My machine is not starting - Washing Machines
    Problem Solver:
  • 10 Answers
Well is it digital or dial is the outlet its pluged into getting power if its a gfc outlet it might have triped try pluging in a lamp or somthing of that nature into the outlet, if it works check if any of the cycles work, depending on the age of the machine is where you would start looking for the next solution
Posted on Oct 03, 2009
My Bosch 1244E will not go on I plug it and no power?
Washing Machine Won't Start - White Goods Help
www.whitegoodshelp.co.uk > ... > DIY Washing Machine Repair Help
Jun 21, 2013 - If wall socket & fuse are OK but washing machine won't start ... didn't work - so I tried plugging my Hoover washing machine into another plug and all systems are go! ... I have a bosch washing machine which is 16 months old.
Washing Machine Fault Diagnosis - How to repair
www.how-to-repair.com > Home > Washing machines
Nov 11, 2014 - Washing machine will not start, no power. ... So begin at the plugand make sure that there is power to the socket and that the fuse is okay ... I have aBosch washing machine which is leaking from underneath and the water is coming out the front at the bottom. .... It washes but won't go into rinse or spin.
Washing Machine Will Not Start - What To Check - How To Fix
removeandreplace.com/.../washing-machine-will-not-start-what-to-check...
Apr 10, 2015 - Be sure the washer is plugged into the electrical outlet in the wall. ... If the lid switch is faulty, then the washing machine will not start. ... If the lid switch is being pressed but no power is being supplied to the washers motor, ..... October 28, 2014; Bosch Washing Machine Error Fault Codes October 28, 2014 ...
Dishwasher Will Not Turn On - How To Fix ...
Jan 19, 2016 | Bosch Washing Machines
My washing machine wont start,its opening and turning on, all the lights are on but it wont run. Can you help me please
How to Fix Washer That Won't Start ' Washing Machine Repair
www.partselect.com/Repair/Washer/Will-Not-Start/
A broken washer means disaster in most homes which is why we've created this repair guide to help you fix a washer that won't start. While a washing machine ...
What to do when your washer won't fill, start or run - YouTube
? 2:00
https://www.youtube.com/watch?v=Atd5YHbRh7M
Jun 20, 2012 - Uploaded by searspartsdirect
What to do when your washer won't fill, start or run ... Front Load Washer Won't Drain or Spin Video: Washing Machine Tips from Sears ...
Troubleshooting a Washing Machine That Won't Start ...
www.doityourself.com/.../troubleshooting-a-washing-machine-that-wont...
If your washing machine won't start, begin by looking at the power source. ... mywashing has filled with water,now it wont agitate,it's like it is dead,could this be ...
Jan 14, 2016 | Washing Machines
Why won't it start?
Bosch WAS32461GB Washing Machine that will not start
www.how-to-repair.com/.../bosch-was32461gb-washing-machine-that-w...
Mar 31, 2015 - Bosch washing machine Will not start, won't start, Will not open - this is usually due to the machine still having water in it or a door interlock ...
My Bosch Washer Won't Start ' eHow
www.ehow.com > Home
If your Bosch washer does not start, there are a few troubleshooting steps to take before calling for ... Problems with Bosch washing machines that won't spin.
Bosch washer WFMC6400UC won't start - Appliantology.org
appliantology.org > ... > The Laundry Appliance Repair Forum
Jan 07, 2016 | Bosch Washing Machines
Outlet has power,circuit breaker is good. Has power to machine, able to see light on circuit board inside machine.
? 2:00
What to do when your washer won't fill, start or run .... In case awashing machine does not start and is ..
Oct 31, 2015 | Washing Machines
Smart drive 508 kelvinator washing machine The start button doesn't work. Machine turns on and all the lights and other buttons work but when you press start it doesn't start or start filling up.
WASHER WILL NOT START:
Power If your washing machine won't start, begin by looking at the power source. First of all, is the washing machine plugged in? If it is, has it tripped a circuit breaker or blown a fuse? Check and reset the breaker (or replace the fuse) if necessary.
Lid Switch The main control for the washing machine is the switch inside the lid. If this has stopped working for some reason, your washing machine won't start. It's not especially difficult to troubleshoot this on a washing machine. You might have to open the top to access the switch. With the power on, depress the switch and listen for a click. If you don't hear one, the switch MAY BE BAD and will need to be replaced. Confirm defectiveness with a multi meter checking for continuity OHMS. An open circuit reflects a bad switch..
If the switch works but the washing machine still won't start, check to see if your washing machine has a special fuse for the lid switch. It will usually be inside the control panel. If it's blown, you'll need to replace it before the washing machine will start.
Door Interlock The problem could be with the door interlock. If the lights come on but the machine won't start, this might well be the cause. This could either be down to the wiring that runs to the door interlock, or the door catch not activating the interlock itself.
Timer Knob Some models of washing machine use a mechanical timer knob and won't run until the water in the machine has filled to the selected level. If the knob doesn't line up properly with the graphics on the control panel, you can try to troubleshoot the washing machine problem by advancing the timer a little. When you've done this, pull it out a little way and see if the washing machine will start properly.
Overheating If you've run several loads, one after another, without any problem but suddenly find your washing machine refuses to start, overheating could be the cause. The simple way to discover whether this is the problem is to give the machine ample time to cool down, say for a couple of hours, and then try it again. If it works fine, overheating has been the problem and you may have a motor with bad windings.
Apr 13, 2015 | Washing Machines
How do I start my machine after I'm done positioning it.
Not sure what model sewing machine you have. Viking machines are usually started using the foot control (depressing the foot control will start the machine). Some models have a Start/Stop button that will start the machine sewing.
Hope this helps. Good luck.
Oct 21, 2014 | Husqvarna Sewing Machines
Hi there i am trying to start the machine for the first time, the dryer works, but i can't figure out how to start the washing machine. i use the same steps to start the washing machine, but no start. can...
Is this a NEW appliance? BE SURE TO READ THE INSTRUCTION MANUAL OR QUICK START.
If this is a used machine, perhaps there's something wrong that you need to check out. BUT......
Pushing-in the Timer wheel is sometimes necessary on the older machines--it's the round wheel with the wash/rinse/spin cycles imprinted on the panel, a "wheel" which turns to the various cycles as the machine operates. Many of them pull-out or push-in to operate the machine. Find the appropriate cycle and rotate the wheel to the corresponding location, then PUSH-IN. The washer should respond.
If there is a problem with the water supply entering the machine or other hazard the machine will shut off until it is repaired.
Oct 08, 2010 | Frigidaire FEX831CS Top Load Stacked...
Machine will not start, power is on but machine
suggest you check the door lock mechanism. If it is not latching correctly when the door is closed,the program will not proceed.
Jun 15, 2010 | Washing Machines
"START" ON MACHINE FUTURA CE-100
The start switch is the Led indicator buton. You will see it on page 12 of your manual. It is on the right of the needle bottom button.
Good Luck
Please Rate FixYa!
Dec 19, 2008 | Singer CE-100 Futura Computerized Sewing...
Washing Machines Logo
91 people viewed this question
Top Washing Machines Experts
