Question about IBM ThinkPad T30 2366 Notebook
My IBM t30 wont boot up
Whilst i was using my laptop for games it crashed on me. I tried rebooting it after it shut down and it came up with blue screen sayin unmountable boot volume . ive tried usin the IBM BIOS setup utility and that wont work ive also tried the advance setup nd tht also wont work . I dont know what to do next . Can you help ?
  • climbharder Sep 17, 2008
    I also need to reboot using this method but I bought the Laptop on ebay and I do not know the Admin Password so I keep getting an "incorrect password " prompt.
    How can a fix this?
    thanks,
    --w
If i don't have the disc of Windows xp what should i do can i download it or something???i have his same problem but i think mine is a little bit differetnt it doesn;t want to open any programs and neither let me install a conection HELP
Posted on Sep 08, 2008
First off turn computer on and press whatever key for setup.in setup press key for default bios setup key yes to confirm.
this isnt absolutly necessary but a good place to start.
Reboot with operating disk in drive click F8 .in menu select boot from disk.When setup starts up select install windows not repair.in the next screen it tells u there is already a system installed . select repair that system.It takes more or less the same time to install fresh copy but leaves all other installed programs intact so as you dont have to spend hours finding and re installing them.There's nothing wrong with trying check disk,though check disk cant always repair the problems you have.hope this helps it'll certaintly get you back to your system before it crashed.
Posted on Jan 09, 2008
  • 36 Answers
Use Knoppix to save your data if you need to, otherwise it sounds like you may need to reinstall the OS.
ftp://ftp.uni-kl.de/pub/linux/knoppix/KNOPPIX_V5.1.0CD-2006-12-30-DE.iso (to download Knoppix 5)
You could try using the recovery console, as previously mentioned as well. If you don't need to save data, just blow it all away and reinstall XP.
RESOLUTION loadTOCNode(1, 'resolution'); If it be the connector cable problem then replace the 40-wire cable with an 80-wire UDMA cable.
If it's a BIOS settings problem then load the 'Fail-Safe' default settings, and then reactivate the most frequently used options such as USB Support.
If it's a damaged file system case then:-
1.Insert the Windows XP CD-ROM into the CD-ROM drive, and then restart the computer.
Click to select any options that are required to start the computer from the CD-ROM drive if you are prompted.
2.When the "Welcome to Setup" screen appears, press R to start the Recovery Console.
3.If you have a dual-boot or multiple-boot computer, select the installation that you must access from the Recovery Console.
4.When you are prompted, type the Administrator password. If the administrator password is blank, just press ENTER.
5.At the command prompt, type chkdsk /r , and then press ENTER.
6.At the command prompt, type exit , and then press ENTER to restart your computer.
This takes a bit longer, but the system should boot back into Windows.
Posted on Dec 21, 2007
  • 3 Answers
If you are using Windows XP, try this solution posted on Microsoft site: http://support.microsoft.com/kb/555302, follow the procedure.
Laptop wont reboot
Hard Boot - Press the power button till it shuts down. Not an uncommon problem. It's just Windows.
Oct 07, 2012 | Computers & Internet
Ibm t30 boots with error 1820, unauthorized minipci card, remove and reboot
Updating the BIOS firmware will not lose any data on your hard disk.
If the BIOS update is not installed properly or malfunctions then the T30 may stop working unless you can roll back the BIOS update.
Feb 22, 2012 | IBM ThinkPad T30 2366 Notebook
No sound ibm thinkpad t30 windows xp sp3
After checking the obvious (volume control mute not checked, volume slider not all the way down, and volume button on keyboard is not pressed to mute) -
Go into Control Panel, system, hardware tab, device manager, Sound and Video Game controllers, and delete the sound card. Reboot your system. Windows will find the sound card and re-install it.
Hope this helps.
Aug 14, 2010 | IBM ThinkPad T30 2366 Notebook
Ibm t30 laptop has no video at start up
Try doing a hard reboot.
Unplug AC and remove battery.
Press and hold POWER for 30 seconds.
Plug in AC.
Turn on.
Upon bootup insert battery.
If this does not work I regret to say the graphics card is busted.
Apr 26, 2009 | IBM Thinkpad T30 Notebook
T30 motherboard problem
press f8 on boot up. select safe mode
Go start>run
type msconfig
hide all micosoft items in services and deselect the remoaining
Also deselect any "dghdfg" looking items from startup
Reboot
Install CCleaner & run
Dec 12, 2008 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2367
I bet your hard drive crashed on you. You might have to buy yourself a new hard drive and replace your old one with it. Then format it and install a fresh copy of your Operating System on it. Your error condes here indicate to me that you either got a blue screen or similar. Blue Screens and/or the code that you stated here are usually caused by a software issue, and are rarely hardware issues. But in this case, you may have gotten something bad on your computer, such as a virus or serious spyware, that wiped out your Operating System And caused your hard drive to crash/become corrupt. As I mentioned, try replacing your hard drive. Hope this helps.
Sep 07, 2008 | IBM ThinkPad T30 2366 Notebook
IBM T30 won't boot with LCD, but will boot OK with external eonitor
It means computer developed oxide on some contact, and this is causing a short that forces unit to shut down, laptop must be taken apart, dried properly, and eventually cleaned with circuit cleaning solution.
If problem stops when you turn to external display, then probably it is water or oxide in LCD ribbon cable connectors.
Aug 10, 2008 | IBM ThinkPad T30 2366 Notebook
T30 boot problem
Sorry, but probably your T30 (my favorite Thinkpad) has developed a problem with one of it's memory slots. It is an inherent problem with the Thinkpads. The way to tell is topress on the memory cover in a way that pushes the memory (or more to the point, the memory slots) into the motherboard. While keeping pressure on the memory, try to boot up. I use a T30, and have worked on several others, all have at least one slot with this problem. Also try taking out the memory which is closest to the front of the system, and pushing in on the remaining one. Hope this helps. If this is the problem, there are a couple of things you can do to keep it running, but probably with only one ram stick. Goood luck
Oct 07, 2007 | IBM ThinkPad T30 2366 Notebook
IBM ThinkPad T30 2366 Notebook Logo
677 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
pankaj rautela
pankaj rautela
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
