Question about Admiral AW22 Top Load Washer
Admiral Washer AAV7000AWW everything works -goes through cyclebut will not drain
Everything seems to work fine but the problem. The washer does its thing. Fills, agitates and spins - goes through the cycle normally. However, when it spins to drain, whether it is after the wash or after the rinse (final spin), it does not pump the water out.
I unplugged the drain from the tub to the pump. The water comes out free flow. I unplugged the out drain from the pump with the hose hooked up to the tub. Without running the machine, water flows freely.
I turned the machine on its side. the belt is turning the wheel on the tub, motor and water drain pump.
The motor does click and move into a new position when the it comes to the spin time.
So that would lead me to believe it is the water drain pump.
Here is the thing. I replaced the water drain pump 3 1/2 months ago. Could it have gone bad in this period of time? My wife said that when this occurred, she heard a grinding sound and did go to the basement to shut is off.
Everything seems in order but it will not drain/pump the water out.
Expecting guests for the holidays----Help!!!!!!!
You,ve done a good job the first time the pump fail MikieM. You can do it again. We sometimes forget to empty our pocket. Some small metal things could have gotten into the pump...could be other hard foreign object. Good luck.
Posted on Dec 29, 2007
Admiral washer aav7000aww
If your drain is not high enough, 39 inches, from the ground, it will siphon out. Also if your drain hose is too far down the drain, this will also happen. Just make sure your drain hose in not laying on the ground.
Sep 02, 2014 | Admiral Washing Machines
My admiral AAV7000AWW washer makes a loud chattering noise and leaks water..An solutions?Thanks a bunch
Chattering could be a shaft bearing and if it got bad enough could have damaged the tub seal and makes it leak. attached is a price on parts if your interested
http://www.appliancepartspros.com/07-tub-parts-for-admiral-aav7000aww.html
Jan 07, 2012 | Whirlpool Cabrio Washing Machines
Washer makes straining noise when draining water from tub while spinning?
my admiral washer machine model AAV7000AWW makes a noise only when draining/spining water, is no water spill at all. Thanks
May 21, 2010 | Washing Machines
Willnot spin
You may have a bad lid switch.
Mar 07, 2010 | Maytag Admiral AAV7000A
Admiral Washing machine will not advance to the next cycle.
whirpool machine .. it was overload and now it's not draining the water. stops when in the drain cycle./
Jan 01, 2009 | Admiral AW22 Top Load Washer
Washer is washing but is not letting water out
remove drain hose in back and make sure it is not plugged with hair. also there is a drain hole between the rubber seals in the front of the washer just inside the door that always seems to plug with hair. When you remove the drain hose make sure to look inside the hole where the hose connects to the washer.
hope that works!
Jul 30, 2008 | Kenmore Elite HE4 Electric Dryer
Admiral AW22 Top Load Washer Logo
394 people viewed this question
Top Admiral Washing Machines Experts
Sal De
Are you an Admiral Washing Machine Expert? Answer questions, earn points and help others
