Question about Acer AC713 17" CRT Monitor
As soon as I login the menu display gets activated automatically
The automatically activated menu display stays on the screen changing the settings automatically unabling me to function.
  • Friendly PC Repair
    Friendly PC Repair May 11, 2010
    you're saying it trys to adjust the resolution then locks up? could be a video driver. is this a fresh windows or linux install
  • Acer Master
  • 4,924 Answers
If you dont know what caused this ... restore the system to an earlier date ...one when ya are sure that the problem wasn't present ..
Posted on Oct 03, 2009
What is the OPC light?
OPC_ Optical Picture Control
Automatically adjust the brightness of the screen.
You can change the settings in the menu option.
It's in Menu, then picture, then OPC.
OFF- The brightness is fixed at the value set in "Backlight"
ON- Automatically adjusts
ON: DISPLAY- Displays the OPC effect on the screen while adjusting the brightness of the screen.
If you don't want the silly display from popping up all the time, go into to menu and change the setting to ON; instead of ON: DISPLAY
Feb 04, 2016 | Sharp Aquos Televison & Video
How do you change the font size on a motorola defy for sms
If your Defy is running one of the leaked Gingerbread (Android 2.3) ROMs, go to 'Menu > Settings > Display'. There, you'll find a 'Font size' dropdown menu.
Otherwise, I can think of two approaches to try to workaround the lack of a font size setting under the menu settings: 1) If you you have updated your device to (or if it already came with) Froyo (Android 2.2) - it is avalable on the Gingerbread leaked ROMs too - go to 'Menu > Settings > Accessibility', and tick both 'Accessibility' (this one you can leave ticked for good) and 'Zoom mode' (for this one you'll get a confirmation popup screen). A magnifying square will appear. Untick this setting to remove it. Whilst active, you can move it around by tapping, holding and dragging any of the 4 stripes on its edges. You can also set the magnification level, by tapping on either '-' or '+' signs. If you don't want to keep activating and deactivating it whenever you need it, you can leave it partially hidden, by dragging it to one of the screen's corners, the one which would bother you less.
2) Install 'Any Cut', by Jeff Hamilton, from the Android Market. Then, tap and hold any empty area on any of your home screens, and select 'Shortcuts > Any Cut > Activity'. Wait for the list to be updated, scroll down, tap 'Display' (attention: it's NOT 'Display settings') anf 'OK'. Tap that newly created shortcut. Tap the arrow right below 'Font', select 'Large', and tap 'OK'
Hope you are able to sort your problems out soon.
Anyway, please, let me know if I can assist you any further.
Regards, Carlos
Sep 26, 2011 | Motorola Mobility Defy Cell Phone
How do you shut off the annoying Bosch Nexxt 500 Dryer wrinkle guard?
Click HERE to get the Users Manual for your machine, from what I can see, it's in the selection option of the machine.
From the manual:
Select the option to be changed with the "Menu" button. Press the button to move to the next option on the display. The active symbol starts flashing.
The current active option setting is displayed on the right. These settings can now be changed with the "Select" button. Press the button to jump to the next possible setting. Pressing the "Menu" button again saves the setting. If you don't press any buttons for 10 seconds the settings are saved automatically.
Hope this answers your question. Please rate and comment. Thank You
Joe
Sep 01, 2011 | Bosch Nexxt 500 Plus Dryer
I have hp mini with intel atom processor.it works with operating system windows 7.but there r many problems in it while installing tally 9 ..after installing tally 9 i opened it but an error msg is given...
on any pc if you get error "insufficient height to allocate".. then just set the dpi of your pc/laptop to 100%, (you can adjust dpi from display settings) and try to use tally, this might solve ur problem.
if the above doesn't solve ur problem, then go to screen resolution setting and select 800 x 600 resolution. this might solve ur problem to most extent.
if still u are facing the prob then go to display setting of windows and reduce the font size of menu, message box, active title bar, non-active title bar and etc... reduce fonts of all..
tats all
Jun 23, 2011 | HP Mini 1000 Netbook
How do i get my xerox C7600 to stop beeping?
1. Press the [Log In / Out] button on the left side of the Control Panel. The System Administrator Login screen will be displayed.
2. Enter the System Administrator Login ID using the numeric keypad on the Control Panel, and then select the [Confirm] button on the Touch Screen. The System Administrator Menu screen will be displayed.
NOTE: The System Administrator Login ID and UserID is '11111' by default. If an error is made, press the [Clear (C)] button and re-enter the ID. To cancel the operation, select [Cancel]. If the administrator has a problem with changing or has forgotten the ID, a service call must be placed.
