Question about NEC MobilePro 900 Handheld
Setting my dialup
I need setup for dialup or where is the setup wizard
How can Idial my friend
Posted on Apr 20, 2008
How can i connect my samsung s5350 with my computer. I use BSNL service provider with 3G. Please reply in details. Thanking you.
s5350 has an inbuilt modem meaning you can use it as a modem on pc. all you need is samsung suite or just load the proper drivers for your samsung.. it will also load the modem part of it. then get the dialup settings and input them manually on connection setup. setting i mean are mostly the APN and dialup number.. username and password.
Pist back for followup
Nov 25, 2010 | Samsung Modem Configuration Software...
How do i set my lg rumor to data/modem setting
1. Get GPRS activated on your phone number from your service provider. 2. Install the PC suite of LG on your PC. That means install the phones drivers. When you do this all drivers including that of phone ad modem will be installed. 3. Ask you service provider for the following info a) IP Address. b) Proxyport Number. c) Proxy Port settings. d) APN. And set then to your phone. 4. Connect the phone to the PC and allow Windows to detect the phone and load its drivers. 5. Go to Control Panel->Network Connections. 6. Setup the dialup connection for your phone modem. 7. Your service provider will also give you the number to dial from your dialup connection. Enter that in the dialup. 8. Connect. The connection will take around ten seconds. And you are on.
Nov 25, 2009 | LG RUMOR Cellular Phone
How I make a call on the huawei EG162g usb modem?
assuming that u r a professional n using a dialup broadband connection..
install itz driver (that usually provided with a cd or download frm the internet)..connect the modem..wait and verify if the device is detected.. start menu->settings->control panel->network connections->new connection wizard->click 'connect to the internet'->next->setup my connection manually->next->connect using a broadband connection that requires a user name and connection->next->provide 'isp name'->next->give 'user name and password'->next->finish..
hope itz ready..
for supervision contact ur system admin/vendor....
Oct 30, 2009 | Computers & Internet
Setting up dialup modem for Medion Akoya E7330D
go to control panel -> phone and modem options -> modem ->add ..............Thanks
Oct 04, 2009 | Computers & Internet
DSL-2640U connect to internet but want to setup second dialup connection from pc
Sounds like you have high speed internet and also want a dialup connection as well. Maybe as a backup.
Anyway, your pc will need have a dialup modem installed in it.
If you already have one installed then you will also need a dialup ISP account. Some times an ISP will provide dialup in addition to broadband. Ask you ISP or call AOL.
Sep 05, 2009 | D-Link ADSL2/2+ Modem/Wireless Router...
Have an acer aspire, just got high speed internet, will not connect. is there something i need to activate so it will work. worked fine with dial-up and can use wi-fi. internet company says it shows i'm...
Check your network settings. It is probably still configured for dialup. You probably need to deactivate the internet setup for the modem, then run the setup wizard for the lan connection again.
Apr 10, 2009 | Acer Aspire 3680 Laptop
Dialup link problem
Are you trying to set up router ?
You can set up your router manually, without the CD.
Make sure that your computer is able to go online directly through the modem.
If your computer is able to go online through the modem, that means the modem is working fine.
You will need to connect the computer to the router and the modem to the router.
open the set up page of the router and change the settings of the router according to the ISP.
Apr 02, 2008 | Paradyne COMSPHERE 3910 Modem
No modem
put your modem in another pci slot and try again.
Dec 08, 2007 | Acer Aspireā„¢ T180 PC Desktop
Setting up an MN700 Base Station with dialup
1. disable all ICS and all Proxy settings on all machines 2. connect the NIC to the MN700 using Port 1 3. set up the MN700 and the wireless connection 4. switch the MN700 to Bridging mode 5. enable ICS on the host computer The basic object is to have the working connection for your dial-up, then set up the base station as an access point only, then share the working connection via ICS through the NIC. Quite similar to having a switch box, but you're going wireless with it. You don't need to feed the MN-700 any of the normal info like your Internet Service Provider's IP/DNS, etc., because your computer already is sharing that info.
Feb 19, 2006 | Microsoft MN-700 Wireless Router
NEC MobilePro 900 Handheld Logo
19 people viewed this question
Top NEC Computers & Internet Experts
parusdi rusdi
Level 1 Expert
Steven Wander
Steven Wander
Alun Cox
Are you a NEC Computer and Internet Expert? Answer questions, earn points and help others
