Question about HP Officejet 6500 Wireless All-in-One InkJet Printer
HP officejet wireless 6500 printer won't print
HP officejet wireless 6500 printer won't print with kodak photo paper- says no paper and to load paper tray, although the paper is there.
  • 3 more comments
  • raju
    raju Mar 04, 2014
    we are using hp L600 printer
  • Anonymous Mar 13, 2014
    hp officejet 6500
    hp officejet 6500 head
  • Anonymous Mar 15, 2014
    color seettings on enable color printing in my HP Officejet 6500 E710n-z
    can not print color enable color printing in my HP Officejet 6500 E710n-z
    Guru:
  • 224 Answers
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
HP 6500 wireless, having horizontal lines in photo printing
Perform nozzle clean, repeat this process twice or thrice check the print quality, if not satisfied replace print heads...
Jan 31, 2012 | HP Officejet 6500 Wireless All-in-One...
Cannot prink anything in black from my HP officejet 6500, have changed cartridge, colour print all ok
Check whether the cartridge's correctly installed and re-install correctly.
Clean the printhead by:-
  • Load into the printers paper tray a plain A4 sized paper.
  • On the printers control panel,press the setup button.
  • Select tools and press OK.
  • Now select clean printhead and press OK.
  • After printhead cleaning,turn the printer off and then on again.
Hope this helps.Thanks!
Oct 10, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP officejet 6500 keeps giving me two messages 1. load paper when there is already paper and two align cartridges for 7 minutes.
before you on the unit put a single page on a tray then turn it on while initializing it feeds the paper automaticaly then print a sample page after printing put the sample page face down on the scanner then press the scan button then wait till the power on light stop blinking then youre ready now
Aug 09, 2011 | HP Officejet 6500 Wireless All-in-One...
My HP Officejet 6500 Wireless printer won't print in black when trying to print from Microsoft Office Word and Microsoft Office Excel or PDF. The ink cartridge is new. I have turned the printer off and...
I also have the OfficeJet 6500 and had the same problem. The black text was printing using a mix of colored inks instead of the black ink, resulting in a grey, fuzzy text. I finally found a solution. In each application under Page Setup, there is an option called "Format for". Mine had been set to "Any Printer". I changed that to "Officejet 6500 E709n [830E4A]" and now it prints the black just fine. I have a Mac running 10.4.11. Hope this helps.
May 17, 2011 | HP Officejet 6500 Wireless All-in-One...
There are no instructions on how to print photos on this printer
here is a pdf this is the user guide take time to read it maybe newer than the one u have even if its brand new it could have been sitting for a while anyway all u need to do is in the program u are printing from go to printing propertys select ur paper ie photo paper then the quallity ie photo and there ya go
http://bizsupport1.austin.hp.com/bc/docs/support/SupportManual/c01669504/c01669504.pdf
Jan 20, 2011 | HP Officejet 6500 Wireless All-in-One...
Hp officejet 6500 wireless printer won't print quickbooks checks
go to control panel, printers, right click on my printer icon (HP Officejet 6500 E709n), click properties, click advanced tab and check "print directly to printer"
Nov 26, 2010 | HP Officejet 6500 Wireless All-in-One...
HP Officejet 6500 Wireless All-in-One InkJet Printer Logo
5,004 people viewed this question
Seeker5211
Seeker5211
