Question about Olympus Camedia C-8080 Wide Zoom Digital Camera
Camera Draining Battery
Within the past few weeks, my Olympus C8080 has been draining the batteries. At first I thought the problem was the fact that the battery was 3 years old. So I bought a new battery. Even though it was fully charged, the battery light in the camera started flashing that it was low after only two hours. I used to be able to go a full day with a charged battery. What could be the problem?
I have a olympus C-3040 and it is 6 years old untill resently it started to drain batterys in matter of 1 til 3 shots and there was no diffrence if the were chargable or one time users. ( it uses 4 size AA ) so I´m wondering what could be the reson it drains batterys so quickly, it must be generating a lot of heat inside the camera in the wiring.
Posted on Feb 10, 2008
  • 26 Answers
I have a different model of Olympus and I read that you did not always have this problem and you already have replaced the battery so an old battery is not likely the issue. I suspect you might have something that is draining that was not set in the past. I keep my batteries longer by not using flash most of the time. Is there someone new using the camera that perhaps leaves it on longer than you do after finishing, perhaps uses flash longer? Is there a setting for auto shutdown that has been changed to not turn off as fast as it used to? If none of these I wonder if the flash is requiring more energy than in the past.
Could you tell me if the battery is draining even if you don't use it or is it only if you are using it does it drain faster.
Another possibility is that the charger is not charging so well as it used to but I suspect you leave it in long enough and more.
If you have the ability to check the output voltage of the charger with a multimeter you would be sure it is really putting out enough volts to charge fully.
Please let me know if you have further questions.
Posted on Dec 21, 2007
My olympus tg 310 is stuck with the lens open and won't come on at all even when a fresh battery is installed
If the camera is within warranty, return it to where you bought it. Common fault with a few different brands, to do with a lens open sensor within the lens assembly itself. Maybe allow the camera to dischage without the battery for a few hours and see does it power on with a new battery. Also chack the battery, if it has bubbled it a dud, and check the battery contacts within the battery compartment.
Jun 05, 2012 | Olympus TOUGH TG-310 Digital Camera
I have been having this problem with my Olympus mju1040 for quite sometime. Everytime i tried to charge the battery when the battery low signal is blinking or when the screen blackout, it will be fully...
Try charging it for an hour even if it is indicating that it is already full in 10 minutes. If the battery still gets drained after a few shots, then you should change your charger.
May 22, 2011 | Olympus Stylus / mju 1040 Digital Camera
Battery drained within a few pictures but over a weeks time. camera is shut off between uses
Rechargeable batteries will degrade the more you use it. Their maximum capacity will always decrease the older the battery is. So if the camera is over 2 years old, the battery probably can't hold much of a charge anymore. Also, the battery will discharge even when the device may not be on.
My recommendation would be get a new battery. It doesn't hurt to have another one lying around, and there are usually Fuji compatible batteries you can buy that will not cost quite as much as an original.
Thanks for reading and good luck.
Feb 04, 2011 | Fuji FinePix 3800 Digital Camera
My Olympus Stylus 850SW won't turn on. Thought it was a drained battery, got new battery, then thought it was my charger. Bought new charger. Battery is fully charged, camera still will not turn on.
Good day,
Link above leads you to the Stylus 850SW manual-see page 62. Please make sure that you are using Olympus Lithium Ion Battery only, as this is the only battery the camera is accepting. Using exhausted battery will make the camera to turn off.
If the problem still persist, kindly contact Olympus Help desk for more details.
Aug 05, 2010 | Cameras
Rapid battery drain, also with new battery
u have a shorted power board.i had same problem when mine got wet. likley not repairable.
Aug 22, 2009 | Canon PowerShot SD550 / IXUS 750 Digital...
I have a Olympus C8080 digital camera that won't start up? It has a brand new battery, which I purchased because the old battery was over 4 years old, and because it took a charge in about 5 minutes, but...
Are you using a genuine Olympus BLM-1 or a cheap "compatible" battery. It's possible that the original fault was caused by a worn out battery, but if you've bought a cheap compatible from places like eBay or Amazon then they're often very poor quality and frequently not of the stated charge capacity. Sometimes they're not even lithium batteries so your charger and camera won't work properly with them They're often so cheap that there is no effective quality control so your new battery may well be a faulty one. There is no way that the new battery would have been fully charged after just eight minutes: although they're usually supplied with a partial charge it's nowhere near a full charge.
Another possibility is that your Olympus BCM-2 charger is faulty.
Worst of all, you may simply have been sold a pup. If the eBay seller described the camera as being in good working order then I suggest you ask for a refund and return the camera. Although private sales are "as seen" they also have to meet the sellers description. If the seller won't play ball then you may be able to claim PayPal buyer protection if you used it to pay the seller.
Your camera is a five year old model now and way outside the warranty, in the UK perfectly good used examples sell for around £125 and this is likely to be less than the likely cost of any repairs if you send it to Olympus. You'll need to carefully weigh up what you've paid so far, what you're likely to have to additionally buy just to diagnose the fault correctly and what you can get if you just cut your losses and sell the camera as is.
Apr 14, 2009 | Opteka (OP-T2XUHD-C8080) for Olympus...
Olympus Camedia C-8080 Wide Zoom Digital Camera Logo
261 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
