Question about IBM ThinkVision L170 17" LCD Monitor
I have an IBM Thinkvision L170 showing only an all white screen. Anyone having schematics or suggestions on how to fix this? Brgds, Don P.
Replacing 7 bulging capacitors on the inverter PCB fixed the problem.
Posted on Oct 05, 2009
Can't adjust the color, brightness or contrast so that there is a pure white color. Can this be fixed?
yes you can. Go to Menu, and follow the steps for adjust the color, brightness ,etc or restore the factory default in Menu
God bless you
Jul 31, 2013 | IBM ThinkVision L170 17" LCD Monitor
I have an image with the flashlight, but no backlighting on my IBM 6734 lcd monitor
The inverter module is bad or the back light behind the LCD screen has stopped working, I would suggest an estimate if you decide to have it repaired.
Jan 22, 2011 | IBM ThinkVision L170 17" LCD Monitor
IBM Think Vision L170 Monitors. I have a couple with the same issue. Power them on, and the IBM logo flashes for a second, then a blank screen. The indicator LED is green. Powering off/on doesnt...
check for bulging capacitors on the power supply board.if any are bulged their bad.mine was blinking ibm logo i found 2 capacitors bulged i replaced those it works fine.
Sep 27, 2010 | IBM ThinkVision L170 17" LCD Monitor
My IBM ThinkVision monitor flickers the correct display then blacks out. The light goes green a moment, then goes amber with the blackout. I think it may be stuck in the Energy Star/Power Saver mode. Is...
skeltonh, Have you connected your L170 to a different "known-good" PC that has ALL power-save and screen saver modes disabled? Have you connected an old monitor to your PC to see if it will act same way as the L170? 12fixlouie
Jul 31, 2010 | IBM ThinkVision L170 17" LCD Monitor
17 lcd l170 black screen power on but no display
When powered-on, and *NOT* connected to a computer, most ThinkVision LCD monitors will flash, for a few seconds, the IBM ThinkVision "logo", before going into "power-saving" mode. If you don't see that, then it's time to spend about $120, and buy a new 19" (not 17") LCD monitor.
Apr 08, 2010 | IBM ThinkVision L170 17" LCD Monitor
LCD (IBM) monitor power light is green but no display
Make sure the monitor lead which goes behind the computer is in correctly and has not come loose.
Unscrew it from the PC and put it back in again.
Jan 06, 2009 | IBM ThinkVision L170 17" LCD Monitor
Ibm thinkvision l170 monitor
Hi! Tammy,
It's seems your new pc resolution settings, set to high...
Hook up to another monitor and go to settings to correct your
resolution to 1280x768 or less. That will fixed your problems.
Good lucks!
Aug 07, 2008 | IBM ThinkVision L170 17" LCD Monitor
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
IBM ThinkVision L170 17" LCD Monitor Logo
442 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
