Question about LG 42LC2D 42 in. LCD HDTV
Will not switch on
When you try to switch on the tv, from standby with the remote, the red power button just goes out and stays off.
Last week it was doing this but after 10 minutes the light would come back on, then go out for 5 min, etc. After about five goes the picture would eventualy come on and it would work fine.Now it stay off.
It has a BT Freeveiw and a DVD player attached by scarts and is approx 2 yrs old.
Cheers.
  • troybo Oct 03, 2009
    Thanks noobcybort. Looks like its the repair shop.
    Sergeant:
  • 199 Answers
There's a problem with the video card of the lcd TV  needs replacement .
some chip are damaged .or gets over heated eg processor .
Good luck
Posted on Oct 03, 2009
Tv on standby wont turn on either by remote or buttons on tv
Its not the remote but the set itself, Have it looked at and get an estimate for repair
Dec 05, 2012 | LG MKJ32022813 Remote Control
I can't program the remote to work for my tv
Try these codes. Proceedings are given. Switch OFFthe set and Switch it ON, each time, and wait till the standby light at the front of the TV to OFF.
Codes to check are.
0079 0123 0063 0020 0004 0009 0226 0266 0006 0095 0122
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
    If you can't set up it by the above proceedings, just go to Code Search Method. If your remote have a code to synchronise your TV, code search method should work. If not, there is no hope.
    CODE SEARCH METHOD
    1. Manually turn on the device (TV, VCR, etc.) to be controlled.
    2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
    3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
    4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
    5. Press and release MUTE to install the code. The indicator light goes off.
    Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search
Apr 20, 2012 | Radio Shack 3 in 1 Universal Remote
TV DOES NOT TURN ON STANDBY RED LIGHT STAYS ON
Hi Friend,
Check your TV's remote battries. If they are good, then, power off the TV at the main wall socket and unplug the power cord, leave it for 5 minutes. Now, connect back the main power cord, hold the Power On/Standby button on your TV and power then turn ON main switch on the wall. This should resolve your issue.
Thanks,
Shiva
Dec 19, 2010 | Sony Bravia KDL-40V4100 40 in. LCD HDTV
Pioneer 53
Unplug the TV for maybe 10 minutes, then turn it on. Sometimes these units simply need to recycle. If that doesn't work, you've likely got serious problems.
Apr 11, 2017 | Pioneer SD-533HD5 53" Rear Projection HDTV
My emerson tv standby light is on the power light flashes twice
Mine stayed in stanby mode and all I had to do was to switch the plug to a different outlet. The power strip it was on wasn't providing enough power. It worked fine for a month before I had a problem.
Dec 04, 2008 | Emerson EWL3706 37 in. LCD Television
TV won't turn on Sylvania LC320SL8 - 32'' LCD HDTV
will turn on tv with remote. stays on green for about 1 second and goes back to red.
Nov 11, 2008 | Televison & Video
'standby' mode and akb error number
AKB 66 in self diagnostic test means...TV goes to standby (shut-off) for AKB problem 66 times. AKB is White-Balance signal and it is not proper or maintained in your TV. So error signal produced and TV goes to shut-down state.
Regardnig Standby button, its available on remote only. If you push TV Power switch, TV will switch ON, push it again to OFF TV. Power Button on remote set TV in standby status and you dont need to push power button of TV itself.
Aug 14, 2008 | Sony KP-53HS10 TV
Goes into standby mode
press the off/on buttun and keep it pressed in while pressing the standby button... it should fix it
Nov 26, 2007 | Harman Kardon AVR 320 Receiver
LG 42LC2D 42 in. LCD HDTV Logo
151 people viewed this question
Computer Repairing
Computer Repairing
