Question about Seagate Barracuda 7200.10 500 GB SATA Hard Drive
I have a iomega harddrive and the computer is not recognizing it. It is also beeping. the power light is on and the cable cables are in and are connected securely.
  • 478 Answers
Wrong pin placment or failed drive
Posted on Jan 26, 2010
  • 329 Answers
See jumper setting also go to bios and disable native for sata....
Posted on Oct 03, 2009
Set up HARD DISK
http://www.ecs.com.tw/ECSWebSite/Product/Product_Detail.aspx?DetailID=106&MenuID=24&LanID=0
The ECS P6STP-FL motherboard uses IDE (PATA) harddrives, and optical drives. (CD/DVD drive)
IDE 1 is for the Harddrive.
IDE 1 is the 40-pin connector that is closest to the Ram Memory slots.
(Only 39-pin are used, however)
IDE 2 is used for the optical drive/s.
IDE 2 is next to IDE 1, and is further away from the Ram Memory slots.
The IDE connectors on the motherboard, have a Cut-Out on one side. A small square cut-out.
This is for the Locating Lug, on the flat IDE ribbon cable's, connector.
This makes sure that Pin 1 in the motherboard connector, is lined up with Wire 1 in the flat IDE ribbon cable.
http://en.wikipedia.org/wiki/File:PATA-cable.jpg
The Locating Lug shown in this example, is two 'ridges' that are separated. Some designs just use one solid block.
IF, there is no Locating Lug;
Look for the faint Red stripe, on the side of the flat IDE ribbon cable,
http://en.wikipedia.org/wiki/File:Nappe.svg
This stripe denotes the side, that number 1 wire is on.
Motherboard installed in computer case, the red stripe on that flat IDE ribbon cable, goes DOWN.
Down towards the Bottom of the motherboard.
When connecting to the Harddrive, and there is no Locating Lug on flat IDE ribbon cable, the Red stripe goes towards the power cable connection.
This applies to the optical drive (CD/DVD drive), and Floppy Disk Drive.
(34-pins for a Floppy Disk Drive. Cable is smaller in width)
Now, there is a different method of connecting a Harddrive, or optical drive, in relation to the flat IDE ribbon cable.
Depends on if the flat IDE ribbon cable is a 40-wire cable, or an 80-wire cable. You can use Cable Select setting on Harddrive/Optical drive; OR you can just connect the Harddrive, or Optical drive the correct way,
http://mikeshardware.com/howtos/howto_connect_ide_hd.html
Is the Harddrive recognized in BIOS Setup?
If your question relates that the Harddrive is not recognized, post back in a Comment.
Also post the manufacturer ID information off of the Harddrive's label.
Example for one type of Western Digital harddrive;
WD800AAJB
Western Digital 80 GB harddrive, and IDE (PATA)
With this information I can find the Cylinders, Heads, and Sectors.
Then guide you in entering it in BIOS Setup, IF needed.
"Press DEL to run Setup"
Press the Delete key to enter BIOS Setup.
AS SOON AS you press the Power On button, start tapping on the DELete key.
Tap in 2 second intervals.
You will hear beeps. These are Stuck Key Error Code beeps, and it is YOU that is doing it. Ignore the beeps.
Best method for entering BIO Setup.
(The window of opportunity for entering BIOS Setup, goes by F-A-S-T! The above method will get you in)
Your problem statement leaves a hole in the time/space continuum.
Does not exactly state what your problem is
For additional questions please post in a Comment.
Regards,
joecoolvette
Apr 26, 2013 | ECS Elitegroup P6stp-fl Motherboard Cpu...
Beeping noise when connected to tv
Beeping often indicates a power problem. Try a different usb cable.
Sep 04, 2012 | Iomega 500GB Prestige USB 2.0 Portable...
Trying to find the operators manual for prestige desktop hard drive super speed usb 3.0 ,2 tb
The general directions is to plug the USB cable from the IOmega Prestige into any available (Open) USB port.
To open, (Access) the contents on the harddrive, double-click on the drive letter that corresponds with the IOmega.
In WinXP left-click on Start, then on My Computer.
