Question about Invicta 2608 Wrist Watch
I need a pin for wrist band - Invicta 2608 Wrist Watch
    Problem Solver:
  • 6 Answers
Go to a watch repair shop or juwler you should get one
Posted on Oct 03, 2009
Wrist band pins slip off easily
put a spot of super glue on the end of the pin befor you push them in
Jun 01, 2013 | Seiko SNP022P1 Wrist Watch for Men
Shorten the length of a Kenneth Cole "New York" watch band
With the watch on your wrist, check to see how many links need to be removed from your watch. Your watch should fit comfortably on your wrist. Remove the extra links with your paper clip or push pin.To remove the links from your watch, press on the small pins with your tool that are holding the links in place. The watch band should now separate allowing the pin to become free, and you can now remove the pins first and then the links one at a time until you have removed the desired amount of links. Reattach the watch band when you are done removing the links. To reattach the watch band to your watch, simply fit the end links into each other. To complete the resizing, use your push pin to re-insert a joining pin.
Jan 19, 2011 | Watches
Can't adjust the wrist band on citizec C651
Look where the band connects to the fold-over clasp. There are several holes on the clasp. Use a plastic headed thumbtack or some other small pointed object to push the pin in and move to desired hole to fit your wrist.
If the longest adjustment is still not big enough you will need to add a link to the band. You can contact Citizen Watch at 800-321-1023 they will send you 3 links at no charge.
Oct 21, 2010 | Citizen Skyhawk Eco-Drive JR306059F Wrist...
The rubber band broke on my seiko dive watch--unable to get the pins out without breaking them--any suggestions on removing the pins
mcdevito75 here, Best Bet, you may need a special tool to remove and replace the SPRING BARS (PINS) that hold the band onto the watch, then you may even need new spring Bars, (pins) to re-attach the band to rthe watch. BEST BET, look for a small watch repair shop in your area to change the band.
Jul 21, 2010 | Seiko SGF204 Wrist Watch
I have a women's kc1239 wrist watch. I've brought it to my jewelers to fix the pins near the clasp, but noticed the 2nd pin down from the watch face was broken, too. My jeweler said they cannot fix this...
I am sorry but u are going to need to replace the watch band, the jeweler is correct, did he suggest the correct replacement band, he should have a selection of bands that will work with this watch.
Dec 07, 2009 | Kenneth Cole KC1239 Wrist Watch
It's too small on my wrist I have the extra bands but I don't know how to add them
you will need sharp needle nose pliers and a small ering pin (the part that goes thru the ear) use your needle nose pliers and grabing the ear pin pushe the pin that holds one of your wrist band then finish pulling the pin with the needle nose pliers all the way add the extra band and insert the pin with your fingers first then finish with pliers
Oct 26, 2009 | Kenneth Cole KC3315 Wrist Watch
Skagen 596XLTXM Titanium Mens Watch
good morning ! you need a puncher pin and anvil to remove the pin on your watch band punch or push the pin use the puncher pin according to the arrow sign,full the pin to remove,and fush to fix again,do it carefully,thank you ! god bless .
Aug 27, 2008 | Skagen 355LGSC Wrist Watch
Band removal
There are two little pins on the strap. They need to be pushed to the side to release the strap
Dec 24, 2007 | Nike Triax 10 WR0006-001 Wrist Watch
Band adjustment
Use a pick tool and push the pins out the sides in either direction of the arrows.
Nov 17, 2007 | Fossil CH2331 Wrist Watch
Shortening the Length of a Metal Wrist Band
I just did this for my wife's new Kenneth Cole wrist watch rather easily. You don't need a screwdriver, but a short section of a paper clip will do. I just set the band on a raise surface to allow room for the pin to be pushed out using the paper clip. For this watch, one side of the pin resembles the slotted side of a small screw - but it is not a screw. This is the side that bulges up a bit to help the pin stay in place. I believe if you punch it out from the opposite side it will fall off quickly, but if you do from the bulged side it, too, will come out but with some resistance. To reattach the band you need to punch the pin into the slot in such a way that its bulged side is on top otherwise you may end up with a bent pin. You must also first line up the hole with the paper clip before reinserting the pin. Good luck.
Nov 06, 2007 | Kenneth Cole KC3289 Wrist Watch
Invicta 2608 Wrist Watch Logo
35 people viewed this question
Top Invicta Watches Experts
Ansel Alberto
Ansel Alberto
deton8 von Splosion
Are you an Invicta Watch Expert? Answer questions, earn points and help others