3. Select the [System Settings] button twice. The System Settings screen will be displayed.
4. Select the [Common Settings] button. The Common Settings screen will be displayed.
5. Select the [Audio Tones] button.
6. Select the required option from the list, and then select the [Change Settings] button.
7. Select the [Save] button to save the settings.
8. Select the [Close] button several times, and then select the [Exit] button to exit.
Thanks & regards.
Jun 03, 2011 | Xerox Workcentre 5225 / Copier, With...
My screen stays blank when I turn on. Lights blue and green come on but screen stays blue
If your display settings aren't set to automatic this can occur. Example: if you have set resolution to 1080i and are trying to play it on a display that has 1080p you will get a blank screen or no signal message. you will have to connect your PS3 to the last display you had an image on and change the "display setting" to "automatic" for your PS3 to work on all displays. when you choose a specific resolution to the "display settings" it will only work on that specific resolution. hope this helps.
Feb 15, 2010 | Sony Playstation 3 (PS3) Console
How to give ip address to workcentre m133 network printer
: You must be a System Administrator to perform this solution. 1. Press the [Log In / Out] button on the Control Panel. The Login screen will be displayed. 2. Enter the System Administrator userID using the numeric keypad on the Control Panel, or select the [Keyboard] button on the Touch Screen to enter the userID, and then select [Save] on the Touch Screen. 3. If necessary, enter the System Administrator password using the numeric keypad, or select the [Keyboard] button to enter the password, and then select [Save] on the Touch Screen. NOTE: The default userID is 11111, and the default password is x-admin (must be entered in lower case). If the userID and / or password have been forgotten, a service call must be placed. 4. Select [Confirm] on the Touch Screen. The System Administrator Menu screen will be displayed. 5. Select [System Settings] twice. The System Settings screen will be displayed. 6. Select [Network Settings]. The Network Settings screen will be displayed. 7. Select [Protocol Settings]. The Protocol Settings screen will be displayed. 8. Select [TCP/IP - Get IP Address], and then select [Change Settings]. The TCP/IP - Get IP Address screen will be displayed. 9. Select [Manual], and then select [Save]. The Protocol Settings screen will be displayed. 10. Select [TCP/IP - IP Address], and then select [Change Settings]. The TCP/IP - IP Address screen will be displayed. 11. Enter the machines IP Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 12. Select [TCP/IP Subnet Mask], and then select [Change Settings]. The TCP/IP Subnet Mask screen will be displayed. 13. Enter the machines Subnet Mask using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 14. Select [TCP/IP Gateway Address], and then select [Change Settings]. The TCP/IP Gateway Address screen will be displayed. 15. Enter the machines TCP/IP Gateway Address using the numeric keypad, and then select [Save]. The Protocol Settings screen will be displayed. 16. Select [Close] three times. 17. Select [Exit]. The machine will reboot automatically.
Jun 09, 2009 | Xerox WorkCentre M15i Laser Printer
What is "OPC"? It comes up and goes away.
Apr 20, 2009 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
I can't access any email or messenger account
I encountered this problem last night. I had gotten a virus that changed my lan settings, and even after I removed it the lan settings stayed.
Right click Tools from the Menu bar in Internet Explorer. (If you dont have a menu bar, right click the gray part below the url bar and select Menu Bar from the drop down list)
Select Internet Options from the bottom of the list.
Select the Connections Tab, 5th over at the top.
Click the LAN Settings box torwards the bottom of the page.
Make sure that "Automatically Detect Settings" Is checked, and NOT Proxy Server settings.
Apply changes, close Internet Explorer and reopen.
This should solve your problem.
Mar 24, 2009 | Yahoo Messenger
Pebl U6 I have a menu at the left of my screen but can't figure out how to remove it. The phone seems to have limited funtions. I owned one before this one and didn't have this problem, would...
show/hide menu icons
Show or hide menu feature icons in the home screen:
menu > Settings > Personalize > Home Screen > Home Keys > Icons > Show or Hide.
change menu icons & home keys
Change menu feature icons, soft key labels, and smart key function in the home screen:
Menu > Settings > Personalize > Home Screen > Home Keys.
external display
Set external display orientation:
Menu > Settings > Initial Setup > External Display > Left Orientation or Right Orientation.
language Set menu language:
Menu > Settings > Initial Setup > Language scroll Set the highlight bar to stop or wrap around in menu lists:
Menu > Settings > Initial Setup > Scroll.
ringer IDs Activate ringer IDs assigned to phonebook entries and categories:
Menu > Settings > Ring Styles > style Detail > Ringer IDs
ring volume a > Settings > Ring Styles > style Detail > Ring Volume.
keypad volume
Menu > Settings > Ring Styles > style Detail > Key Volume.
Mar 30, 2008 | Lands Phones
Acer AC713 17" CRT Monitor Logo
133 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
