Question about Nikon D60 Digital Camera
My camera does not autofocus - Nikon D60 Digital Camera
    Problem Solver:
  • 12 Answers
Check if you have any of following issues
1. Lens is not AF or AF-S
2. Try flicking the lens switch from A to M and back to A again, might solve any contact issues
3. In the menu system also you can navigate to select the manual or auto focussing. if this got set to 'Manual' mode by mistake the camera will not autofocus even if the lens switch is in Auto mode.
Posted on Oct 04, 2009
  • 77 Answers
Something you have to understand, auto focus mechanisms work on the basis of measuring contrast.
What that means in English is that there have to be clearly identifiable lines or surfaces that can be discerned by the camera. If that is not available the camera can't focus and at night you can count on it that you won't be able to focus for that reason.
This is not a Nikon problem, it's a problem with all auto focus mechanisms of any brand.
What I'd suggest you consider is to focus manually. That immediately solves your problem. Alternately, try to auto focus on some other object that is about the same distance away, then hold your shutter button half way down, compose your shot and finally take the picture.
I hope that helps a little. Good Luck
Posted on Jan 14, 2010
On a 645n, does the autofocus not work unless film is loaded first?
You're posted in Instant Cameras. More likely you need help with film camera.
Oct 14, 2014 | Pentax 645N Medium Format Camera
Is adding grip for nikon d5100 solve the problem of auto focus with sigma 170-500 lens
No. This lens lacks an autofocus motor, relying on the camera to have one. The D5100 lacks an autofocus motor, relying on the lens to have one. Adding a battery grip does not change this situation.
The D5100 only autofocuses with lenses having an internal autofocus motor. Nikon designates such lenses AF-S, Sigma calls it HSM. Lenses without the motor will only autofocus with the larger and heavier Nikon cameras such as the D7000.
Nov 27, 2012 | Polaroid Wireless Performance Battery Grip...
I have a AF Nikkor 70-210 which I use with a DSRL camera. But I want to buy a analogic one. Should I buy an AF one, or the lens will still full working (including the autofocus) with a manual one, like a...
The lens will work with any Nikon film SLR, including the FG-20. However, the FG-20 is not an autofocus camera. Whether the lens is capable of autofocusing or not, you'll still have to focus manually. With a newer autofocus camera, such as the N75 and N80, the lens will autofocus.
Mar 13, 2012 | Cameras
Which Nikon S.L.R. cameras can I use my 70/300mm AF-S Nikor and still maintain auto focus, it is currently on a D40x
Every one (assuming the camera supports autofocus in the first place, of course--old film Nikons didn't). The lens has an autofocus motor, so the camera doesn't need one.
Film Nikons supported autofocus starting with the N2000. (Actually, the F3 also had autofocus capabilities, but used a different system). All the digitals support autofocus.
May 15, 2011 | Nikon Cameras
Just bought a new eos d600 . How do I turn on the autofocus?
Set the autofocus switch on the lens to AF. Press the autofocus button on the camera (right on the cursor pad) to bring up the AF mode. Use left/right or turn the command dial to select the desired autofocus mode and press SET.
It's in the "Changing the Autofocus Mode" in the manual (page 83 in my copy).
Mar 23, 2011 | Canon PowerShot SD600 Digital Camera
Hello - I am having an autofocus error issue.
Check the camera and make sure that autofocus is on on both the lens and the camera, if they both have switches.
Check the autofocus mode, whether it's single, or continuous. If it's in single, it'll only focus once per time you half-press the shutter release, continuous it'll continue to focus as long as your finger is down.
If that doesn't work, try another lens and see if the problem still persists. Otherwise, contact the manufacturer, as it could be hardware related.
Remember, cameras do not autofocus well in low light.
Mar 01, 2011 | Canon EOS 450D Digital Camera
Using a Nikon D40 digital slr with a AF-S DX Nikkor 18-200 1:3.5-5.6 G ED lens I was previously able to autofocus bun now am not. Can you suggest reasons why this may be?
Please check if the Autofocus-switch on your lens is set to M/A. Also check if the Autofocus on your camera is switched on. For detailed information about your cameras autofocus, please check this site: http://www.kenrockwell.com/nikon/d40/af-settings.htm
Jul 18, 2010 | Nikon D40x Digital Camera
Canon 40D Autofocus not working
Maybe The Button Is Broken Chek The Button If It Still does Not work Let an Axpert Chek Your camera
Sep 22, 2009 | Canon EOS 40D Digital Camera
I have the Nikon 18-200 lense and it will not autofocus on my D80. I tried other lenses on the camera and they auto focused, so I presumed it was the camera. I sent it for repair, received it after being...
Try you 18-200 lens on another Nikon DSLR. If it still does not Autofocus. It is the lens. Sometimes the electrical contact points of the lens are not making correct contact with the camera. ok?
Mar 05, 2009 | Nikon D80 Digital Camera with 18-135mm...
Nikon D60 Digital Camera Logo
305 people viewed this question
Top Nikon Cameras Experts
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
