Question about Sony Alpha DSLR-A200K Digital Camera
Just charged battery and replaced and LCD screen
Camera used frequently, wanted to charge battery because going away. It wasn't low. Left to charge over night. On inserting battery, LCD screen now blank. Can get menu by pressing 'Disp', which says battery fully charged. Can take photo as normal and see image through 'disp', Have pressed default, taken memory card out & put back in, battery out & put back in, switched on and off etc. but still blank screen. Read instruction book which says that you press 'disp'. What has happened?
Any suggestions?
Going away in 10 hours!!
thank you
  • 21 Answers
SOURCE: white LCD on my canon
Hi: I think you have broken (accidentaly with the fall) the cable with several wires that connect the LC display. My real advice is that you take your camera to a store were they can give you direct support desmanteling the camera and replacing the cable or fixing it. However, Zair already had a problem like yours and the best solutions was given by BowerR64. You can consult on the following page: http://www.fixya.com/problems-solutions/t103443,p294056/Canon-PowerShot-G2-Digital-Camera.aspx (just copy and paste on the address bar) ;) Regards
Posted on May 22, 2006
  • 36 Answers
SOURCE: Zoom, DISP & SET controls not working
I too have the exact same problem, and an online search turns up others with similar Casio Exilim models, with the same problem. It involves a malfunctioning Disp, Zoom, and non-functioning Set button, with all other functions working OK. Casio Support seems to recognize the problem, and indicates it has to be fixed at one of their authorized repair centers. Start with their online system: https://www.ecasiorepair.com/
Posted on Dec 03, 2007
RehanZafar
  • 38 Answers
SOURCE: Battery fully charged but my Sony F717 just unable to switch on.
Problem is occour in camera power supply section. There are 4 fuse in BT-015 Board if they are okay than check FR-194 Board. on this board IC001 DC control is faulty. I hope problem will be solved
Posted on Oct 09, 2008
  • 4090 Answers
SOURCE: DSC-W200 Frozen
try this it works for lens problems like you describe ]]]
OK you are probably going to think I am loony giving you this advise But No I am completely sane!
Get a can of compressed air OR acces to a compressor at your local garage Get them to fit the triggered air blower tool to it.
Blow around the lens in all the extension joins the firmly slap it in the palm of you hand with the side of the camera making contact with you palm. Do the procedure two or 3 times and inbetween the slaps turn it on to activate the lens mechanism. I have now fixed about 80 of these cameras with this method. I obtained the fix from Sony who charge $90 to do exactly the same. Keep at it as it will eventually work. One tip, make sure the battery is charged before you do this.
let me know if this worked for you Cheers
Please rate our help to keep the service online ++++ Thanks for using Fixya
Posted on Sep 11, 2009
SOURCE: The display on my Sony
my camarsa screen is black but, i know i have gone through to prosedure but i still get a black sceeen wethre it is picture or move plaese hep
Posted on May 28, 2010
Canon 600D LCD screen display problems
cables on the LCD screen needs replacement go to the nearest service center
Feb 09, 2014 | Canon EOS 600D Rebel T3i Digital Camera
Electric starter not working
Check battery terminals and voltage drop should not go below 11 volts when starter engaged.sounds like weak battery even new batteries could be weak if left on shelf to long fully charge on low amp charge overnight
Nov 09, 2017 | Cars & Trucks
My camera shows that battery is low even if battery is new
Clean the battery terminal connections with rubbing alcohol and a cotton swab
Sep 29, 2010 | Nikon COOLPIX L20 Digital Camera
Bought a Nikon Coolpix S220 digital camera in Thailand as the one I had was stolen in Laos- this Nikon camera came with a manual in Thai- what can I do about getting info in English- want to know what I...
If in doubt, charge the battery. You're not going to hurt it by charging it too frequently.
The camera does not have a battery level indicator as such. That is, it doesn't display anything if the battery level is good. If the level drops, a battery symbol will appear on the upper-right corner of the screen. If the level drops too far, it will say "Battery exhausted" and not allow you to take any pictures.
You can download an English-language copy of the manual from the manufacturer's web site at http://support.nikontech.com/app/answers/detail/a_id/13948
Jan 24, 2010 | Cameras
Is their a way to tell how much charge is left in the powerShot SD750 Digital elph battery by using the menu on the camera
Hey scelzinc,
This camera does not have a way to show the current charge level on your battery, but an Icon of a low battery symbol should appear on the LCD screen when your battery is at a low level and needs to be recharged. I hope this helps!
Sincerely,
Allan
Go Ahead. Use Us.
Jul 24, 2008 | Cameras
LCD IS NOT WORKING WHEN CHARGEABLE BATTERIES IS PUT IN THE BP300 GRIP
ni-cad or ni-mh rechargeable batteries all have charging cycle life and will fall in effeciency. in saying that, batteries used for some time will be not be as powerful as the new ones, and over or under charged batteries also wouldn't give you expected power.
i guess the CR123A you replaced is a new one, so it has the desirable voltage and current.
LCD itself and the driver actually do not require a lot of power, but the camera does, which draws away from the battery.
pc-cook
Jan 25, 2008 | Canon EOS Elan 7 35mm SLR Camera
Red light flashes and LCD turns off and on
A quick test would be to purchase a set of Duracell Ultra Digital batteries and try them. They won?t last for very long; however, if they make the red light go away then you problem is either the batteries you are using or the charger. More often than not its going to be the batteries so we?ll start there: Check your batteries, you should be using Nickel metal hydride (Ni-ME) that are rated at 1450 (I use 2500) mAh or better. If the batteries are more than one year and you?ve used them a lot then its likely the batteries just aren?t holding a charge anymore. Purchase a new set or borrow a working set from a friend. Charge them in your charger and try in your camera, if the red LED goes away use the batteries till they need charging again. Charge them in your charger and if the red LED stays off then the batteries were the problem. If the red LED returns then try charging your batteries in someone else?s working NiME charger. Put them in your camera and if the red LED goes away then your charger is the fault.
Jul 23, 2007 | HP Photosmart 945 Digital Camera
Camera not powering on
Hello... 1)camera is not turning on . Is the battery inserted correctly? Check the direction of the battery. Is the battery sufficiently charged? Use a battery that has been sufficiently charged. 2)camera switches off after powered on * Is the battery charge insufficient to operate the camera? Use a battery that has been sufficiently charged. * If you leave the camera on, the battery will be exhausted. Turn the camera off frequently by using power save mode or economy mode etc.
Jul 20, 2007 | Pentax Optio S5z Digital Camera
Sony Alpha DSLR-A200K Digital Camera Logo
15 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
