Question about Homelite Mighty Lite Lawn Trimmer
Can I get a manual in Greek for a homelite F2020.
2 Suggested Answers
  • 110 Answers
SOURCE: i have a homelite f2020 series petrol trimmer i
I use 50:1 with Sthil 2-stroke oil in ALL my 2-stroke equipment. This ratio does not smoke at all, and does not foul plugs.
Never had a problem yet. At this mix ratio, you can also use it in 4-stroke engines, which means you only need 1 fuel can on site. Also eliminates the possibility of using the wrong can to fill the trimmer.
Posted on Jun 16, 2010
What is the corrector part number for carburetors fitted on homelite line trimmers model F2020 UT2078
Your missing the last digit of the model number.
UT-20788 and UT-20789 uses the UP00608 carburetor which is a ZAMA C1U-H39.
Mar 28, 2015 | Homelite Garden
How do I start an homelite whipper snipper model f2020 this one I have never started from new it's about 3 years old could be older it's never even had any fuel in it up to now
First make sure the on/off has tried in both directions. Even here in the shop I sometimes forget to set those switches that don't have the momentary off postion.
Then if still doesn't start then I would treat it as if run at sometime and go thru the basic troubleshooting of a won't start engine.
  • Check for spark. No equals ignition problems.
  • If you have spark then
  • Try putting a little fuel mix in the cylinder via the spark plug hole to see it will try to start. if tries to start then carburetion problems. Yes even with an used carburetor.
  • If still don't try to start then check for compression and timing related problems.
Jan 06, 2015 | Homelite Garden
I am greek, and I have a panasonic kx tga110ex, dows anyone know how can I put the volume up or find a manual in greek?
to find a manual, go to yahoo.com down load the manual, then go to google translate.com and paste the manual to the page and select the language you want to translate too
Dec 11, 2014 | Panasonic Lands Phones
Homelite trimmer F2020
One of the most common failures would be the smallest air leakage in the pickup tube. the siphon effect is cancelled by an air leak too small to see. If the trimmer will start momentarily or "pop over" when fuel is administered directly through the venture or spark plug hole then the issue is definitely fuel delivery. bad diaphragm, swollen fuel lines or a blockage in the main jet or venture tube.
Oct 24, 2017 | Tools & Hardware - Others
I purchased a model f2020 weed eater from bunnings naenae the line cartridge broke up and i went to get a replacement from bunnings they don't stock homelite parts but ordered one for me i have been...
You can order the part from www.homelite.com You will need your model number to help you select the right part. You will need to click on the order parts text in the upper right hand part of the screen. This will take you to another page which will ask you to go to the homelite parts catalog. After you click on the parts catalog link, it will ask you to agree to the terms of use for the website. READ THIS CAREFULLY.
After you have agreed to the terms of use it will take you to another page. From here you can input the model number of your unit. Input the f2020 into the search box and click on search. It will ask you which version of the model you have. On the right side of the screen it will have a parts breakdown. You should select (Shaft-Spool and String- Grass Deflector). This will pop up a diagram with a parts breakdown which will include part numbers to help make ordering the correct part easier. I believe the part that you wish to order is part number 17 of the diagram. When you click on the part number in the diagram it will select it below the diagram and will flash for a second. At this point it has an option to add this part to your shopping cart.
I hope this helps get you back in business.
Apr 02, 2011 | Homelite Mighty Lite Lawn Trimmer
I have a homelite f2020 series petrol trimmer i would like to know the petrol and oil ratio mixture please
Jun 16, 2010 | Homelite Mighty Lite Lawn Trimmer
I want the user's manual for nikon d60 in greek and where i can find it without pay?
Start with http://www.nikon.gr
I don't read Greek, but I'm confident they'll have a manual there.
Feb 28, 2010 | Nikon D60 Digital Camera
Homelite Mighty Lite Lawn Trimmer  Logo
157 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
