Question about Dell Latitude XFR D630 Notebook
Some of my Cd's get stuck and won't play a song or two. Also just lately my audio CD player sounds a bit ''bumpy'', not smooth.
  • 736 Answers
Make sure the CDs are clean .. you can wash them using a bit of hand dishwashing detergent and warm water.. dont worry about the label side .. just the blank side .. carefully pat dry... if it still has problems then you can purchase a "cleaning disk for your player" .. those run from a buck to $8 .. it looks like a normal CD but it has several soft brushes that sweep dust off the laser in your CD player .. if the player is used in a smokey area .. then you may need the laser professionally cleaned (dont know anyone that does that anymore) .. its also possible your laser is wearing out .. but if the problems are always in the same spot or repeatable, i would suspect damaged or dirty CDs, not the laser
Posted on Oct 03, 2009
  • Dell Master
  • 3,866 Answers
I have a feeling this needs to be replaced..
Based on what your describing your cd unit insde is giving it up early/late who knows but would need to be replaced..
Bose wave radio cd won't play cd's
If your CD is not scratched,the optical lens need replacement.
Apr 02, 2013 | Bose Awrc1g Wave Radio Cd Player Only -...
Cd error on my shaker 500 in my mustang do I need a new stereo or can I fix this. Thanks Dean
Hi Dean,
Although it isn't generally public knownage, the original "standard format" for recorded audio was established as ".wav" and is universally readable by vertually all cd players portable, auto and home systems, unless it is "designed" as an "MP3" player specifically and is usually noted somewhere on the unit. If you burn your own disks, although the file sizes are bigger (almost 2-3 times the bit size), they will be readable in alot more players. Recording in "MP3" format, you can get lots more songs on a disk however, you may notice the difference between the "sound" of the two different formats on the same song, it has to do with the "sample rate" and the "interpretation" of the sound by the format. (long explanation not important but, if you're interested you can find tons of information about audio anywhere on the web)
Many audio units read "both" as well as other audio formats that are "computer" or "digitally" created and are actually computer "languages" with different applications like ".WMA" which is "windows media audio", so, depending on the format of the disk you tried playing when you got the error code, it may be that simple, your unit cannot "read" the format the disk was created with and is telling you "cd error". The same thing would come up if you put a dvd or a computer cd in it.
If you only had trouble with that one particular cd, try a commercially produced cd or one you know worked before and so long as it plays you have your answer.
If other disks including commercial cd's won't play, you may have to use a "cd player cleaner", a disk designed to clean the optical laser inside the unit, they usually have tiny brushes on the disk and may or may not come with a cleaning fluid to use with it.
Hope this helps :)
Jul 04, 2011 | Car Audio & Video
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
Music Plays with Pauses on Bumpy Roads.
check its mounted securly if it is then lens will need cleaniing failing that lens will prob be on the way out
May 28, 2010 | Pioneer 12-Disc CD Changer for IP-Bus...
Rover 25 CD player wont play MP3 format discs
It sounds like your Rover dosn't have MP3 capabilities. You will have to use standard audio CD format (not data/MP3 format). You will only be able to burn about 15-20 songs but they will play in any cd player.
Aug 07, 2009 | Car Audio & Video
13N6769 will only rip the first few songs of a cd then freeze
if the disk plays to the end in your favorite player it is a software problem.
if it stops when only playing in approximately the same place it is a hardware problem.
That is the sort of incentive I would add to convince trial users to upgrade to the full paid product, perhaps your license code has been damaged
Jul 18, 2008 | Lenovo (13N6769) CD-RW/DVD-ROM Combo Drive
CD player skips
CD player will not open and play? Please as soon as possible. I have company coming over tomorrow, and I need my CD Player really bad.
Thank you
May 27, 2008 | RCA RS2663 Shelf System
How to set radio to play from the last song that it plays before turn off.
all CD players should do this. Who installed the CD player? Because it sounds like the memory wire isn't hooked up right. Does the clock keep the right time? If not your memory wire isn't hooked up right.
Jan 22, 2008 | JVC KD-G310 CD Player
Cd player
hi the gentle macanizem is bad probaply a thooth or a little wheel whats the qustion? you can spry a lubricant spry inside (through the little holes ) NOT ON THE LASER EYE!! it will smooth things out a little bit good luck
Dec 27, 2005 | Emerson NR303TT CD Shelf System
Dell Latitude XFR D630 Notebook Logo
57 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
