Question about NEC-Mitsubishi MultiSync LCD1770GX 17 in. Flat Panel LCD Monitor
I start my computer thet the monitor. After 2 sec. the monitor goes black (no power)then it starts again and it does that again and again I have an NEC LCD 170v
    Sergeant:
  • 199 Answers
Hello !
Your NEC LCD 170 has circuit problem  there must be a chip getting over heated  or has a lick .
Some chip can't handle the work load  so they shut down .
I suggest you get  a new  screen coz the cost of repair is more than buying .
good luck
Posted on Oct 03, 2009
  • 630 Answers
Check the power cable is in securely and check the VGA cable at both ends. Wiggle each cable and see what happens. If it's OK then faulty monitor.
  • 329 Answers
Check for cmos battery or try to change ram slot
SOURCE: monitor won't stay on
Hey. This problem is caused by the Backlight bulb(s) blowing up.
This is fixable. You have to get into the monitor and remove the LCD screen to see what bulb you need. This is a moderately difficult job and fragile parts will easily get broken.
However by all means have a go but this is the problem that you guys have been experiencing
Gareth162
Posted on Sep 02, 2008
bammbammfran
  • 159 Answers
SOURCE: Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes
Hi
I repair monitors
Based on other models , it sounds like you are having a powerboard-inverter issue.
It just so happens that I hjust got one in that's doing that, I should know in a day or two (maybe sooner) what the whole story on this model is.
Good timing !!??
ebaysbammbammfran
Posted on Oct 15, 2008
  • 11 Answers
SOURCE: Tyris Tyris 17" LCD F179 T701DB monitor image appears for 2 secs
Tyris Model: F179
No Power
Purchased an AsIs non-Working Tyris F179 from Goodwill for $15. Opened the case, found no swollen capacitors. Tested the capacitors on the power board and found C203 680uf 16v and C202 680uf 16v only partly working. Could not find a pair of 680uf caps and since they were in paralell on the same traces I removed both of them and substituted with a single 1500uf 16v capacitor. Next, the video board does have a Novatek chip much like the Novatek chip in the Samsung 710n but look closely at the 5 and 6 legs, they are not being used in the Tyris design so the 5/6 50ohm resistor fix is not needed here. Did find C107 , C16, C50 weak, all 47uf 16v, so i replaced them. Reassembled and now have a great picture again.
i'm not an expert at anything...x'cept maybe dumpster diving. God Bless
For Reference_Novatek Chip goto near bottom of page
http://translate.google.com/translate?hl=en&sl=es&u=http://www.dtforum.net/index.php%3Ftopic%3D55304.msg1010695085%3Btopicseen&prev=/search%3Fq%3DNT68F63LG%2B50%2Bohm%26hl%3Den%26rlz%3D1T4SUNA_enUS219US220
Posted on Mar 09, 2009
PaulRepair
  • 66 Answers
SOURCE: NEC MultiSync lcd 2010 monitor blank screen
This is the common bad capacitor problem. The caps have died inside, and they can be replaced. If you have basic electronics skills, you can go in, order replacement caps, and unsolder and resolder. If you can't do it yourself, you can take it into a shop.
Here is a link to the Cap plague that explains what happens in detail. But I repair these all the time with that symptom.
http://en.wikipedia.org/wiki/Capacitor_plague
Posted on Apr 02, 2009
  • 814 Answers
SOURCE: nec MONITOR TURNS ON FOR A SEC THEN GOES BLACK
This monitor is going into the protection mode due to a component failure. The unit should be sent or taken in to a service center for testing and repair. The NEC customer support telephone number is 1-800-632-4662. The website for customer support is www.necdisplay.com/support center. They will be able to tell you where you can take you monitor for servicing. I hope this information helps you with you problem
Posted on May 24, 2009
I have a Sceptre X7G-Naga VI 17 inch LCD Monitor When I turn the monitor on and boot the computer I get the red light for a sec then the blue light comes on I will also see windows booting up but the...
try with restarting computer & press F8 at the same time. u will see a menu where choose "safe mode" & start the computer. in safe mode see the display properties, set the refresh rate & resolution according to monitors specifications, apply & restart again. if that does not work, replace the main board of lcd monitor.
Aug 25, 2011 | Sceptre 17" LCD Monitor
Acer monitor swtiches itseolf off in i9n about 15
After much ado and waiting for tech support from Acer, remembered that some years ago something similar happened with a printer so I downloaded a new driver from acer for the monitor onto another computer, copied it to cd and then with much fiddling installed this on the acer, as it was installing monitor started to flicker and finally lit up again normally. Now working perfectly! When tech support phones, will tell them!!!!!!
Nov 20, 2009 | ViewSonic VX2235wm LCD Monitor
New computer, monitor issu
when you power on the computer ............after a second press F8
then advance boot option come after thet there is a option"enable VGA mode ............." press enter .finally window start up
then goto display properties and change the refreshing rate of moniter.
Apr 05, 2009 | X2Gen MG17J 17" Monitor
Acer AL2017 20 inch LCD Monitor comes on for 2 sec during start up then goes black. I 've had it for a year now. During start up it comes on 2 sec goes black then as the start up continues comes on 2 sec...
Hi
I repair monitors
Good timing !!??
ebaysbammbammfran
Oct 14, 2008 | Acer AL2017 20" LCD Monitor
My computer goes black
the problem is in the monitor, it charging and then discharging, u have to replace the capacitor in the montior and it will work
Feb 22, 2008 | AOC LM729 17" LCD Monitor
MY MONITOR TURNS ON AND AS IT SAYS STARTING ANALOG, IT IMEDIATELY GOES BLACK BUT FOR A SECOND I CAN SEE XP STARTING
Then ther is problem with your ram,please change your current RAM and upgrade it to newer one...
Dec 31, 2007 | Gateway FPD1760 17" LCD Monitor
NEC-Mitsubishi MultiSync LCD1770GX 17 in. Flat Panel LCD Monitor Logo
167 people viewed this question
Top NEC-Mitsubishi Computers & Internet Experts
Jerry Greenberg
Jerry Greenberg
mukhtar21 shaikh
mukhtar21 shaikh
Are you a NEC-Mitsubishi Computer and Internet Expert? Answer questions, earn points and help others
