Question about Microwave Ovens
My kennmore microwave 72163992303 wont get hot
  • 1 more comment
  • wayne rodgers Oct 04, 2009
    kennmore microwave won"t get hot.
    normal microwave
  • Kimbo too May 11, 2010
    is it a convection microwave?, or just a normal microwave?.
  • 75 Answers
Most likely the magnetron has died. May be cheaper just to buy another one.
Posted on Oct 05, 2009
Where is the manual fo the Kennmore 721.63763300?
The manual might be obtainable from Sears.
May 04, 2014 | Kenmore Microwave Ovens
How do I replece the fuses on a Kennmore Convection Oven #721.63763300?
The outer housing will have to be removed to gain access. Be sure to read and heed the high voltage warnings.
Shm1816s Samsung microwave oven wont shut off All lights off turn table not turning but you can hear the humming. the turn table plate gets very hot.
if the turntable is getting hot it means that the microwave is working but as the turntable is not turning , it means the adjustment of the door lock of your microwave may have become improper due to use.may be it got damaged.
call the technician of samsung microwave ,he will open the cabinet of microwave and make the adjustment of door lock proper.
Thanks
Nitin
Oct 19, 2013 | Microwave Ovens
Can't unlock kennmore microwave, tried the start, stop/clear button it does not work
holding the stop / clear button for 5 seconds or the start button for 5 seconds usually works,
see this link
http://www.fixya.com/support/t8306273-unlock_digitals_butons
Feb 14, 2013 | Microwave Ovens
Kennmore ultra wave shut off and F-9 message on display
LG's service manual troubleshooting section suggests the F9 code could be due to line voltage, magnetron, inverter module, "Relay 2", or a loose connection between door/magnetron/control PCB (Power Control Board).
Other indications might help narrow down these choices before having to pull out your multimeter and crack open the microwave case; for example, if the microwave works, but heats slowly, then the troubleshooting manual narrows your choices down to magnetron or line voltage problems, and pretty much rules out the other possiblities.
In other cases, F9 error code indicates an inverter failure. This can sometimes by caused by a power surge or glitch through the electrical lines. You can sometimes clear this fault by completely unplugging the microwave for 1 minute. Plug it back in and see if the fault code returns. If it does, then you have an internal component failure that will need to be serviced by a technician.
Hope this helps (remember to rate this answer).
Sep 09, 2011 | Goldstar MV-1515 Microwave Oven
My model# sbm7500w sunbeam microwave is apering to be working but wont get hot
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
May 05, 2011 | Sunbeam SBM7500W Microwave Oven
Wont get hot
heatman101
How to change the fuse in a kennmore microwave
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Feb 27, 2011 | Kenmore Microwave Ovens
Microwave oven wont get hot
heatman101
Sep 22, 2010 | Kenmore 62622 Microwave Oven
The timer works, but the unit isn't cookinj
Most likely the magnetron went bad if you try to warm up or cook something and it wont get warm/hot. The device looks like this inside the microwave, http://img.alibaba.com/photo/226640575/Microwave_Oven_Magnetron.jpg. It will need to be replaced, or you may want to just replace the microwave.
Nov 09, 2009 | GE XL1800 1100 Watts Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
