Question about Samsung YP-K3JAB MP3 Player
My samsung YP-K3 couldn't turn on any more,it's locked
My samsung YP-K3 2 GB couldn't turn on any more, it always locked.
Without any reason...i can just press the "reset" button to trun it off before, but for now i can't really turn it on, the screen was showing that it's locked.
how can i solved this, plz help
    President:
  • 803 Answers
Try reflashing the firmware for your device you can find the latest firmware and flashing utilities from the Samsung's website. Make sure that you back your music up first because when you do this you are setting it back to factory settings.
Posted on Oct 05, 2009
I had exactly the same problem... it all seemed to be fine when connected to a PC i.e. could upload songs, battery charged & seemed fine etc. but when i tried to use away from the computer it kept showing the locked icon & NOTHING (using a pin to
reset the player @ the back, updating the firmware etc) made any difference...
I was just about to throw it in the bin and then i thought "hold on what it it's a purely mechanical problem? So i got a very small flathead screwdriver & gently open the unit up a bit (not fully, it looked like that might break internal connectors...) on the side where the hold button was. Took a bit of messing about - initially the hold button didn't work at all - re-jogged it and... ta-da!!!! It works fine now. I believe the hold button mechanism had simply lost it's footing with the internal contacts or something.
Anyway the player now looks a little battered - can't seal it properly - but at least it now works again, which is better than what was going to happen to it otherwise...
So, a bit risky (it might not work for you...) but better than just throwing it away - until this had happened i really liked my YP-K3 - now i'm not quite so keen on it but all the same it still works fine!
Hope this works for you, though i would suggest the other solutions prior to my one!
Posted on Oct 19, 2009
Samsung player reset my files?
Like most Samsung electronics, the software is the pits, yet the hardware is generally quite good.
If the Samsung YP-K3 MP3 player continues to act erratically, a reboot, or reset, may help. Resetting this device allows you to reinitialize your player without losing your files or device settings.
The Reset hole is on the back of the device, toward the bottom. Press one end of a straightened paper clip into the Reset hole gently. Then allow the Samsung YP-K3 MP3 player to initialize.
You may want to upgrade and if you have, this may be why the files were reset.
YP K3 SUPPORT SAMSUNG
May 18, 2014 | Samsung YP-K3 MP3 Player
Samsung yp-k3 says it is locked on the screen but i unlocked it what do i did
i get this problem all the time, put it back into locked position, then you ahve to really forcefully hold the button down, and unlock it, usually takes 3-5 go's but it does work, mine does it like 2-4 times a day
Jul 05, 2009 | Samsung YP-K3 MP3 Player
My KP-K3 won't let me download music from my pc.
WHEN I PLUG IN MY SAMSUNG YP-K3 MP3 IT SHOWS A LITTLE WINDOW U NEED A 2.0 USB BUT ME FRIEND BRUNG HIS OWN YP-K3 AND PLUG IT IN AND IT WORK WAT CAN I DO
Jun 01, 2008 | Samsung YP-K3 MP3 Player
Yp-k3
press the reset button on the back. then try it.
if it's still not working, lock it and press the reset button again. then unlock it. then try it.
May 23, 2008 | Samsung YP-K3 MP3 Player
Samsung YP K3 J Qb
hit the reset button at the back of the mp3 player..use a small needle to poke it..it will turn on..it wont erase any sort of data..it worked for me...
I wanted to know if there is anyway i can get an extra cable for this MP3 player since ive lost mine...thnx alot :)
Hope my suggestion works...worked for me
Mar 26, 2008 | Samsung Audio Players & Recorders
MTP Error
When the YP-K3 2 gb device is plugged into the USB Port, the system says "Found New Hardware, Samsung YP-K3" which then switches to "MTP Device" and then fails on an MTP error. It seems to be searching for a driver, and cannot find one. H E L P!!!!!
Dec 29, 2007 | Samsung YP-K3 MP3 Player
Mp3 wont turn on
what happens when you USB connect to your PC? Might help to reset it, if its a software glitch.
Nov 18, 2007 | Samsung YP-K3 MP3 Player
Samsung Yp-K3 is lock.. how can i solve?
I can unlock and lock my SamsungYP K-3 without any problem. So, heres how: you look on the right side and push down the side button!
Oct 11, 2007 | Samsung YP-K3 MP3 Player
Samsung YP-K3JAB MP3 Player Logo
413 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
