By rotating the HOLD switch in the direction of the arrow given on back side, all the buttons are inoperable. If you press buttons while the HOLD function is activated, “HOLD” and the current time appears in the display. If you rotate the HOLD switch to the opposite position, the HOLD function is released or canceled.
Please rotate the hold switch on the back side of your mp3 player opposite to the arrow mark given there.
Please go through the user manual if you are having any doubts. manual
Originally, it would turn on and then when I pressed FM tuner or another button, it would shut off....
(More)
Originally, it would turn on and then when I pressed FM tuner or another button, it would shut off. Then when I tried to turn it on I was see flash really fast - format error. Those times I would see Walkman - creating datbase. Now it it doesn't want to turn on more than a second to show walkman that it shuts right off again. I do not have it on hold. It is fully charged. I have hit the reset button. I don't know what to do. I can't reformat it because it won't turn on.
la pc no reconoce algunas carpetas delmp3. las carpetas estan en el mp3 pero no accedo a ellas desde...
(More)
la pc no reconoce algunas carpetas delmp3. las carpetas estan en el mp3 pero no accedo a ellas desde la pc
Bonjour, j'ai un "Walkman" Sony (NWZ-B105F). Quand, je charge les Mp3s, ils se chargent...
(More)
Bonjour, j'ai un "Walkman" Sony (NWZ-B105F). Quand, je charge les Mp3s, ils se chargent sans problèmes et ils sont bien dans la mémoire de l'appareil. Quand je débranche de l'ordinateur et je mets sous tension, le walkman me dit "no data" mais les Mp3s sont bien en mémoire. S.v.p. me donner informations pour régler ce problème. J'ai hâte de profiter à nouveau de mon appareil. Bonne journée et merci. réponse à : mikejean1971@hotmail.com
Hai, I was using this USB Sony walkman in my PC. I was trying to format this. but it is showing...
(More)
Hai, I was using this USB Sony walkman in my PC. I was trying to format this. but it is showing windows cannot format it. i cannot view the data also. Help me to solve my problem. Give me step by step procedure. Should i re program it and what kind of software i should use it?
