Question about Toshiba 310CDT Keyboard
Want to do backward slash; the key only performs # and no slash. also want @ to appear when I use the key showing that sign (currently use the " sign to get it)
    Problem Solver:
  • 8 Answers
I know this post is years old, but I recently needed a solution to the same problem, and the previous response was a bit lacking. Anyway, I had the same #-/ issue, it was a regional setting where my US keyboard was set to UK english. Alt-shift allows you to switch between language settings. If this doesn't work, modify them in control panel's regional settings.
Posted on Jan 04, 2013
  • 657 Answers
The back Slash would be above the ENTER key and the @ sign can be accessed by holding SHIFT and pressing number "2"
In case you are not able to get the desired keys normally. It is possible that there may be something stuck between the keys. I would suggest you to kindly remove the keys and clean the base.
Posted on Oct 03, 2009
Question mark key and slash plus 2 keys above it have turned to eee with accent above
https://support.microsoft.com/en-ca/kb/258824 - I suggest you check out this article - or you can google yourself - How do I change my Keyboard Mapping? and then see what comes up.
I would appear that you have somehow setup something on those keys - e with an accent above is most likely French
May 28, 2016 | Logitech Computers & Internet
What is the difference between forward slash and backward slash
forward slash aka slash tips forward - /
Backward slash aka back slash tips backward - \
Nov 26, 2012 | Computers & Internet
Beeping with f and e showing
BMP accepts the following options: -h, --help Show summary of options. -n, --session Select BMP/XMMS session (Default: 0). -r, --rew Skip backwards in playlist. -p, --play Start playing current playlist. -u, --pause Pause current song. -s, --stop Stop current song. -t, --play-pause Pause if playing, play otherwise. -f, --fwd Skip forward in playlist. -e, --enqueue Don't clear the playlist. -m, --show-main-window Show the main window. -v, --version Print version number and exit.
ford performance chip.
May 25, 2012 | Kitchen Ranges
How can I get the slash sign?
To type a slash going from the lower left to the upper right (like this / ), hit the key to the right of the full stop key on your keyboard. To type a slash going from the lower right to the upper left (like this \ ) hit the key to the left of the z key on your keyboard.
The kind of slashes used in web addresses are forward slashes, that is going from lower left to upper right e.g. http://www.fixya.com/
May 18, 2011 | Computers & Internet
The question mark is over the number 6 and shows as A triangle. The backwards slash shows as an A with A mark over it. What is going on.
go to the two letters in the taskbar[EN] remove all keyboards and add new ones and it will be fixed
May 10, 2010 | Acer NSK8458AN Keyboard
CHANGE THE TIME ON MY PANASONIC 7453
To set date and time on your phone system you must first enter user programming mode.
Using a display phone with the receiver hung up.
Press PROGRAM
Dial ** 1234 (SYS PROG NO)
Dial 000 (DATE AND TIME)
Press SP-PHONE key once (display shows current date)
Normally this is correct if not dial the changes in with your keypad. Use the FWD\DND key to
move forward on the display and the CONF key to move backwards.
Press AUTO DIAL STORE (Confirmation tone)
Press SP-PHONE key once (display shows current time flashing on hour)
Dial new hour (Two digits) Use the FWD\DND key to move forward on the display and the
CONF key to move backwards. Dial in any changes and when your done:
Press HOLD (SYS PROG NO)
Press PROGRAM
Your phone should be back to normal.
Mar 14, 2010 | Panasonic KX-T7453 Corded Phone
Odd characters appear.
Ensure your Keyboard is set to your proper language, Under Control Panel, Regional and Language Options!
Apr 15, 2009 | Computers & Internet
Slash / sign and other symbols
Hold down the shift button and press the letter V. Everything printed above the letters on the background of the keypad can be printed by holding down the shift key and pressing they letter key.
Hope that helps.
Jan 24, 2009 | Dymo LetraTag QX50 Thermal Label Printer
Key board functions
the backward slash is under the question mark key
Oct 05, 2008 | Compaq Presario Notebook
Computers & Internet Logo
694 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
