Question about Kenmore 22422 Top Load Washer
I have a different problem. My washer will pump
I have a different problem. My washer will pump and spin but it will not fill? What's the fix?
    President:
  • 1,304 Answers
Sounds like a water selonoid, or maybe just clogged water screens
Posted on Oct 03, 2009
My washer has slow drain and won't spin out completely. What might be the problem?
Repairing a Washer That Won't Drain or Spin ' ThriftyFun
www.thriftyfun.com/Repairing-a-Washer-That-Wont-Drain-or-Spin.html
Did everything look at everything that has to do with slow water draining. ReplyWas ... My washer washes fine, but it won't drain the water out or spin on any cycle. The guy who .... My Kenmore 417 washer will not completely empty and spin.
my washer won't spin and empty? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jan 15, 2008 - If your washer spins but doesn't pump the water out, the drain line is probably clogged. In many washers, a small sock or other piece of clothing ... My Whirlpool washing machine won't empty all of the water after ...
Mar 21, 2013
Clothes washer won't spin clothes to drain water out?
Jun 11, 2008
More results from answers.yahoo.com
Why won't my washer spin or drain? - Kenmore 110 Series ...
https://www.ifixit.com/.../Why+won't+my+washer+spin+or+drain
iFixitMar 16, 2014 - Belt, Water Pump If the washer won't drain the pump belt might havebroken or might have worn ... It will fill with water but won't spin or drain on its own. ... Keep in mind that any water in the washer will pour out of the hoses when removed. ... I would have had to take apart entire washer to fix clogged pump.
My washing machine won't drain - LaundryDoc.com
www.laundrydoc.com/Washing-Machine.../My-washing-machine-wont-...
If your washing machine will spin but it won't pump water out, then the drain line is probably clogged up. In most washing machines, a small sock or small piece ..
Jan 05, 2016 | Washing Machines
My washer wont fill up or spin on spin cycle. its not a front loader
SOUNDS LIKE A BLOCKED HOSE SOMEWHERE OR OBSTRUCTION IN WATER PUMP
Apr 08, 2014 | Frigidaire Washing Machines
Older maytag stackable washer and dryer combo washer fills , washes and spins but water wont pump out
check for the pump belt broken or off,clogged pump or sock or small item clogging the tub outlet to pump hose. the pump pulley may have become loose on the shaft also
Feb 28, 2013 | Maytag LSE7806A Top Load Stacked...
Washer fills, agitates, will not drain or spin
check your lid switch ,or debriss in drain pump ,pump can not run will not spin untill machine waterlevel switch comes below a certain level of water pressure
Jan 22, 2013 | Hotpoint 3.2 Cu. Ft. Super Capacity Washer
My siemens washer will not pump the water out or spin
Sounds like your pump went out on the machine. They are not ease to replace though. You might want to kall some one out to fix.
Dec 16, 2008 | Frigidaire ATF6000ES Front Load Washer
May tag washer spin cycle wont spin
check the pump ,,, if pump wont pump out the washer wont spin till it gets down so low / larryyb
Dec 05, 2008 | Maytag PAV2300 Top Load Washer
Washer fills with water but will not agitate to wash the clothes.
REPL/ PUMP GRINDING NOISE IS BROKEN IMPEELER INSIDE PUMP SHOULD FIX PROBLEM
Nov 30, 2008 | Frigidaire GLTF2940E Gallery 3.5 Cu. Ft....
Kenmore 2 Way Tumble Action Front Load Washer
no thats two different problems. The rubber piece (boot) forms a seal to prevent the water from leaking out, that should be replaced. Water might have leaked and ruined the pump. At the end of all cycles is there still water in the tub? If so your pump is either clogged or has gone bad, and thats why the washer wont go into extract.
Jul 09, 2007 | Kenmore 44102 Front Load Washer
Troubleshooting your problem LG Washer
you may find that you need to dismantle the pump as you can get things inside the impellor area causing intermitant problem
May 30, 2007 | LG WM-1832C Front Load Washer
Kenmore 22422 Top Load Washer Logo
Sal DeAngelo
fordexpert
Ed Mac