In Win Vista and Win7 left-click on the Windows logo button, then on Computer.
You will see there are different drive letters;
Drive A: is reserved for a Floppy Drive. Older computers
Drive C: is for the Harddrive. (Hard Disk)
Drive D: is reserved for a recovery drive, or an optical drive (CD/DVD drive)
Drive E: is reserved for an optical drive, usually.
Drive letters beyond these are usually under the heading, Devices with Removable Storage
One of these drive letters should correspond with the IOmega.
Suggest, IOmega not plugged in, go to My Computer, or Computer, and look at the devices connected to the various drive letters.
Now plug the IOmega in, and see if it shows up next to a drive letter.
(Give the computer BIOS a few seconds)
Where there was NO device shown BEFORE, there should now be a device shown.
{No device shown before, but now there is. May not state IOmega, just external storage, or similar}
DOUBLE-click on the device shown.
For example:
I have drive letters C: D: E: F: G: H: I: J: and K:
Drive letter C: is for my harddrive.
Drive letter D: is for a recovery drive. (Partition in harddrive reserved for recovery)
Drive letter E: is for an optical drive (CD/DVD drive)
Drive letters F through K are reserved for an external storage device.
Whether it be an external harddrive, or flashdrive, or what have you.
IF you find the drive letter that corresponds with the IOmega DOUBLE-click right on it.
If nothing happens, or if there is no device shown when the IOmega is plugged in, there is a problem with the IOmega.
Hard to believe IOmega is still having problems with their external harddrives.
In the past they were having problems with a small circuit board located inside the IOmega's case.
[ A circuit board is a PCB.
Printed Circuit Board
For example a computer mouse has a small PCB in it,
http://en.wikipedia.org/wiki/File:Mouse_printed_circuit_board_both_sides_IMG_0959a.JPG ]
The small circuit board is an Interface Board.
It connects the harddrive inside the IOmega's plastic case, to a USB cable, and this allows the harddrive inside to be plugged into a USB port on a computer.
As mentioned inside the plastic outer case (External enclosure) of the IOmega is a harddrive.
(Hard Disk drive; proper speak)
Harddrives are measure across their Width. There are two current types used;
A laptop size harddrive, and a desktop size harddrive.
A Laptop size harddrive is 2.5 inches across in width. (2 and a half inches, or 6.4cm)
A Desktop size harddrive is 3.5 inches across in width. (Or 8.9cm)
There are two technologies used;
IDE (PATA) or SATA
I'm sure the harddrive inside susanbrenton is a SATA unit.
I BELIEVE, it is a laptop size harddrive (2.5)
Point?
If there is data (Information) on the IOmega that you must have, you may wish to buy an inexpensive external enclosure, remove the harddrive from the IOmega, and install it into the external enclosure.
The external enclosure has a plastic case (Enclosure), and a small circuit board inside. It has a USB cable, or connector, just like the IOmega does.
Once you install the IOmega harddrive inside the case, the case is closed, and it's USB cable is plugged into a computer.
(Just like the IOmega. You are just replacing the small circuit board essentially)
Once you have the IOmega's case open, and can view the internal harddrive, measure the width of the harddrive.
Buy the appropriate external enclosure.
This is one example of an external enclosure for a 2.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=3195233&CatId=2783
This is one example of a external enclosure for a 3.5 SATA harddrive,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=2145406&CatId=2780
Basic instructions on how to open an IOmega Prestige external enclosure (Case):
1) There are two Philips head screws on the Back of the case.
These are removed.
Once removed a the oblong panel on the end comes off.
2) You can now see the harddrive inside. Pull from the Front, and remove the harddrive out of the case.
3) The harddrive is attached with screws to a metal carrier. (Bracket, essentially)
Remove the screws, remove the harddrive.
Basic example, the harddrive will look like this,
http://www.geeks.com/details.asp?invtid=0A26923-NDW-R&cat=HDD
For additional questions please post in a Comment, (Believe upper right of your page)
Regards,
joecoolvette
Oct 15, 2011 | Iomega Prestige 1 TB USB 20 Hard Drive
I have an iomega mdhd250-U external storgae device that for some reason has ceased to be "visible". It has always been connected through a USB port in my server but has just "disappeared....
