Question about GE 24 in. GSD3400G Built-in Dishwasher
Dishwasher detergent does not dissolve entirely. Gel is still on side and powerball tabs doe not dissolve. Dishes are not clean. It sounds like it goes through the cycles properly.
  • 734 Answers
1. No waterMake sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner.
Posted on Dec 02, 2008
SOURCE:
Our dishes are not getting cleaned. Food particles remain and spots are all over the glassware. The detergent comes out of the holder, but is hardly dissolved and ends up on the bottom of the dishwasher --...
If your sprayer arms are clear, you will want to check these things.
The upper arm attaches to a tube in the back of the dishwasher. If the support clamps come loose, the upper spray tube will not be flush with the tube and can't carry water to the sprayer arms.
Also, make sure your water temperature is hot enough to dissolve your detergent. It should be 140 degrees.
Finally, make sure your detergent is fresh. If it is several months old, it might have become affected by humidity and will not dissolve.
I hope this helps. If it does, please come back to Fixya and rate my answer
Jun 14, 2011 | GE Dishwashers
My dishes are no longer getting clean. Is it
Hello Sue. There are a few things you can do. let's begin by giving the interior of your dishwasher a good cleaning. To do this, with an empty dishwasher, toss in 2 cups of vinegar and then run your longest and hottest wash cycle. Repeat monthly.
Next, consider changing your detergent over to a product like Electrasol Dishwasher Detergent with Powerball Tabs. That product gets the highest marks from my customers.
Finally, always run the hot water into the sink until it reaches max. temp. before you start the dishwasher. Joe
Thanks for choosing Fixya!
Feb 16, 2011 | Bosch 24 in. SHE43C05UC Stainless Steel...
Soap residue on glasses, dishes & flatware...what can I do..I use Cascade & JetDry
Instructions Things You'll Need:
  • Vinegar or lemon juice
  • Gel dishwasher detergent
  1. dishwashers have a rinse aid dispenser. If your dishwasher has this dispenser, fill it up periodically and it will release the appropriate amount of rinse aid automatically at the right time during the wash cycle. This will help your dishes rinse more cleanly.
  2. Rinse aid in solid form
    Some older dishwashers or basic models do not have an automatic rinse aid dispenser. In this case, you can buy rinse aid in solid form that attaches to your dishwasher rack. Solid rinse aid can be hard to find in stores because it is not commonly used, but it can be purchased online.
  3. Vinegar or lemon juice
    Appliance repairmen will tell you that one of the common problems they see with dishwashers is the buildup of excess detergent. If there is too much detergent in your dishwasher, your dishes will not rinse cleanly, no matter how good the dishwasher is or how much rinse aid you use. To clean the excess detergent that has built up inside your dishwasher, put 3 tablespoons of vinegar or lemon juice (concentrate is fine) in the empty dishwasher and run the dishwasher through a complete cycle with no dishes. Do this twice, for two complete cycles of the empty dishwasher with only vinegar or lemon juice added. The acid in the vinegar or lemon juice will break up the detergent that has built up in your dishwasher's interior.
    After you have cleaned the detergent buildup from the inside of your dishwasher, follow the steps below to keep the buildup from happening again and to help your dishes rinse cleanly and prevent residue from accumulating on the dishes.
  4. Gel dishwasher detergent
    Switch to a liquid or gel dishwasher detergent. Any brand will do.
  5. Fill one compartment half full Dishwashers will effectively clean dishes with much less detergent than manufacturers often recommend. The bleach in the detergent, combined with the extremely hot water used in the dishwasher wash cycle, will clean and sanitize your dishes completely, even in small amounts, and using less detergent helps prevent buildup and residue from accumulating on your clean dishes.
    Fill only one detergent compartment(the one that snaps closed) half full with gel detergent. Snap the opening closed and run your dishwasher as you normally would. Your dishes will come out sparkling clean with no buildup or residue, plus you'll save money by using less detergent!
Feb 02, 2011 | Dishwashers
Dishes not clean, soap not dissolving completly(powerball tabs and cascade gel)
first step would be to cut your soap usage in half. To much soap will cause the problems above.
Jun 10, 2010 | Maytag MDBS561AWS Stainless Steel...
Dishwasher detergent clumps in pre-wash and main wash compartments
Make certain that there are no apparent obstructions between water and detergent. If no obstructions and the detergent dispenser and spray arms are operable, then the detergent should dissolve during wash. Otherwise, try using a different kind and amount of detergent (e.g.: powder vs. gel or gel vs. powder, and less detergent). If still clumping, contact an appliance service company.
Feb 20, 2010 | Maytag Dishwashers
Does not clean well and leaves detergent residue even after several cycles. Tried changing from detergent tabs to gel, no real change.
The scum, film and white residue problems have started since the reduction of phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
Dishwasher Residue and Film on Dishes
heatman101
Dec 21, 2009 | Amana 24 in. ADB1500AW Built-in Dishwasher
Dishwasher wont dissolve soap and not washing properly
The make and model number can probably be found around the door edge (usually right side) If you can find it, post the make and mode # here.
Recommend you get a box of brand name detergent powder (like Electrosol or Cascade) and begin only using that. (Neve use gel or tablets) Cheap Cheap, generic detergent does not dissolve properly, leaves residue of its own and cleans poorly.
If problems continue, check the heating element as it is very possible that it has failed and the dishwasher needs to get to the proper temperature to activate the detergent. Also check to see if the holes in the spray arms are not blocked with debris.
If the heating element is working, then the wash pump motor has begun to fail and you need to decide to replace it or replace the entire dishwasher.
Apr 08, 2009 | Dishwashers
Dishwasher detergent won't dissolve
Recommend you stop using the gel and switch to a brand name powder - like Electrosol or Cascade. Never use gel, gel packs or tablets in any dishwasher. Avoid untra-cheap, generic powders.
If problems continue, a service call, with them checking that the heating element is working is the follow up step.
Good Luck!
Apr 02, 2009 | Whirlpool DU930PWSS Stainless Steel...
Detergent falls out and doesn't melt
check water temperture its not hot enough..onthejob
Feb 05, 2009 | Dishwashers
GE Monogram ZBD0700K - gel pak detergent not dissolving
Low inlet water Make sure inlet water temperature is at least
120°F (49°C)
Run water at the nearest faucet prior to
starting the dishwasher to insure optimal water
temperature.
Water pressure is low Turn on a faucet. Is water coming out
more slowly than usual? If so, wait until
pressure is normal before using your
dishwasher.
Air gap is clogged • Clean air gap.
Improper rack loading Make sure large dishware does not block the
detergent dispenser or the wash arms.
Jun 20, 2008 | GE Monogram® ZBD6880NSS Stainless Steel...
GE 24 in. GSD3400G Built-in Dishwasher Logo
486 people viewed this question
Top GE Dishwashers Experts
Mike
Archie Ferrarini
Archie Ferrarini
Vitally Alcher
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
