Question about Pioneer DEH-P8400MP CD Player
My pioneer deh-p8450mp is opening and closing/switching on and off contiuously. help
Hey sparrow, sorry you didn't get an answer to this sooner, mine just started doing the same thing. After fidling and dismantling for an hour or so I think I have diagnosed it to being the ribbon cable which comes from the circuit board to the front most control panel is cracked (i.e. the cable that connects to the connectors on the removable face plate) When the panel attempts to open fully the ribbon cable is flexed enough to lose connections making the unit think the faceplate has been removed and so attempts to close...when it closes the connectors retouch causing it to think it needs to reopen....this is a nasty design flaw for a unit that cost me $1500 (admitedly 10 years ago but it was in a box in the cupboard for 8 of those years) !!!! Now any chance I can source this $2 part .....eek
Posted on May 29, 2010
  • johnc4 Jan 24, 2014
    Just an update, the cables are sourceable however if you are desperate, a temp fix that worked was a dab of flexible glue where the cable has cracked. This solved the problem for me till i could get the replacement cable and time to install. About two months lol. Just make sure you put the glue dab on with the cable in the unflexed position. Also new cable has been fine for last four years now.
Pioneer deh p790bt display only works when open and goes out when faceplate is closed. everything works but no display.
The ribbon cable is bad. This is easily repairable. I think Best Buy still does them or call your local electronics repair shop.
Oct 11, 2013 | Pioneer DEH-P790BT
Pioneer premier deh-p880 prs faceplate opens when you turn car off
The face folds down to give you the option to remove the face if you want. It will return to the upright position a few seconds later whether you remove the face or not. There should be a tab on the underside of the face you can push should you decide to detach the face from the chassis.
May 07, 2012 | Pioneer Premier DEH-P880PRS
I have a pioneer deh-p7800mp and i dont know how insert the disc
there is a slot behind the screen when you push open the screen should drop down. put the cd into that slot when you do the screen will go back up. push open again the screen will drop and your cd will eject automatically.
Mar 25, 2009 | Pioneer DEH-P7800MP
DEH-P9600MP front flip half opens and switches system off.
I also had this problem and the solution was to change the data bus, or if you want, you can pull out a little the data bus.
Mar 14, 2009 | Pioneer Premier DEH-P960MP CD Player
Pioneer deh - p9600mp
An install gone bad. Something is hindering free movement of the face plate open mechanism. Closely inspect the top edge of the bezel, is the face plate trim ( thin plastic ornamental frame covering the ugly aluminium mounting sleeve) snapped securely back in place? has it been fitted upside down?, is it deformed?.
May 20, 2008 | Pioneer DEH-P9600MP CD Player
Pioneer deh p2000
stuck up voulume buttons. you need to open the head unit and locate that defective volume switch. sometimes these micro swtches can be opened up and cleaned. but this is requires really steady hands.
Apr 20, 2008 | Pioneer DEH-P2000 CD Player
Pioneer deh-p9600mp and deh-p960mp
my 9600 gat the same problem.. been told the ribbon needs replacing they sell on ebay for about £30 or you can send ur h/u to pioneer to do but that will be more expensive..
hope this helps
Jan 15, 2008 | Pioneer DEH-P9600MP CD Player
Keeps opening and closing
you can try the following:
With the car off but iginition switch "on" ,press multicontrol until "face auto open"option comes. select "off" and see the result.
or
Press RESET with the iginition "on".
the default setting will be "auto open ".so select it "off".
Dec 03, 2007 | Pioneer DEH-P5800MP CD Player
Cant save settings in Pioneer cd player DEH-P55BT car cd player
The constant power (yellow wire) needs to be connected to an unswitched +12V source. It sounds like that's either unconnected or you've connected it to a switched power source.
Nov 07, 2007 | Pioneer DEH-1500 CD Player
Pioneer DEH-P8400MP CD Player Logo
516 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