I also have an iomega external drive different from yours and has a switch or a button. If you have that switch or button, please try to press it and see if it resets. If not we have two things to consider.
1. Try to use a different USB Cable and test. 2. Open the external harddrive and replace the disk with a spare one or working one. Then test if it connects. a. If it does not connect then the problem is the electronic board of the external harddrive. Buy a Harddrive enclosure so as you could still use and retrieve your valuable data. Or slave the drive on your desktop computer and see if its connect. b. If it connects then you have a faulty harddrive. I hope you have a backup of what you have there.
Jul 12, 2011 | Computers & Internet
Can not get computer to recognize hard drive any more?
You could try using another USB port on your computer. Perhaps that USB port you have the IOmega external harddrive plugged into is bad.
More than likely not, though.
The problem is usually inside the IOmega's case. (External enclosure)
Inside that IOmega external harddrive's case is a regular harddrive as used in a desktop, or laptop computer.
To explain;
Harddrives are physically rated in width, as well as type, and size.
A laptop harddrive is 2.5 inches across in width. (2 and a half inches)
A desktop harddrive is 3.5 inches.
The larger desktop harddrives are usually used in external harddrives that are 500GB, and larger.
(Not always the case when it comes to the 500GB size)
Harddrives have two technologies, or types.
IDE (PATA) or SATA.
You didn't state the Model Number so I can't even hazard a guess at this point.
The harddrive inside the case plugs into an Interface.
The Interface may be separate, and connected via a cable to a small circuit board, or the Interface may be soldered directly to the small circuit board.
It is this Interface, and circuit board which go bad.
The solution is to remove the harddrive inside, purchase an inexpensive external enclosure, and install the harddrive into it.
The external enclosure has a USB cable just like the IOmega external harddrive did.
As stated the harddrive inside is just a normal harddrive. Made by a harddrive manufacturer.
Could be a Western Digital, or Seagate, or Hitachi, or Maxtor, or Fujitsu, or IBM, just to name a few.
(Seagate bought out Maxtor)
On the harddrive will be a decal with it's specifications.
You will also be able to physically measure the width.
This external hookup will support harddrives that are 2.5, or 3.5 inches in width, (And 5.25), plus will support both IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7220658&CatId=3770
This external enclosure is for a desktop sized harddrive, 3.5 inches, and will support either IDE (PATA) or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1951866&CatId=2780
This external enclosure example is for laptop sized harddrives, 2.5 inches, and will support either IDE, (PATA), or SATA harddrives,
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=7041055&CatId=2783
Just one example of how to disassemble an IOmega Select Portable harddrive,
http://www.youtube.com/watch?v=NvUvz5Qb4vw
Other styles are listed in the Suggestions column down on the right.
Not a good source for information on disassembling an IOmega external harddrive, but there is very little info available.
(It isn't that tough for any external harddrive enclosure. The screws are usually hidden under labels, and the case pops apart in two halves. Just a little different design here, and there)
Regards,
joecoolvette
Jun 14, 2011 | Iomega Computers & Internet
I need a new internal power supply for my 2tb external its an Iomega prestige. I just want the part number for it so i can order a new one.
There is no internal power supply. The unit gets it's power from the computer. A USB port has 5 Volts DC.
Inside that external enclosure of the IOmega external harddrive is just an ordinary harddrive as used in a desktop computer. A SATA harddrive.
The harddrive plugs into a small circuit board with an interface on it, or there are cables, (wires), which come from the circuit board, and plug into the back of the harddrive.
It is this small circuit board that is usually the problem.
The solution to this problem is to simply just buy an economical external enclosure, and install the harddrive out of the IOmega into it.
Just one example from a quick search for an economical SATA 3.5 external enclosure,
(Note*
A laptop harddrive is 2.5 inches across in width. 2 and 1/2 inches.
A desktop harddrive is 3.5),
Have additional questions or need clarification to what I have stated, please post in a Comment.
