Question about Honeywell HZ-690 Oil Filled Radiator Heater
Honeywell HZ-690 7 Fin Oil Filled Radiator Heater manual
  • 4 Answers
SOURCE: honeywell oil radiator
Press the *power button* once to start the heater on high power, continuous run. If left at this setting, the unit will run continuously on high power (1500 watts, 12.5 amps) and will not shut off until the unit is manually turned off.
Press the *power button* again, to change to low power, continuous run, (900 watts, 7.5 amps) and will not shut off until the unit is manually turned off.
Set temperature:
Press the temp/timer button until the temperature icon blinks. Use the up and down arrows to set the desired temperature.
The temperature icon will stop blinking and the current room temperature will reappear after the desired temperature is set.
The heater will turn off and on to achieve the desired temperature.
Set timer: (auto off)
Press the timer/timer button until the timer icon blinks. The hour display will appear. The auto off icon will also appear.
Use the up and down arrow buttons to set the heater operation time between 1 and 10 hours. This function will activate once the timer icon stops blinking. The heater will automatically turn off whn the times runs out.
Set timer: (auto on)
Press the temp/timer button until the timer icon blinks. The hour display will appear. The auto on icon will also appear.
Use the up and down arrow buttons to set the heater start time between 1 and 10 hours. This function will activate once the timer icon stops blinking.
The heater will automatically turn on when time expires.
Hope this helps!
Posted on Nov 16, 2007
SOURCE: Honeywell HZ-709 Oil Filled Radiator
Problem: firs let's identify the problem, there is a sensor on the inside panel, made originally for safety if you tipped the heater off, it kill the power causing it to turn off...after a year of so that sensor get a little rusty/dirty causing it not to work correctly...
let's find out how to fix that annoying turn off..
tool needed, a phillip screw driver.. electrical tape or soldering unit..
fixing it: take out the top and bottom screws, to open the panel. after you open the panel you'll see a metal bar screwed to the front controller...take all 6 screws out...the front panel comes off....then there is about 4 screws holding an inner box, open that up..
inside there, you;ll see lots of wires...look for 2 small blue wire running together to a black sensor that make noise everytime you move it....
disabling the sensor
2 ways you can do this..
-you can cut the wire off using a scissor, and connect the blue wires together, use the tape to tape them.
or
- you can solder them together on the back of sensor panel...
there you go problem solved...
Posted on Mar 25, 2008
SOURCE: Instruction Manual for HZ-705
cda5aa8.jpg maybe can help
Posted on May 31, 2008
SOURCE: honeywell kaz HZ-705 oil filled heater
i have the same problem. i do'nt know if i have to refill the oil; if so, what kind of oil?
Matt
please e-mail me = matpet33@yahoo.com
Posted on Aug 17, 2008
  • 24 Answers
SOURCE: NEED NEW POWER ON SWITCH
generally if you remove the switch and visit your local hardware store you can find what you need.
Posted on Jan 13, 2009
How many amps are adequate for the HZ 690? Is 15 amps satisfactory?
Imnot sure about amperes butyou check it on its body but also ithink you can conect it to anothr circuit or switch off yo guitar and use it but if still tripping you needto call electrician to check for earth leakage or replace with 20 amperes circuit breaker
Sep 13, 2014 | Honeywell HZ-690 Oil Filled Radiator...
Unit does not heat.
-Possibly dirty contact or burn elements.
Good luck
Mai
Nov 12, 2013 | Honeywell HZ-690 Oil Filled Radiator...
Where will I find replacement wheels for this heater?
Contact them here:
Kaz, Incorporated • Consumer Relations Department
250 Turnpike Road, Southborough, MA 01772
Toll Free: 1-800-477-0457 • E-mail: consumerrelations@kaz.com
And see if they even offer replacement parts for the Kaz - Honeywell Model HZ-690.
I do not know of any other source except a trial and error CASTER hunt at the local LOWES, MENARDS, or HOME DEPOT
Kelly
Jan 20, 2011 | Honeywell HZ-690 Oil Filled Radiator...
Our HoneywellHZ-690 oil - filledheater is leaking and I want to know if it is safe to use.
Here is a tip that I wrote that will help you to understand about oil filled radiator heaters....
Oil Filled Radiator Heater Leaking
heatman101
Dec 03, 2010 | Honeywell HZ-680 Oil Filled Radiator...
How do you set heater to work? I have no manual for this heater it is Honeywell HZ-709 Oil Filled Radiator Heater After I turn it on How do I turn it on and set it to work?
http://www.honeywellcentral.com/ssi/pdf/honeywell-commercial/oil-filled-heaters.pdf
That is the manual you need. Hope it helps. If you need anything else, let me know.
Dec 29, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 oil filled radiator heater-all controlls work but no heat produced. Possible reason?? Thanks
There is a bottom element and a top element so the elements could be dead.
More likey, there could be no power coming from the wall - there are switches on the front that need to light up or the thermostat could be set to off.
Dec 07, 2009 | Honeywell HZ-709 Oil Filled Radiator...
We purchased the Honeywell HZ-709 heater and the instruction manual is missing. How do we operate it?
That is the manual that you need. Hope this helps. If you need anything else, let me know.
Nov 19, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-690 Oil Filled Radiator Heater Logo
127 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Brandon Berry
Brandon Berry
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
