Question about Sharp UX A255 Plain Paper Thermal transfer Fax
Cheat for Printing Transaction Reports?
Is there a cheat for getting transaction reports out of the UX-A255 a day or two after the FAX was sent? It's pretty important I get it, and I can't believe there isn't some code to retrieve the last few reports out of the machine.
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Sharp Master
  • 1,362 Answers
Sharp copier mx-m350n
Custom Settings > Key Operator Settings > (enter access code usually 00000) > Image Send Settings > somewhere under this heading is the Fax setting to control transaction reports
Oct 25, 2013 | Sharp Office Equipment & Supplies
HOW DO I PRINT FAX CONFIRMATION REPORTS PLEASE
Touch the [Image Send Settings] key, the [Fax Settings] key, and then the [Fax Default Settings] key to configure the settings.
Go to Transaction Report Print Select
Setting
These settings are used to set the conditions for printing
transaction reports for single transmissions, broadcast
transmissions, receptions, and confidential receptions.
For each type of operation, touch the key of the desired
condition.
May 16, 2011 | Sharp MX-2300N Color Copier
How do I print the fax log?
Follow the steps below to print Fax Logs for already received faxes
  1. Press Setup , and then press 2 . This displays the Print Report menu.
  2. Press the Right arrow button to scroll through the following report types:
    • Fax Report Setup: prints the automatic fax reports as described in Generate reports automatically.
    • Last Transaction: prints details of the last fax transaction.
    • Fax Log: prints a log of approximately the last 30 fax transactions.
    • Speed Dial List: prints a list of programmed speed-dial entries.
    • Self-Test Report: prints a report to assist in diagnosing print and alignment problems.
  3. After the desired report is highlighted, press OK .
Also, Click on the link below for more information about Fax settings on your printer
Fax Settings
* Please rate this solution with Thumbs up and Testimony to help us improve providing support
Dec 31, 2010 | HP OfficeJet 6210 All-In-One InkJet...
Re: Fax Machine - Sharp UX-B700 Everytime I send a fax I get a print out if the fax was sent or not. A whole paged is use... this is paper waste... can it be stopped?
Yes you can stop it printing the report. Use the menu to cruise through the settings for fax. You will find the reports section and recognize that you don't want the memory storage report, so disallow it by pressing th no key.
Oct 06, 2010 | Sharp UX B700 Plain Paper Inkjet Fax
Can a sharp ux-p410 retrieve old sent faxes from its memory
No, your fax machine only records the fax number of the last 50 transactions
Oct 19, 2009 | Sharp Office Equipment & Supplies
Eliminate the transaction report
To eliminate the transaction report, perform the following:
  • Press Function button once
  • Press down arrow 3 times
  • Press right arrow > once
  • Press 5 "Never Print"
  • Press "STOP"
This will eliminate ALL transaction reports. There are 5 options for this function.
  1. Always Print
  2. Error/Memory Print (memory errors only)
  3. Send Only (prints only on sent fax)
  4. Error Only (prints only when there's an error encountered)
  5. Never Print (eliminates all transaction report printing)
This should solve your problem. Please post back with any questions and/or to rate this solution. Thank you very much.
Greg
Aug 11, 2009 | Sharp UX B700 Plain Paper Inkjet Fax
Delivery reports
Hit function button, go to transaction list, there will be 4 options : never print, always print, send only and if error only
Jun 01, 2009 | Sharp UX-B800H Fax
My Sharp UX-355L Fax machine printed unwanted information
Sounds like you have the machine set up to print reports on all occasions, fax transmission, error, etc. You can change this by doing the following:
1 Press these keys:
The display will show:
FUNCTION
TRANSACTION LIST
2 Press a number from 1 to 5 to select
the condition for printing.
ALWAYS PRINT A report will be printed after each
transmission, reception, or error.
ERR/TIMER/MEM A report will be printed after an error,
timer operation, or memory operation.
SEND ONLY A report will be printed after each
transmission.
NEVER PRINT A report will never be printed.
ERROR ONLY A report will be printed only when an
error occurs.
To print from memory:
If the memory becomes full...
If the memory becomes full while the document is being scanned,
MEMORY IS FULL will appear in the display.
♦ Press the START/MEMORY key if you want to transmit the pages
which have been stored up to that point in memory. The remaining
pages will be ejected from the feeder. After transmission, the memory
will be cleared and you can transmit the remaining pages. You
will also need to transmit the page which was being scanned when
the memory filled up.
♦ Press the STOP key if you want to cancel the entire transmission.
Hope this helps. : )
Mar 30, 2009 | Sharp UX 355L Plain Paper Thermal transfer...
I want to report all the telephone numbers dialed today. How wil
You can either view, or print the transaction reports. The machine should print out automatically after 32 transactions, or you can print manually. To print out manually after each transacton, from the control panel select "function", 6, 1, set key. Pesssing key 1 will print journal, pressing key 2 will let you view journal. To set the printing of transaction report for all sent faxes, you can get into the fax parameter setting #13, and scroll to your selection using the up (^), or down keys.
Dan
Jan 07, 2009 | Office Equipment & Supplies
Can't get Fax Confirmation page to print
What model brand name something!!!!!!
Nov 12, 2007 | Sharp AR-F152 Fax
Sharp UX A255 Plain Paper Thermal transfer Fax Logo
134 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