Regards,
joecoolvette
May 29, 2011 | Iomega 2TB Prestige External Hard Drive
I have a white light on my iomega external harddrive. My computer does not recognize it. Is my data recoverable?
There is a chance that the only thing that isn't working on the external hard drive is the actual controller of the enclosure. What you could try doing is opening up the external hard drive to get at the actual drive that's inside. Go online and look for something called an IDE to USB adapter. They are usually relativly cheap, 10-20 bucks. This will plug into the back of the hard drive and then to the computer with a usb cable. See if the drive is readable. or if you have another open SATA port in your desktop computer, just try connecting it as a secondary hard drive. See if it will read it.
Mar 04, 2011 | Iomega 1TB Desktop USB 2.0 Hard Drive
Western Digital Harddrives // Win Vista two separate harddrives with same problem - once plugged in, lights on harddrives turn on, computer beeps but, doesnt recognize the hard drive. WinVista...
Uninstall the WD drivers, then, leaving the WD drives attached to the computer, reboot the computer.
Here is something else to try: Driver Booster by Iobit.
11 Free Programs That Will Help Update Drivers in Windows
And take a look at the software for your drives at the Western Digital site.
Aug 10, 2017 | Olympus Computers & Internet
My 500 GB will not turn on properly. I've tried rebooting a couple times, but everytime a solid red light comes on. If i try restarting using the Power button the redlight begins flashing. Trying to...
First make sure usb cable connected to harddrive is working fine.
try it in different usb ports.
Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers.
then check.
Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key.
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318}
And remove upper filter and lower filter.Then restart computer then check.
Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue.
Let me know if you need further assistance.
Thanks for using FixYa
Sep 13, 2010 | Iomega (33275) 500 GB USB Hard Drive
Iomega lphd160-u beeping
Your USB port does not have enough power to support the drive. You will need to use an external power source or try a firewire cable if the drive has that option.Travis Cable
Mar 29, 2008 | Iomega (33600) 160 GB USB 2.0 Hard Drive
Open Questions:
bricked hard drive? Would folling this lead to a full hard drive format or just unbricking a drive like people sat it does?? Also any other ways that might help would be great to know, heres what i'm talking about! "Fixing The Drive NOTE: Commands for you to type are in red boldface. Pay attention to upper & lower case - it is important. Turn on power to the RS232-to-TTL adapter and the hard drive. After a few seconds, Press CTRL+z. You should then see a prompt like this: F3 T> If not, swap TX & RX wires. Access Level 2 (type /2): F3 T>/2 (enter) F3 2> Then spin down the (disconnected) motor: F3 2>Z (enter) Spin Down Complete Elapsed Time 0.147 msecs F3 2> Very carefully, remove the cardstock that you placed between the PCB and the drive head contacts. Carefully replace and tighten the 3 loose screws. I suggest using a small piece of masking tape to help you hold the screws while you put them back in place. Then start the motor: F3 2>U (enter) Spin Up Complete Elapsed Time 7.093 secs F3 2> Next go to Level 1 (type /1): F3 2>/1 (enter) And do a S.M.A.R.T. erase (create S.M.A.R.T. sector): F3 1>N1 (enter) Cycle power to the drive, then do partition regeneration: F3 T>m0,2,2,0,0,0,0,22 (enter) After 15-30 seconds, you should see something like: Max Wr Retries = 00, Max Rd Retries = 00, Max ECC T-Level = 14, Max Certify Rewrite Retries = 00C8 User Partition Format 10% complete, Zone 00, Pass 00, LBA 00004339, ErrCode 00000080, Elapsed Time 0 mins 05 secs User Partition Format Successful - Elapsed Time 0 mins 05 secs Do not turn off drive until you see this message. Once seen, drive can be turned off. Power down everything, place drive back into your computer, and confirm that it's working." Thanks.
Apr 12, 2010 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Seagate Barracuda 7200.10 500 GB SATA Hard Drive Logo
169 people viewed this question
Top Seagate Computers & Internet Experts
Arora Singh
Arora Singh
Alun Cox
pankaj rautela
pankaj rautela
Are you a Seagate Computer and Internet Expert? Answer questions, earn points and help others
