Question about Frigidaire Freezers
Frigidaire - Model No AFFU2066DW1 Frezzes up around door? Sits in the garage. Worked fine for years. Recently, Found that contents were thawed. Thought it was broke. Didn't do anything - it works now. Keeps everything frozen but ice builds up around the door. Found one spot on the door seal (aproximately seven inches) that is folded/warped. How should I proceed? Thanks
SOURCE: Ice build up in my frost free upright freezer
seems simple you have blocked defrost drain hole. find it and clear it out.
Posted on Nov 11, 2006
Falling Down
  • 67 Answers
SOURCE: door liner on chest freezer broke due to ice build-up
if you can't find a replacement, use a piece of flat vinyl siding that goes on houses. You can heat it and bend it as needed, or cut it and screw the pieces to a balsa wood frame for lightweight support. Glue or epoxy probably won't work as the cold temps make them brittle but external caulking may be ok to hold the pieces together. Be sure to sand all edges and corners as the cut plastic can be sharp. If you can disassemble the unit and place the door face down, you can fill the cavity with insulating foam to help stabilize it.
Posted on Nov 30, 2007
22yooper
  • 828 Answers
SOURCE: frigidaire upright model #MFU20F3GW8- Food not freezing
Check and clean the air cooled condenser for dust and dirt. Check and make sure the fan in back, on the bottom behind a removable panel, is operating. After cleaning the condenser replace the panel.
Also you stated there is no frost anywhere. Did you check the back wall of the freezer for frost buildup. If not check it and if there is frost there your defrost system is not working and the frost has stopped air circulation.
Posted on Jun 15, 2008
SOURCE: freezer door not sealing
Probably a defective defrost timer. Try to find the timer. It is usually underneat in the back. When you find it turn the knob slowly click by click. (You may need a screwdriver or knife) turn just until the compressor stops. Let it stay in defrost for about 1/2 hour. turn the knob until the compressor starts let it cool down several hours. Then do it again. If this solves the problem replace the timer. While you are waiting to do this Defrost it at least twice a day by turning the knob.
Posted on Jul 03, 2008
ngfam1
  • 639 Answers
SOURCE: Frigidaire LFFH2067DW3
Roger ,
If the problem started prior to July 2008 and you had service document it!
call Frigidaire and ask for a supervisor!
Tell them that you want it replaced or you will not buy the, Frigidaire Pro stainless steel kitchen that you planned to get in 2 months when you remodel you kitchen!
They call it a PUSH PULL!
They contact me or some other dealer and pay them replace it for you and it includes all charges that they pay to the dealer!
0 dollars for you! I do this often!
I KNOW THIS WILL WORK!
Neil
PS. PLEASE WRITE A "PROBLEM SOLVED" RATING FOR ME HERE IN THE FIXYA.COM SITE!!
THANK YOU
Posted on Aug 25, 2008
Freezer cools fine but will not shut off till I open door
Running all the time means you either have to clear/clean your condenser... Check for good tight door seals... and make sure the doors/vents are not blocked by any contents...
Free flowing cold dry air inside... sealed compartments is ideal.
Dollar Pull test:
Use the dollar bill pull test all round your doors...
(brown paper sack is cleaner & nicer):
You can take the paper...
close the door on it..
Pulling it out you should feel mild but constant pressure around the full perimeter of each door (or drawer).
If you do NOT feel it the door/drawer needs to be checked for gasket integrity... and the door may need to be adjusted.
New door gaskets are not terribly expensive
(but most issues are caused by spilled food, cleaning
or door adjustments = easy).
(FULLY covered in every owners manual I've read).
Consider purchasing 2 TAYLOR BRAND refrigerator
thermometer & turning the freezer to the ZERO Fahrenheit
area and the refrigerator to 33 or 34 degrees above zero
(32 degrees Fahrenheit... being frozen eggs & milk (too cold)).
Else... comment me back...
We can take this all the way into refrigerant level check if you find NOTHING ELSE WRONG
((HIGHLY IMPROBABLE... but do-able)).
