Question about Plumbing
Electric motor for swimming pool pump was immersed in water. how do i get it to run again
    President:
  • 1,378 Answers
If there is no permanent damage, it needs to be dried out to eliminate the ground likely caused by the flood. Your best bet would be a fan or small forced air heater left blowing on it for a few hours. If you can, read resistance from the line connections to ground and once that reading is infinite, you can hook the motor back up and run it. You may find mechanical damage from the flood also, such as bearing noise. If it is present, you'll want to fix that sooner than later as the longer you wait, the more damage and chances of possible total failure go up. increases
Posted on Oct 03, 2009
Testimonial: "useful advice that I knew already but was reassured to know I was doing the right thing"
2 hp Swimming Pool - Jet / Well Pump Motor / Century B124: Water pump from swimming pool to filter lost it's ...
NOT THE MOTOR ,THE SEAL... JET PUMPS ARE NOT FOR POOLS.. LOW FLOW HIGH PRESSURE.. YOU NEED HIGH FLOW LOW PRESSURE ... IF NOT YOU MAY HAVE A SUCTION LEAK OR A BAD SHAFT SEAL... VOTE JAY
May 17, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Pump motor not operating
The pump is defective and will need to be repalced.
May 16, 2010 | Intex 1000 Gallon Swimming Pool Filter...
1 HP electric motor hums but not turning.
check for a re-set button somewhere on the motor housing.
May 02, 2010 | AO Smith Pool Pump Motor Hayward Swimming...
I have swimming pool but it dosent have drainage so its short of big water tank, i want to keep it filled with water ,,what shouod i do to keep that watre clean and smell free
LOL,, well if your serious about that then a carbon fish tank filter unit, and an aquarium air pump and aerator stone should do nicely, if you actually want to turn your Kenmore swimming pool into a washing machine again then you will half to look underneath the unit and find the water pump, follow the drain hoses, this pump may be belt driven or have a separate motor to run it, insure the belt is still on and tight or put in drain mode and see if the electric pump is functioning, if all is OK check to see if there is a filter that is plugged, when you made it this far let me know and i will help further good luck
Apr 28, 2010 | Kenmore 15864/15862 Top Load Washer
Pool won't drain
must replace motor the cooling fan is damage and the motor is over heating whrn the motor coll down it will start again
Apr 21, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
Plumbing Logo
Top Plumbing Experts
Andrew Bugbee
Tom Chichester
Gil Shultz
Are you a Plumbing Expert? Answer questions, earn points and help others
