Question about Autodesk AutoCAD 2010
I recently openned a file from a friend and since then my autocad has got me crazy i have to run everythig under commands, ie: if i select something ang press the delete key it doesn't works, if i double click a text it doesn't works, if i select an object and want to change it from layer nothing happens, i have to make it by commands e, ed, ma, respectively....
Found it thanks
it's the command _PICKFIRST
you've got to set the vaalue to 1
Posted on Oct 03, 2009
  • 729 Answers
Try to reinstall the software you use and do not open that file again, I think it must be bad
To do that simply uninstall the software, reboot the computer and reinstall the software
Hope that helps
Have a nice weekend
Please rate my answer
    Scholar:
  • 98 Answers
I would recommend that you uninstall auto-cad and reinstall it. This is only if you have the CD and a product/serial key. A important file got corrupted when you open the file and possibly edited. the best way to fix the problem is do what i recommended, but then again you mush have the things i specified too.
Autocad changes lost
The most effective solution is .dwg recovery tool when other methods don't work
The place where you may read various thing about Autocad
Here you may read more about article below
However, a few things may get it to open:
  • Try to open the drawing file directly instead of using the Recent Documents menu.
  • Check that the storage location that holds the drawing is working properly.
  • Use the RECOVER and RECOVERALL commands on the drawing.
  • Attempt to insert the damaged file into a clean drawing or template using the INSERT command.
AutoCAD Recovery tool How to repair corrupt AutoCAD drawings and fix its errors Error Drawing file is not valid when opening file in AutoCAD
Aug 28, 2017 | Computers & Internet
How to view damaged dwg file of autocad?
Try using a different version of AutoCAD to open the drawing, such as AutoCAD 2013 vs. AutoCAD 2015 or plain AutoCAD vs. AutoCAD Architecture, etc. Try different computers if available. or try DWG Viewer Tool on website:http://www.ask.com/answers/722146801/how-to-view-corrupted-autocad-drawing?qsrc=14106
May 29, 2015 | Autodesk AutoCAD Electrical 2013
Corrupt DWG files
AutoCAD RECOVER command?
If doesn't help, try it:
DWG Repair Kit
This professional AutoCAD DWG repair tool features a uniquely efficient data analysis core and an interface that both professionals and novices with appreciate. The program will show you how to repair DWG files online in seconds even if you have never worked with data recovery tools of any sort!
For more information: http://www.dwg.repair/
Also look here: https://social.technet.microsoft.com/Forums/en-US/fb2d8693-9551-43b7-9310-584471d60a56/autocad-files-corrupted?forum=w7itproappcompat
Feb 17, 2015 | Autodesk AutoCAD 2007
Autocad hanged
1. Please check your computer specifications. Normally 2010 Autocad, require a good ram and video card.
2. It also hangs when opening a lower version of cad file.
Jan 12, 2010 | Autodesk AutoCAD 2010
When I open a file that is associated with autocad, autocad opens the file and the program at the same time. But if I already have autocad open and click on another file, instead of autocad opening that...
Turn off your single document interface. Type OP and hit enter. Then select the system tab and check off the SDI (it should be towards the upper right of the dialogue box.
Nov 24, 2009 | Autodesk AutoCAD 2006
Autocad 2010 problem
If you run Win7 in XP mode, all should be fine.
May 06, 2017 | Autodesk AUTOCAD LT 2008 SLM 10 SEATS...
Opening dwgs in autocad
In the past the fastest way to fix this is to go directly to the file and try to open it. It is possible that file or database has been corrupted. In some instances the file type dwg is not associated with autocad and the application hangs because it is looking for .dwg as an associated file type to autocad.
Let me know if you need further clarification.
Apr 08, 2009 | Autodesk AutoCAD 2004 for PC
Opening dwgs. in autocad 2004
Try rebooting your computer, then relaunch AutoCAD. If your .dwg file will not open then open the backup file. Sometimes the .dwg file goes crazy and the backup file will save your life, most of the time. Also make sure that your machine has enough memory to run AutoCAD. Memory is either your best friend or your worst enemy when working with AutoCAD. I hope this helps.
I keep getting the same message while using autocad 2002lt
There are a few things to try. I'd try this first: Start ACAD and use the Recover command (File menu) to open your drawing. If that doesn't you can insert your drawing into an empty drawing as an exploded block and/or purge your drawing.
Dec 17, 2008 | Autodesk AutoCAD LT 2002...
Autodesk AutoCAD 2010  Logo
116 people viewed this question
Top Autodesk Computers & Internet Experts
JM Computer Service
JM Computer Service
Jerry
Jerry
Are you an Autodesk Computer and Internet Expert? Answer questions, earn points and help others
