TV.
If you connect DVD out to Verizon box input, and then TV , you will have to turn off the receiver box to see DVD.
If you use only one TV Input connect Verizon output to DVD input and DVD out to TV.
If instead you use separate inputs on TV, then try using the source/select input button on TV remote, and try different cables.
Regards.
Jul 25, 2009 | Sharp DVMX1U DVD Player
HDTV goes blank when connected to Fios HD-DVR or Fios DTV recvr.
If you can first connect the Fios box via component and that will rectify the issue and still allow HD. HDMI is funny, if there is anykind of communication issues between the TV or the Fios box you see what happens. You might also call Samsung to see if there is ANY firmware/software updated for your TV specifically to fix such an issue with the Fios/Mortorola connection. If there isn't then the issue is the cable box since the TV works ok on HDMI with other devices.
Jul 23, 2009 | Televison & Video
I have an olevia tv model number 542-13-11 and it will not turn on. Any suggestions would be appreciated. lindafranks@hammondhenry.com
do you get a blue light on ? if you do that means you have power so..it could be the main-board is bad on the television. But if you have no blue light on the front of the television then you have no power. You could try switching the power switch on the back of the television several times and see if you get any type of blue light on the front of the tv. If you don't then try connecting the power cord to a power strip or straight to the wall.. if you still don't get power try disconnecting the power cord from the television overnight and then plug it back in and see if you get any sign of power.. if still no sign of power then the television power supply is bad and will need to be replace or repair..
Since the manuf. of OLEVIA is out of buss ..you have this 3rd party repair center that is able to provide you with a repair quote call this number 866-965-3842 the company is called Amergence Technology who is able to repair and service all OLEVIA HDTV products..
Jul 21, 2009 | Olevia LT42HVi 42 in. LCD Television
RCA tv with FiOs
my fiance fixed it. he has this really expensive remote that he programmed via a USB port and some fancy fingerwork that I can't even begin to explain :D and I was able to change the channel back to 00
Jan 20, 2009 | Televison & Video
Zoom Function and Verizon Fios TV
On the verizon FIOS tv box, turn the FIOS STB on, and turn on the tv, tap the following buttons on the Verizon FIOS STB )in this order) 1-Power, then Select, then Menu. This will bring up the FIOS STB HD options. Arrow down to 4:3 Bypass and set the bypass option to 480P. Hit power 2 times, once to turn off, second time to turn STB back on. This should on standard channels give you the zoom feature back. This worked on my Samsunf 5053 TV model.
Apr 30, 2008 | Samsung HP-S5053 Television
Olevia LT42HVi 42 in. LCD Television Logo
952 people viewed this question
Top Olevia Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Jaime Hernandez
Are you an Olevia Televison and Video Expert? Answer questions, earn points and help others
