Optoma HD70 DLP Projector Logo
Posted on Oct 03, 2009
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Hi, I have an Optoma Hd70 and it keeps turning off after about a 1 min and the temperature indication is blinking red. Is there an airfilter I can clean or something?
Grand Canyon Tech
Level 3:
  • Master 3,867 Answers
  • Posted on Oct 03, 2009
Grand Canyon Tech
Master
Level 3:
Answers
3867
Questions
Helped
1176676
Points
12717
Sounds like there is a overheat sensor failed in this unit in the lamp balast sure a cloaged filter could heat the unit as well so yeah check that..
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
2answers
Optoma HD70 bulb failure
I am betting that the ribbon cable to your color wheel has become loose. Here is a detailed slide show of a similar model so note where the cables are and check each one.
Optoma HD20 DLP Projector DMD repair turning green and flickering
I have a Optoma projector HD70 How do you reset the lamp operating time?
hi,
Do the following for reset the lamp hour.
1. Press the menu button
2. Select Options.
3. Select lamp settings
4. Select lamp reset.
5 Select Yes
ok
When i start a projector after few min screen becomes blank and projectors red led glows.Please provide the help.It is very argent.
well try this....
Before replacing your bulb, fan or any other component try first cleaning your optoma realy good!! HD70 doesnt comes with any kind of filter so you can imagine the amound of dust can be.
The most importent thing is to blow away any dust from your color wheel + the sensor attached to it .
for farther troubleshoting clean your fan's.
there are 2 fan's insinde the HD70.
probably the most problems will be solved by cleening the color wheel!!
if the problem is not solved ,chack the lemp and the fans if they work properlly.
For fan replacing:
Fan Part number: GM1207PKVX-A
How do Ichange the lamp on my hd70.
Look in page 40 of your projector's User's Manual.
If you don't have the manual, you can download it from OPTOMA support pages: OPTOMA HD70 USER'S MANUAL
5helpful
OPTOMA HD70 projector turns off in a few seconds
my 3m projector turns off as soon as it is turned on
5helpful
Optoma HD 70 turns on with lamp and temo soiled lights
Asher fadida and alll,
The issue:
solid red error light?
HD70 "die's" after few min with strage noise?
flickers different colors before complete self shutdown?
well try this....
For fan replacing:
Good luck!!
Hi, on optoma hd70 3 LED lights blinking and projector won't power on
mine is doing this exact same thing. would love to know if you fixed this problem or if anyone else has had this problem and had it fixed.
1helpful
Optoma HD70
Call 1-888-942-2929 option 2 the cost is $59.00
Top Optoma Office Equipment & Supplies Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
john h
Are you an Optoma Office Equipment and Supply Expert? Answer questions, earn points and help others
