Question about Intel D945GCCR Motherboard
How many GB hdd does intel 945GCCR support
How many GB hard disk does intel 945GCCR support?
I have a 160 GB sata and 80 GB Pata but when i connect both the hard disks only 40 GB of the pata is accessible is it that 945 GCCR only support 200 GB
  • 3,866 Answers
Depends on how your formatting this sir.. The bios first would need to support large drive or LBA mode if it does you need to format this using NTFS file system or FAT 32...
Posted on Oct 03, 2009
    Sergeant:
    Champion:
  • 208 Answers
*********** board certainly supports ATA-6 with a maximum capacity of 144,000 terabytes. That's a lot more than 200GB. Your bios settings for the drive maybe wrong. You may want to just reset your BIOS to factory default if you don't want to mess with all the BIOS settings.
Can't setup OS in SATA HDD in Intel d945gccr
Hi.
XP will not install until you go into the BIOS and find the menu page (probably by moving across the top level of tabs) where the SATA hard drives are configured. On that page you will see the ports and at least one, maybe all, will be Enabled. Close to that will be the port mode, usually setable individually for each port. Choices may include IDE (or PATA) Emulation, SATA, AHCI. Set your port to IDE emulation. Now look at the bottom for the key to Save and Exit - often the F10 key, press that key and select OK, the computer will restart and you should now be able to install Windows XP without any problems.
To get into the BIOS you have to press the Del or Esc key when you first turn the computer on.
Regards.
Feb 04, 2013 | Intel D945GCCR Motherboard
Sir my inspiron laptop b130, intel pentium processor 1.70 mhz 598 mhz, it is suitable for upgration r not? ram 1gb. 40 gb hard disk.? I need 2 gb ram and 500gb usb hard disk for oracle applications...
Max RAM for that system is 2GB
http://www.crucial.com/store/listparts.aspx?model=Inspiron%20B130&Cat=RAM
The question is whether there are 500GB hdds for that system. The largest PATA HDD I found was 320 GB
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=4600076&CatId=2675
and there is no guarantee the BIOS will recognise a HDD that large as PATA HDDs require BIOS support for the drive size where SATA HDDs will pretty much work.
My recommendation is to retire this system and BUY a new one.
http://www.tigerdirect.com/applications/searchtools/item-details.asp?EdpNo=631874&csid=_23
Sep 10, 2011 | Dell Inspiron B130 Notebook
Hello, My my motherborad is ASUS p5rd1-vm;RAM1GB and hard disk is PATA 80 GB but the HDD is having some kind of problem and the windows have shown a warning about it several times. Now i want to buy a...
Yes, it's compatible with the motherboard, no, it's not compatible with the XP install disk because it doesn't have SATA support. And since Asus doesn't provides it special driver needed (one that must be put on a floppy) it means that you simply cannot install XP on this disk.
All you can do is to obtain another PATA hdd what ever its size and install XP in it. Then put the new SATA disk in and use it to store all the installed programs and all your files on it. As a bonus you won't lose them if the new PATA disk fails or XP gets corrupted.
Or install Vista or 7 instead of XP, the have support for SATA disks
Jul 28, 2011 | ASUS P5RD1-VM Motherboard
Upgrading my computer
Dear Fried its possible.. Go the Boot Menu at your BIOS ( For go the BIOS Press DEL at startup your system) there you may se Hard Disk Priority Option. There you can change Hard disk Priority... you may need setup your sata as first one..
Thanks...
Mar 26, 2009 | ASUS K8V SE DELUXE,...
Troubling in sata connection
  • I suppose there is a jumper(beside the power pin) on your new HDD,
  • if its true the your HDD supports 3GB/s mode but your motherboard does not .
  • So place the jumper on the HDD on 1.5GB/s combination.
then
  • Disconnect the 80 GB,
  • Connect the new HDD,
  • Boot from any bootable xp or vista or any disk tool like erd commander and try to format the new HDD.
  • Then connect the new HDD and boot from it.
Tell me what happened.
Jan 31, 2009 | Seagate 20PK 320GB SATA 3GB/S 3.5 7200RPM...
PATA SATA PROBLEM
This motherboard does support SATA. Check out the specs on the ASUS website:)
http://www.asus.com/products.aspx?l1=3&l2=14&l3=225&model=754&modelmenu=1
Dec 30, 2008 | ASUS K8V-MX Motherboard
Unable to detect 250GB Seagate hard disk on P4 PC
you need bios update
download bios express installation file
install first any 40 or 80 gb ide harddisk install windows and run express installation file
your motherboard will update your bios
download from http://www.updrivers.com/search/d845glly
or
http://www.updrivers.com/getdriver/Motherboard/Intel/D845GLLY-BIOS/10018.html
Oct 17, 2008 | Intel D845GLLY Motherboard
Sata drive not detected
just no other solution except upgrading BIOS properly
Sep 24, 2008 | Seagate Barracuda 7200.10 500 GB SATA Hard...
Intel D945GCCR Motherboard Logo
586 people viewed this question
Top Intel Computers & Internet Experts
Tony
David
David
vsri9
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
