Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
My printer brother 165c does not print the black color
SOURCE: i can't print in black
You'll need to see the manual on how to do a head clean.
Posted on Jun 07, 2009
CW Oly
  • 240 Answers
SOURCE: black dots on printed page from Brother 9440 color laser printer
The problem lies with the black toner cartridge. This is a common problem in these machines due to poor design by Brother. Best solution is to replace the offending color toner cartridge.
Posted on Jan 19, 2010
  • 164 Answers
SOURCE: My brother printer dcp-165C can't print black
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Time necessary 45-50 minutes
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
PROCEDURE:
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your printer in new condition.
Hope this helps. .
Posted on Feb 08, 2010
n1wgk
  • 84 Answers
SOURCE: nozzle clogging on the Brother DCP-165C multifunction printer
take swabs and use alcohol to manually clean it...GENTLY and with not too much alcohol. You will go through several swabs. Use the foam swabs, not cotton, so you don't leave junk behind.
Posted on Mar 07, 2010
supertech6
  • 513 Answers
SOURCE: Brother DPC-165C has 'Init Unable AF' error
Yup. I suspect the head has been removed from the unit. There are adjustments on some printers. It was assembled wrong. The grating noise is likely the auto cleaner. If it cannot go 'home' the unit will not initialize. Possibly the head detect sensor is broken or covered. If the head will not home (moves out and back more than once or slams home hard), 'Init Unable AF'. You may be able to order a service manual from Brother for this. A repair shop can order the manual as well. (I suspect you need a new print head as well. You might want to replace the printer) see tips on bubblejet printers.
Posted on Mar 20, 2010
Brother dcp-165c print unable 50
how ca n i fix my brother dcp 195 c unable 50?
Nov 21, 2010 | Brother DCP 165C Compact Color Inkjet...
What are the procedure to use only black ink using brother DCP-165c?
Description of Problem 100000016244
Can I print using only the black ink cartridge when any of the color cartridges are empty? Grayscale
Description of Solution 200000023550
To view information and instructions with graphics please go to the website listed below:
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/002400/000061/faq002461_001.html?reg=us&c=us&lang=en&prod=mfc6490cw_all
Jul 10, 2010 | Brother DCP 165C Compact Color Inkjet...
I have a brother DCP-165C and it is not printing black.
The nozzle may be blocked. So take out the colour cartridge and place its nozzle in a bit of water for about 10 mins. Bring it out and dab the nozzle with folded paper. If the tissue is blotted with the three colour it means you have unblocked the nozzle. Try now to print after returning the colour cartridge. You may need to repeat to get good results.
Thank you!!
Jul 12, 2010 | Brother DCP 165C Compact Color Inkjet...
How can i fix my printer which does not print those that are colored black. my printer is brother dcp-165c. whenever i print a document, the printed output does not show any black ink
there is a strong chance that either the black cartridge has run out and will need replacing or the cartridge itself is blocked. i would first check the manual on the printer for an option to clean the cartridges.
failing this within the software on your PC for the printer there should be an option to clean the cartridges. this should sort the problem out.
if not i would purchase a new cartridge for the printer and replace the one that is in it at present to see if this resolves it.
Dec 30, 2009 | Brother DCP 165C Compact Color Inkjet...
New Brother won't print black
Take the printer back to where you got it from and exchane it for another one...
Jul 08, 2009 | Brother DCP 165C Compact Color Inkjet...
1. Paper Jam 2. No black color
for Paper Jam when using photopaper please check below
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000400/000095/faq000495_033.html?reg=us&c=us&lang=en&prod=dcp165c_all&Cat=4
http://welcome.solutions.brother.com/BSC/public/us/us/en/faq/faq/000000/000500/000069/faq000569_006.html?reg=us&c=us&lang=en&prod=dcp165c_all&Cat=4
I can't print in black
Jun 07, 2009 | Brother DCP 165C Compact Color Inkjet...
My brother dcp 165c wont print in black
Hello, please make sure that your cartdridg is well installed and that you took off all protections on it. Unplug your printer from the ac dc and replug it...
May 31, 2009 | Brother DCP 165C Compact Color Inkjet...
Printer wont print black.already replaced with new ink but still wont print black
did you take the tape off the new cartridge and is the print head burned out for the black? if you installed the diagnostic's on it then run it and see what it says, otherwise expect the print head to be cooked, however it is possible to get a bad ink cartridge try tapping it on your finger and see if ink comes out if it does not then the ink cartridge is dried out or no good, about %15 of print cartridges are bad on just about any brand printer some more than others.
Brother DCP-165C Printer not printing black
dear sir,
1- replace cartridge
2- HVPS replace
your problem would be solved.
Feb 16, 2009 | Brother DCP 165C Compact Color Inkjet...
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
245 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Samyfam
Samyfam