You gasket is showing as no longer
available... at appliancepartspros.com...
So be gentle!!!
http://www.appliancepartspros.com/frigidaire-gasket-door-white-216522312-ap2113453.html (Frigidaire 216522312)
Sep 22, 2016 | Frigidaire Freezers
Lffh21f7hwa
Hello Michael - Sounds like the temperature control was accidently turned OFF. When this occurs the temperature control turns off the compressor, but does not disconnect the power to the light bulb or other electronics. Let's try activating the freezer by pressing the UP arrow until display shows "4" or desired setting. Allow 24 hours for temperature to stabilize. For future reference you can lock the control to keep from accidently changing the temperature setting. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if the unit's status has changed successfully. Thank you.
Jul 01, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Not freezing
Check your circulatation fan. It may be stuck. Keep me informed The Raz Shack
Apr 20, 2010 | Frigidaire 14.1 cu. ft. Upright Freezer...
Frigidaire uprite freezer won't cool
it's scrap
they use steel lines inside the cabinet and when you unplugged it the lines rusted through
Jul 30, 2009 | Frigidaire 5 cu. ft. / 142 liter Chest...
Freezer is in garage and has worked up until now. Still runs, makes a humming sound and is cold but not freezing. Food is thawing.
jeskjw
If it is below freezing in your garage the freezer will not work.
No freezer except one Frigidaire freezer will work in the extreme cold.
This one has a button to switch it to a refrigerator in the winter and a freezer in the summer.
Apr 06, 2009 | Frigidaire Freezers
Kenmore commercial upright freezer not sealing well - thawing
If the door seal does not seal completely, replace it. This is very important for freezers.
Contact Rick at Restaurant Parts and More.
\1-888-814-1110. He can most likely get what you need. Just have model and serial numbers and he'll do the rest.
Home Depot and Lowes is a definite no.
Apr 04, 2009 | True 23 cu. ft. / 651 liter Commercial...
Bottom freezer door dripping water on kitchen floor
you can take a ook into the freezer sect its possible that the line has frozen, nad no longer is defrost water going into the drain but rather falling on to the floor of freezer and evnetually out the door
Jan 11, 2009 | Freezers
Top of freezer thawing
Ice build-up in the area of the door could be causing the door gaskets to loose their seal. Shut the unit off and use a hair drier to melt the ice away from the door area. Return the control to run position and see if it makes a difference.
May 14, 2008 | Kenmore Freezers
Amana self defrosting upright freezer - drain plug
The subject is a Eureka Model 350 hand held steamer that can be found at Lowes and other places for around $49.95. With this steamer you can thaw out an evaporator as quick as if you were using a heat gun or hair dryer but without the slightest concern about melting plastic or wiring. By using steam instead of pouring water (yes many still do) there is little to clean up. With the many attachments it comes with there are other uses (i.e. cleaning, thawing drains, thawing IDI fill tubes, etc.). The steam also makes the replacement IDI fill tube (rubber end) more pliable and easier to complete the installation when used at the end.
This unit has a trigger and can be used to blow out a stopped up drain on a refrigerator by letting the pressure build up a little then blow through the drain with one of the attachments. As for thawing out evaporators it had a fine jet tip for actually CUTTING through solid ice.
Another great use for this tool is refrigerator door gaskets. The hot steam works faster than a heat gun with out the worry.
Note: Do not aim steam directly onto the plastic freezer liner. The rapid temperature change could damage the liner.
Jan 18, 2008 | Amana 16.8 cu. ft. / 476 liter Upright...
Some food is thawing in my chest freezer
these frigidaire made freezers are notorious for having restrictions in the sealed systems that will cause exactly what your describing.
what happens is oil moves around in the freon system and pools up in the capillary tubes and the freon is not able to flow properly. if the unit is under 5 yrs old then should be inwarranty to sears. if its over 5 then probably cheaper to purchase a new one..
Dec 19, 2007 | Kenmore 14.8 cu. ft. / 419 liter Chest...
Freezers Logo
52 people viewed this question
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
