Question about NetGear RangeMax WPN824 Router
I have internet on my laptop, but my pc doesn't. It says there's no ip address assigned to my pc. what to do?
  • 99 Answers
First check what IP address has been assigned to your laptop and assign the same IP address to your PC.
ELSE
check with your ISP (internet service provider) what IP has he assigned. Then it works.
Regards
Posted on Oct 03, 2009
Self assigned ip
Hi,an IP assigned by the Internet Service Provider[ISP] so you can contact and assigned IP.
If you need to check your Internet IP address visit the site IP-Details.com and get it.
Dec 02, 2013 | Apple MacBook Pro Laptop Computer with...
Connection issues
To troubleshoot the issue follow the below steps
1.Try disbaling and enabling the wireless lan card
2.Check whether Ip addresses assigned in the wireless network card.If the address is assigned by dhcp and not assigned in network card means assign static ip in the range supported in the networkand ping the website or gateway.
3.If the ip is assigned already means try pinging the gateway and dns server .If ping is success means the connection between router and pc and internet is good .In that case you have to check whether authentication is successful if any authentication is used.
May 10, 2010 | D-Link DIR-625 (790069292637) Wireless...
I'm having trouble getting a wireless internet connection. When I boot up my laptop the router does not recognize the laptop I.P. address and won't establish a connection. How do I fix this problem?
1. make sure you have a DHCP server that can assign the IP addreses, Routers usually come with one...so make sure it is configured to lease addresses 2. Make sure your computer does not have a manually assigned IP, and that it automatically receives one from the Router...
Jan 17, 2010 | HP Pavilion dv5000z Notebook
I formatted my system and reinstalled Win XP on it, but now I could not use wireless to connect with internet
Make sure you have Wireless network adapter driver installed.
Manually assigned IP address and DNS address as earlier (if your IP setting is not automatically assigned by DHCP server).
If you are using router set your Router IP address as your Default Gateway Address.
If you are using Internet through a Proxy Server then Open "Internet Explorer ",
Click "Tools",
Click "Internet options",
click on tab called "Connection",
Click "Lan settings" Button.
Remove "Automatically detect settings".
Tick "use a proxy server for your LAN....."
Type the IP address of your Proxy Server and the port no.
It will work.
Dec 26, 2009 | ASUS A8HE-X1 Notebook
I can not operate Internet
Hi there, my name is Alex and I am here to help solve this problem.
There are many ways why internet might not be operating.
1: Please check all your connections with the phone line and router are correct
2: You may have an antivirus with a built in Firewall which can block the traffic to internet to your computer
3: You may need to assign your computer with an IP address and possibly DNS addresses. Some internet companies assign connections with their own IP addresses automatically and if this is the case and you have put an IP address on your computer, then take it out, select to Optain IP address automatically. This type of connection is known as a dynamic connection and a static connection is when your ISP company assign your connection with your own IP ADDRESS
To check these settings, click start, configuration, control panel and select network connections
right click on local area connections and select properties. Click the bottom option Internet protocol (TCP/IP) and click properties. There you will find if your PC has an IP address assigned.
4: Your RJ45 connectors (These are the connectors which go into a LAN card and one end to the router may not be inserted correct or the ethernet cable may be damaged or wired incorrectly
5: The last option could be you have a Virus, malware, spyware or even third party software installed on your computer which is blocking access to the internet
I hope this info helps. Please let me know if you have any more questions. happy to help
Jan 08, 2009 | Dell Inspiron 1501 Notebook
Wireless internet hookup
What seems to be the problem of your wireless internet?
Mar 27, 2008 | Computers & Internet
Internet hookup
This is not the manufacturer's site, but i will try to help.
Is it your own network?
You need to make sure that the network is not protected, or you'll need the password.
Go to Start>Control Panel on your computer
Then go to Network Connections
There should be an icon for your wireless connection.
Right-click -> select Properties
In the selectbox select 'Internet Protocol (TCP/IP)'
Click Properties
Check if 'Obtain an IP-address automatically' and 'Obtain DNS-server' are selected
If they were not, Press <Ok> two times and try to connect to the wireless network again.
Can you also tell what IP-address you get?
Find it by going to Start > Run
Type 'cmd' without the quotation marks and press <Ok>
you get a black command box
type 'ipconfig', again without the quotation marks and press <Enter>
Please tell me the IP-address it tells you...
Mar 27, 2008 | Averatec 3200 Notebook
Laptop (Averatec Model #3150
Hi
I am try to take a stab at answering your query.
Internet Protocol (IP) Address preceeding with "169" means your PC is not receiving IP Address "generally" from your Boradband Modem or Internet Service Provider (ISP). The PC through Automatic Private Internet Protocol Addressing (APIPA) is assigning itself a temporal IP address.
This conditions means either
1. Dynamic Host Configuration Protocol (DHCP) Client service is not running properly on your PC (Unlikely)
2. There is no connection between your PC and Broadband Device or ISP wired or wirelessly (very likely)
3. DHCP Server Service is not configured or not running on Boardband device (likely) or ISP (unlikely)
4. Some firewall software when improperly configured are known to block all ports and services. This can block TCP Ports 67 and 68 used by DHCP Client/Server communication (quite likely)
Some pointers for more info;
1. Your query suggest your issues are limited to Wireless connection. Can you access Internet through wired connection? If so;
a) What Wired connection is in use? USB or Ethernet?
b) Is wired connection through same Broadband device?
c) What IP is assigned to your PC in wired connection?
d) If wired connection works, is IP assignment static or by DHCP?
e) What Boardband device is in use? In which mode is the device set to? Router/Bridge
2. If you can't connect both wired and wireless, then it is unlikely your PC hardware is at fault. Call your Broadband Provider for further help and configuration. Try entily disabling your firwall software (if installed) and test conection.
3. If you can connect through wired connection and your IP Address does not proceed with "192.168" or "172.16" then your boadband device is likely in a bridge mode. In bridge mode, the DHCP Server Service on your boardband device is disabled. Most ISPs will only assign only one IP address to a user. If an IP address has been assigned to your PC on the wired connection, then the wireless connection will not receive an IP address and therefore your PC will assign itself an IP in the range "169.254"
Regards
Mike
Mar 27, 2008 | Averatec 3150H Notebook
Trying to hook up lap top to wireless internet. Comcast tech says there is problem with IP# 169 which preceeds other numbers and needs to be removed for hookup. How can I accomplish this? Model #3150H
Usually you will have an IP address starting with 169 if the adapter cannot get an ip address from anywhere, it is an autmoatic IP address.
What operating system (Windows XP or 2000 or Vista) are you using?
Dell latitude d800 laptop
The problem may be the modem has to assign an IP address to your laptop, what you may have to do is plug the laptop into the modem and see if the laptop recognizes the modem with no errors in device manager,
Next turn off the laptop and modem, reboot the laptop then modem for the modem to assign an IP address.
Mar 19, 2008 | Dell Latitude D800 Notebook
NetGear RangeMax WPN824 Router Logo
47 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
