Question about Theater Research TR-502 5.1 Surround Sound System Shelf System
Power subwoofer i have a powerd sub has L/R input but my matantz reciver has only 1 sub pre out
  • 74 Answers
Reciver should have came with an adapter, try google to see if you can find one
Posted on Oct 03, 2009
How can I connect a subwoofer to this device (denon pma-520) http://www.hifiengine.com/manual_library/denon/pma-520.shtml?destination=node%2F14208
Look around for a subwoofer which has speaker level inputs.
Something like this;
https://www.parts-express.com/dayton-audio-sub-1000-10-100-watt-powered-subwoofer--300-628
Jun 08, 2014 | Denon Pma-520 Integrated Stereo Amp...
Klh s120eth subwoofer not producing sound.
Normaly C26 has turned bad. It's 22uF/25V and is easy to access when module is disassembled.
Dec 29, 2012 | KLH Audio Players & Recorders
What is a sub woofer pre-out ?
Sub-Woofer pre out is for connecting that terminal to the input terminal of any sub-woofer. The sub woofer which it should be connected must be an active type [that is, there must be independent amplifier section built it with that sub-woofer; not mearly a crossover network].
Oct 22, 2012 | Denon RC-920
How do you hook up a behirnger a500 to my reciver
hi,
Check is there is any pre out for frond left and right channel in your recever. Noramally AV receivers have 5.1 pre out. If so connect the frond left right pre out to the left right input of your behringer a500.
ok
Aug 07, 2011 | Audio Players & Recorders
My subwoofer output is not working properly. I have a sunfire signature that worked all the time. Now the power on the Sunfire will not come. Research says no signal from receiver. I swithed the...
You can prove the sub pre-output works by running an RCA cable from it to the input of a tape deck, TV or any other device that accepts Line In and will either display it or play it. Test it on VERY LOW volume at the receiving device.
Different sub pre-out cable?
Feb 11, 2011 | Denon AVR-4800 Receiver
I have the Subwoofer plugged into the output and have it turned ON but it's still not working!
It only drives a self-powerd sub.
The manual...
http://www.retrevo.com/support/JVC-RX-8010VBKC-Receivers-manual/id/315dj079/t/2/
Page 17:
Setting the Subwoofer Information
Register whether you have connected a subwoofer or not.
Before you start, remember....
• There is a time limit in doing the following steps. If the setting is canceled before you finish, start from step 1 again.
On the front panel ONLY:
1. Press SETTING repeatedly until "SUBWOOFER" appears on the display.
The display changes to show the current setting.
2. Press CONTROL UP / DOWN to select "YES" or "NO."
• Each time you press the button, the display alternates between "YES" and "NO."
YES: Select this when a subwoofer is connected.
NO: Select this when no subwoofer is used.
Note:
You cannot use SUBWOOFER OUT ON/OFF on the front panel (see page 14) and adjust the subwoofer output level (see below) when "SUBWOOFER" is set to "NO."
Then continue with setting its relative level and other things.
Feb 06, 2011 | JVC RX-8010V Receiver
Where do my subwoofer speaker wires get hooked up to on the back of the reciver vsx-815 ??
Hi there, the Pioneer VSX-815 amplifier only feeds out a mono LINE LEVEL output with the subwoofer signal. Therefore you would need to connect the SUB PREOUT jack at the rear of the unit to the "line level input" on a self-powered subwoofer. Hope this helps.. Cheers, Yusuf
Nov 12, 2010 | Pioneer VSX-815-K Receiver
Acoustic Research AR-1 Qusetion- LFE Input and Output functions??
using the LFE input will give you cleaner less distorted bass. You must have a sub out on your receiver or pre-amp. it will give you greater control over the bass output of your system. If you only have one sub-out on your receiver simpley run a 10ft rca from the sub-out of reciever to the rca input of either speaker than use the rca out of 1st speaker to the rca input of second speaker. check to see if you have control of the level of your sub-out on your reciever. adjust the 30hz boost on rear of speakers. now you will have bass that most people only dream of having.
May 20, 2010 | Acoustic Research AR1 Speaker
How can i test my rca output jacks with a test light? pioneer deh p3100ub. hooked up spkr, nothing. tried one rca plug to white(lt) and then red(rt). Unit has 4 rca jacks, 2 for subwfr and 2 for front...
:) the rca jacks have to be connected to an amplifier,, their signal is too lay to even light a bulb.. you have to connect it to a car amplifier and then from the amplifier to the speakers..
Just so you'd know,, once your deck plays and you hear music on your speakers through your normal speaker wires,, RCA jacks work..
Ok you have 4 jacks,, 2 subs and 2 front.. These should connect to a preamp,, which takes 4 inputs and allows you to equalize or adjust how the music should sound,, now from the pre-amp,, it runs to an amplifier,, thats powers the subs and another that powers the speakers.. Some amps have 4 inputs so you can use one amp for your subs mids and heights..
for example a basic music system is
1 cd player
1 pre amp
1 amplifier (4 inputs, 4 channel out)
you bridge 1+2 and connect this to 1 12" double coil sub woofer
the next 2 connect to 2 mid speakers example "rockford or ev 5 / 8 " and 2 tweeters for heights..
Thats a kicking tricked out basic car audio system,,,
Hope that helps you understand how it works..
Mar 12, 2010 | Pioneer DEH P3100UB Car CD/ MP3 Player
Can i hook up the bose wireless reciver for the rear speakers with a onkyo reciver
I don't see why not. Use any record out or if you can rear pre amp out connect to the input on the bose unit.
Oct 09, 2009 | Bose Acoustimass 16 Speaker
116 people viewed this question
Top Theater Research Audio Players & Recorders Experts
David Payne
David Payne
 Grubhead
Grubhead
Tom Chichester
Are you a Theater Research Audio Player and Recorder Expert? Answer questions, earn points and help others
