Question about Canon PowerShot S1 IS Digital Camera
Flasher wont go down after shooting the photo.
Even when the flasher mode it set to auto, it comes out and flash correctly but the flasher wont go down automatically so, have to press it back manually. Is this the normal behavior or an error scenario?Thanks//
SOURCE: Canon Digital Rebel XT: error 05
I had the sticking and two-clicks problem also. I manually pulled the flash up, then took a Q-tip dipped in standard rubbing alcohol and ran it over all the sliding mechanism parts of the flash. Then I rubbed the dry end of the Q-tip over it all agan and it now works fine.
Posted on Feb 11, 2008
SOURCE: Canon SD 550 does not work when flash setting is ON
I have the same problem. Cannon customer support says it will fix this for $119 + 8 for shipping... or you can get a refurbished SD 800is for $140+10 for shipping with w/ a 6 month warranty... what a deal ;~)
Posted on Mar 27, 2008
SOURCE: shut off
Make sure you are using alkaline batteries
Posted on Mar 29, 2008
informatica
  • 1114 Answers
SOURCE: Automatic shooting (for group pictures)
Hi - You can download the manual from the link underlined in blue below:
PowerShot A710
The feature you need is the "self timer" on page 14:
When you press the shutter you will have up to 30 seconds to get yourself in the picture before the camera automatically takes the picture. For best results put the camera on a tripod.
Please take a moment to rate this solution & let us know if the information given was useful to you - Good Luck!
Informatica
Posted on Aug 27, 2008
  • 3 Answers
SOURCE: My G10 will automatically take 3 photos in one
It's probably bracketing each photo. Depends on the settings, but it will take the same picture and under expose or over expose it making sure you get a good picture.
Posted on Mar 14, 2010
My turn singal wont come on an its makes noise when I do turn it on a 99 durango 4x4
The noise you here may be a bad flasher, sometimes you hear a buzzing sound.I have found that a lot of dodge, jeep and Chrysler have a problem with aftermarket flashers.Sometimes the flasher will go bad and not work or make noise.If you like you can go to an auto parts store and try the flasher they sell, if you have a problem still then try a dealer flasher.See if the 4 way flashers work, or try to put signal on and gentle move the signal switch arm up , or down and see if the signal starts to work. if it does then you have a bad signal switch, also called a multi-function switch. let me know the out come, good day.
Apr 26, 2012 | 1999 Dodge Durango
When i press the Shutter release button with the flasher the Flash comes 1 or 2 seconds late
it is a Flash offset, resetting the settings to factory will bring it back to zero.
Apr 09, 2012 | Cameras
When I shoot in arperture priority my photos come out blue. All ok in auto come. Canon d40x
The priority modes often give you more control over more features than auto mode does. In auto mode, the camera is deciding your white-balance, and may not let you select a white balance setting even if you wanted to. In aperture priority, your camera will give you control over white balance. Switch to aperture priority, then check your white-balance (wb) mode. You should still be able to select "auto" within these settings if you'd like, but feel free to play with the various settings to get your ideal photo. Good luck!
Aug 15, 2011 | Cameras
Where is the turn signal flasher located for a 97 cadillac deville.
to the left of the steering collum connected to the under collum kick panel as you take the panel down it'll be connected to the cover, It's not a genaric flasher, it's square and looks like a relay585157684.jpgCost about 6 bucks at the parts store. If the turn signals aren't flashing and they do come on, and may be they flash on one side and not the other then it's not the flashers fault. All the light bulbs have to work or it won't flash and thats how you know that thiers a bulb out. Turn on the four ways flashers (Hazard lights ) and walk arounf the car and see if thier all working and flashing brightly. They'll flash anyway on four way the switches are known to hang in hazard and not work right on turn signal so try switching ti a few times and maybe it'll straighten out. If it flashes at all the flasher is good and if they don't even light not on hazard or turn the flasher and or the fuse is bad.
Sep 17, 2010 | 1997 Cadillac DeVille
Were is the flasher for left rear light
There is one flasher that controls all 4 turn signals. If only one light is not flashing the flasher relay is not the problem. If the flasher relay is bad none of them will flash. Check the bulb. The Turn signal flasher relay is located front seating area. It is integral to the hazard switch located in the center of the instrument panel, just above the radio. Curtorsey: Auto Zone
May 18, 2010 | 2002 Jeep Liberty
Pictures that I take come out very white/bright. you cannot tell details. I have changed batteries and have the setting on auto.
Double-check your flash settings. You mentioned the camera is in Auto mode, but the flash has separate settings from the camera's shooting mode. With the camera in shooting mode AUTO check the Flash settings (Auto, Red-Eye Reduction, Fill-In, Off) It may be set to 'fill' causing your photos to be too bright.
Also, depending on how close you are to your subject the flash may not be needed. Using the flash when too close to your subject (less then 3 ft.) will cause bright/white photos. Turn the flash OFF if you are taking macro or photos closer then 3ft.
If neither of these fix your problem, turn the flash mode OFF, and camera shooting mode to AUTO and in a naturally well lit area, take a photo, if the photo is still too bright, you may have something mechanically wrong with your camera.
Nov 03, 2009 | Olympus FE-210 Digital Camera
Turn signals wont flash bulb good lights come on but dont blink
you either have a bad lamp on both left and right sides that will kill the flasher until replaced, but I would bet the flasher itself is bad
Oct 17, 2009 | 2002 Ford F350 Super Duty DRW Reg. Cab
G9 flash
My flash doesnt work either. Holding the flash button down doesnt do anything either (in program mode)
Apr 08, 2008 | Canon PowerShot G9 Digital Camera
Canon PowerShot S1 IS Digital Camera Logo
12 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
