How i replace a suspension leg on a washmahine
    President:
  • 1,304 Answers
Please be more specific,
model and brand
far to many to be very helpful
Posted on Oct 03, 2009
How do I remove front suspension strut?
first off you need a strut spring compressor . then it a simple unbolt the old and put the new one in place .
Aug 29, 2014 | 2001 Citroen Xsara Picasso
How to replace the front shocks in Audi A6 1996 with diagram if possible please
This vehicle employs macpherson type suspension which means the shocker is part of the suspension leg ,Now remove this is no problem but then you promise me you will take it to a garage to have the spring changed over as this requires special machinery ,This is dangerous without the right gear and can easly decapitate or or sever a arm .Remove the three nuts securing the top of the leg and then the bottom fixing as i cannot remember offhand if its 2 bolts or yolk type fork attachment with a big bolt ?? iam not a dealer fitter but a back street cowboy whos past his sellby date
Jun 05, 2013 | Cars & Trucks
I have an He3t/110 42922200. The drum hits housing on hi speed with a heavy load. Do I replace the drum suspension springs, the shock absorbers, or both?
Check upper springs first as one snaps on this model next make sure machine is level,if all else fails you could replace suspension legs/ struts....
Jan 31, 2011 | Washing Machines
Its not low fluid. just really hard to turn wheel,then its ok.
put some engine oil on top of the suspension leg bolt thats under the bonnet so it soaks down into the bearing on the top of the suspension leg after a couple of days it should improve
Nov 30, 2010 | 1997 Chevrolet Lumina
I have the whirlpool LTE5243DQ6 model stack 24in washer dryer. I use it little because it is my vacation home. The last wash I heard the off balance clunk and when I lifted the basket back even to...
One of the three suspension legs supporting the washer drum has broken. This model is prone to this. I had mine serviced before the warranty expired and the service guy showed me how to do it. Much the same as replacing a worn shock on a car, the front panel of the washer is held in place by two hex screws that can be accessed by 'popping' the top panel of the washer unit. Once the screws are removed, you can then access the whole unit by disconnecting the wiring loom and the internal water hoses. Sometimes if the suspension leg isn't broken, you can screw it in place and secure it with a screw. This is what the service guy did, but it came loose in a few months. There is a new kit that replaces the old suspension legs but I haven't ordered it so I can't comment.
Jun 04, 2010 | Whirlpool LTE5243D Top Load Stacked...
How do I change suspension legs on Hotpoint WMA 62? The drum on my Hotpoint WMA 62 is bouncing around really badly on fast spin which disconnects an electrical connector turning the machine off. Both the...
Could be worn or broken dampers, or loose concrete balance weight.
This would cause the problem you describe.
There are 2 wieghts, one in the top, and one at the bottom of washer.
Check that the nylon locating pins are securly fixed in the damper legs, as sometimes they have been known to come out of socket.
Mar 22, 2010 | Washing Machines
Out of balance how do I fix it maytag washing machine model 9457AAE
Only two options are there in it one is upper holding spring & lower suspension problem kindly check whether the suspension two legs will be there both are evenly moving otherwise replace the two legs which is not working fine then go for the upper spring if you found the upper spring problem replace the upper springs
Dec 24, 2009 | Washing Machines
Leg replacement
u should have asked who told you, the term used for the "front suspension leg" or damper/shock absorber also known as a macphursion strut,
Dec 05, 2009 | 2002 Kia Rio
Suspension legs for hotpoint WF740P
change all 3 legs together quote model no.of machine
Jun 30, 2009 | Washing Machines
Adjusting suspension
hi there,,if u can see a air valve on top of the forks, then u can use a bicycle or foot pump to squeeze a bit more air to the fork,, or if there is an adjuster on the fork,ie, a plastic lookin cap with 1 2 3 4 and a arrow on it u can turn that to a comfortable position,, if there is nothing u can see, then u either have not enuff fork oil in each fork leg,,or if there is enuff,, u will need to change the grade of fork oil and replace wots in it,, so id say a more harder grade of oil,, usually there isnt enuff oil in the forks to make it dive into the front wheel,, try topping the oil up,,with about,4or 5 egg cup fulls of oil in each leg,,if nothing has made any difference,, put in another 4 or 5 ,,,any probs on how u put oil in2 the legs ,please do come back in ,and il tell u how 2,, im assuming u do no,, ok ,,cheers
Jan 29, 2009 | 1995 kawasaki KLE 500
Washing Machines Logo
97 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
